Old 01-08-2008, 05:38 PM   #1
Car: 06 Silver STI
Question Cel P2008
I just got a CEL on my STI 06 currently running Cobb Street Tuner base map, P2008 is some kind of open circuit on intake tumble valve Bank 1...can anyone explain me which one is Bank1 and any other hints on how to isolate the problem to the root cause.
Thanks
stirulespr is offline   Reply With Quote
Old 01-08-2008, 06:18 PM   #2
Car: 2007 STI
Fav Mod: Perrin GT30R
Send a message via AIM to 12SecSTI Send a message via MSN to 12SecSTI
Default Re: Cel P2008
i'd have to grab a manual, but if its a circuit low code, a connector is unplugged.
12SecSTI is offline   Reply With Quote
Old 01-08-2008, 06:27 PM   #3
Car: 06 Silver STI
Question Re: Cel P2008
All connectors to tumble valve motors and sensor were verify today but CEL will come up after an ECU reset. Can you tell me which side of the motor is BANK 1?
Thanks,
Old 01-08-2008, 06:34 PM   #4
Car: 06 STI
get a 2008 sti
06naSTI is offline   Reply With Quote
Old 01-10-2008, 08:09 AM   #5
Car: 05 Subaru WRX STi
Fav Mod: Cobb StreetTUNER
I have data for 2005 MY your terminal numbers may vary.
P2008
Bank1 is Right Hand side
Check pins 8 & 9 on ECM connector B134
If less than 1 ohm check connection at TGV actuator connector or replace the actuator.
Otherwise there is an open in the harness. There are three segments in the harness. ECM (B134-8&9) to F74/B200-7&18 to E2/F61-5&6 to TGV actuator (E55-1&2).
Hope that helps.
Old 01-10-2008, 10:26 AM   #6
Car: 06 Silver STI
Right hand side = Pass side....
Can you tell if the connector or cable have id on them, not sure how to locate the proper ECU connector?
Thanks,
Old 01-10-2008, 03:39 PM   #7
If you have a left hand drive car then yes.
Thanks,
Connectors are not labeled. I suggest you get a three day subscription to the Subaru Technical Information System all of the (current) info you need to troubleshoot your particular Subaru.
Old 01-12-2008, 01:07 PM   #8
Car: 06 Silver STI
Found a broken wire, looks like a rat got into my car and start eating one of my cables........jeje... No the hard part will be to get rid of the rats around my garage.....
Old 01-13-2008, 07:48 AM   #9
makes you wonder what else might have been damaged.
