Old 01-26-2008, 06:53 PM   #1
Car: 06 STI
Default Using a Tactrix cable with StreetTuner?
I have read that a few of you guys are using tactrix cable with SteetTuner. How are you guys doing this? I only have one serial port, and dont want to spend money on a serial to usb adapter if I can use my tactrix cable. All healp is appreciated.
attila is offline   Reply With Quote
Old 01-27-2008, 03:04 AM   #2
Moderator & ECU Tech
Fav Mod: mo boostaz
Default Re: Using a Tactrix calse with StreetTuner?
... by just plugging it in and using the normal ST configuration stuff.
t
Old 01-30-2008, 07:47 AM   #3
Car: 05 Subaru WRX STi
Fav Mod: Cobb StreetTUNER
Are you using the 'COBB USB cable' option?
Tactrix drivers installed?
COBB drivers (if any) installed?
Old 01-30-2008, 11:49 AM   #4
Car: 05 CGM FXT
I just plug in my tactrix cable and choose com2 (that's what the cable shows up as) rather than com1. Done.
ZuMBLe is offline   Reply With Quote
Old 02-04-2008, 04:14 PM   #5
Car: 06 STI
When I plug it in it just acts like there is no cable at all. There is nothing but com1, because I tried that. I tried to use the cobb usb option and it still didnt work. I didnt have to use any drivers when I use the tactrix cable for anything else.
Old 02-08-2008, 09:44 AM   #6
I installed the drivers and it works fine with ST.
Old 02-08-2008, 04:29 PM   #7
Car: '99 M3/'03 WRX Avant
Fav Mod: Modification is wrong!
You'll probably need to use the VCP driver for the FTDI chip the Tatrix cable uses, otherwise the cable does not show up as a COM port.
Rob
STirish is offline   Reply With Quote
Old 02-08-2008, 04:46 PM   #8
Enginerd
Car: The Spaze Mobile
Fav Mod: Tuning
I had to download ECUflash to get the tactrix drivers. I couldn't find them any where else.
Old 02-10-2008, 02:13 PM   #9
Car: 06 STI
Found the drivers and it works now. Thanks for the help.
Old 02-10-2008, 06:06 PM   #10
FYI, the Tatrix/ECUFlash drivers are the same as what you get from FTDI.
Rob
Old 02-10-2008, 06:34 PM   #11
Fav Mod: CAR LIFT & Protune!
is this used to tune your own car??? i have a program called enginuity (for logging), i would really like to know more about this stuff....
Old 02-11-2008, 09:49 AM   #12
Car: 06 STI
Ya its to tune your own car. I was using enginuity for a while, streettuner has more features. It is pretty much protuner for personal use. If you do a search you will find alot of info about it.
Old 02-12-2008, 07:19 AM   #13
PS. Enginuity is now called RomRaider.
Old 02-13-2008, 05:36 PM   #14
Fav Mod: Coilovers
okay this might be a stupid question but im just trying to learn as much as i can..... if i have cobb streettuner, and download say stage 2 map, am i able to flash the map to my ecu via a tractix cable? or do i need an AP?
ChefMasterfunk is offline   Reply With Quote
Old 02-14-2008, 11:12 AM   #15
Enginerd
Fav Mod: Tuning
You cant flash anything with StreetTuner. If you want to flash a StreetTUNER map, you have to save it as a base map to your AP THEN flash it to your ECU.
You can run realtime maps directly from the StreetTUNER interface though.
