Old 06-19-2007, 04:43 PM   #31
Car: OBP 2006
Fav Mod: Hindsight
Default Re: BC 2.7L with 30r .82
I was looking at this exact setup but with a GT35r. Let me know what labor is on the engine work not the heads just the internal rebuild.
drksdesti is offline   Reply With Quote
Old 06-20-2007, 02:28 PM   #32
Car: x2 05 WRX STi's
Well started to take measurements and do the math, with the parts I have purchased I will end up with a 9.18 to 1 compression ratio and the best news is TDC is .002" lower from the deck than stock so (I still need to do the math on the cams BUT) I will be able to run AVCS without the scare of kissing a piston .
Sinister redlines is offline   Reply With Quote
Old 07-18-2007, 04:24 AM   #33
oMgWTFpewpew
Fav Mod: grip.
Send a message via AIM to chaos311clarity
bump for updates!
Old 09-10-2007, 06:00 PM   #34
sorry for the late results but engines been mocked up a few times, destroyed a set of avcs pulleys to make a degree tooling to see where the valves are in relation to piston clearence. I have also ditched the 30r for a 35r .82 Ya I know ate my words LOL.
Old 09-10-2007, 06:34 PM   #35
^ I was just about to say, I would have gone w a 35r w that setup. Good choice keep us posted
wrxcelration is offline   Reply With Quote
Old 09-10-2007, 07:38 PM   #36
I'm on the twinscroll bandwagon right now, so maybe look at a APS TSR70 (with a proper compressor housing) or even a Full-Race GT40R. Hello spool and hello power.
Why not? You have the safety of your block to back all that power up.
Old 09-10-2007, 08:06 PM   #37
Fav Mod: Me.....
too late... hes already has the 35r kit.... Iam trying to get him to throw a 42r on it just for a few dyno runs. lol
Old 09-11-2007, 04:40 AM   #38
Car: 07 WRX STI
Fav Mod: Matching Dead Pedal
Send a message via Yahoo to cpunlamd
The 35R is the perfect turbo for this set up as a DD. I was thinking that the 30R was too small for even the 2.5 block.
(0.82 > 0.63)
cpunlamd is offline   Reply With Quote
Old 09-11-2007, 04:39 PM   #39
So new poll?
whats a 2.71L, ported heads, 1mm bigger valved, cammed balanced engine with a gt35r .82 going to make?
Old 09-11-2007, 06:13 PM   #40
Fav Mod: AP Stage 2
zero traction until 60.
Old 09-11-2007, 06:31 PM   #41
GUNNIN' IT
Fav Mod: Sparco seat
Subscribed because I just can't stop imagining the spool you are going to have
Old 09-11-2007, 06:35 PM   #42
Car: 07 STI LTD #67
Fav Mod: Andrewtech built, Turbo XS tuned GT35R 624 AWHP. 528 AWTQ on VP C16
Originally Posted by Sinister redlines View Post
So new poll?
My guess...
518 hp on pump
635 on C16
TAPOUT is offline   Reply With Quote
Old 09-16-2007, 09:39 PM   #43
Car: 05 wrx sti
Fav Mod: 2.7 stroker
I'm interested in this kit as well,got a few questions for you. After you installed the darton sleeves was there any extra machining required to acheive enough clearences (eg crank to sleeves or block). Can you get a head gasket to suit the 102 mm bore.
Also what spool are you hoping for on the 35R I'm running a twin scroll GT30R with a 1.06 ex housing at the moment but looking at upgrading to a twin scroll GT35R . I'm still trying to decide on the compression ratio for my build as I am running 2L Sti heads.
thanks
Sti 500 is offline   Reply With Quote
Old 09-17-2007, 07:04 AM   #44
Car: 06 White/Gold
The hotside(.82 did you say) is gonna limit you on that setup. You are gonna be pushing to much air out of the motor for it to make max power. It will spool crazy fast, but youll be leaving power on the table. There is a guy down here in Austin that has a cosworth block and heads and the APS TSR70 kit and with the stock hotside(82 I think) they left alot of power on the table because the motor was pushing crazy amounts of air. They switched to a 1.02 or 1.06 hotside(not sure) and he made about 60 more hp. Here is a link to that post http://forums.nasioc.com/forums/show....php?t=1238228
When they switched the hotside it made 540 whp. There is another tread on that.
rjacobs is offline   Reply With Quote
Old 09-17-2007, 07:27 PM   #45
Ya I am thinking the same but I want a good dd that is strong but not unmanagable.
