Old 09-26-2007, 10:24 AM   #16
Default Re: Darton sleeves or ceramic coating?
^^ Suggesting for someone to use a stock block for power levels above 500whp. Wow!
I guess some dynos read extremely high. If the Cobb mustang dyno read about 20% - 25% higher like your dyno, maybe I could suggest the use of a factory engine.
I am sure you will agree, a better answer would be to look at things this way.
- Power level wanted?
- Use of engine?
- Boost pressure needed depending on turbo used for the desired power level.
- What dyno you want to make that kind of power on?
To handle that kind of power for any length of time I would suggest a sleeved engine.
Feel free to PM or email me (jeremy@cobbtuning.com) with any questions.
- J.
Jeremy@Cobb is offline   Reply With Quote
