Old 05-04-2007, 03:33 PM   #16
Fav Mod: CP35r 440whp
Default Re: Can I rev to 8500rpm? engine bulders, info please
I would contact ARfab, and buy one of their oil pumps.
balance the assy to nuts on perfection, and possibly to the ej207 crank drilling. contact Ron at Axis and ask what he does to his cranks to mod them, for retiming the oil passages....
Old 05-04-2007, 03:48 PM   #17
Car: 05 OBP STi
Fav Mod: My Right Foot
If you plan on turning the motor that fast, balance and blueprint during assembly is probably a good idea.
RdRacer301 is offline   Reply With Quote
Old 05-04-2007, 05:02 PM   #18
Car: 05 STi OBP
Fav Mod: All of them
I made an inquiry to Howard at ARfab about extending the redline..he said that you will need to modify the heads oiling, upgraded valvetrain and also recommends upgrading cams to make power to higher rpm.
Personally I was told not to use DPR cams, there have been a few motor failures local to me from them. They are modified wrx cams from my understanding...
Black-STi is offline   Reply With Quote
Old 05-04-2007, 11:37 PM   #19
Car: 04 wrx
Fav Mod: t04z
I was always told that DPR sourced custom grinds from crower.
I'll ask about the oil pump.... I'm trying to do this on a budget. But I guess you gotta pay to play right?
ilivas is offline   Reply With Quote
Old 05-05-2007, 12:03 AM   #20
GT R US
dan grinds his own cams.
the cosworth pump offers marginal improvement over the stock pump. they make a point that the flow rate is unchanged. save your money. if you want to spend money on something meaningful, get an accusump.
you can probably do it but youre going to have the valvetrain maxed out at 8500 rpm. 78-8200 is more reasonable.
Old 05-05-2007, 12:19 AM   #21
Car: 04 wrx
Fav Mod: t04z
I'd be happy with 8k.... much better than the 7k I was revving before.
So I guess it's the valves themselves that are limiting me right now??
Old 05-05-2007, 03:32 AM   #22
Car: 03 mbp gga
Fav Mod: 12.9 / 105+
Send a message via AIM to ride5000
have you guys actually heard of valve damage/failure from overrevving?
i don't mean shim spitting/splitting from after or backfires...
i don't mean bottom end damage from lack of oil at high rpms...
i mean actual valve float/piston contact/etc, from overrevving.
ride5000 is offline   Reply With Quote
Old 05-05-2007, 05:33 AM   #23
Fav Mod: Synapse FMIC
My stock ej257 spun to 8500ish at least a dozen times... every time it was the same situation... shifting from 4th to 5th I'd get a grind in 5th, pause for a sec, try 5th a second time, and catch 3rd instead.
The heads and bearings were fine when the motor came apart.
Revving that high under load is another story though.
Old 05-06-2007, 06:02 AM   #24
Car: 03 mbp gga
why would that be?
Old 05-12-2007, 03:38 PM   #25
Car: 04 wrx
Fav Mod: t04z
I'm kind of curioous as to why I cant do it
Old 08-02-2007, 03:54 PM   #26
WJM
Car: 1996 SUBARU Legacy
Fav Mod: Hankook C50
just rev it to 12 and see what happens.
WJM is offline   Reply With Quote
Old 08-02-2007, 05:18 PM   #27
520
STi > EVO... Wait what???
Car: 03 EVO
Fav Mod: stock :(
Send a message via AIM to 520
did you even see how old this thread is?
Old 08-02-2007, 05:48 PM   #28
Car: 95 Supra Single Turb
Fav Mod: Big Turbos
Send a message via AIM to SupraJaySTI Send a message via Yahoo to SupraJaySTI
why not go with a smaller AR? like a .68??? Im using that on my supra and i get full boost at 3,500rpm instead of a .82 ar which would bring me above 4k. I know that you lose topend cause of the lower ar but ive noticed no weakness in the turbo at topend.
Or just get some Nitrous for spool up only that can give you more of a powerband.
Or just get a smaller turbo. reason why i ask this is because are you making 600+hp?? if not than theres no point of having that turbo on there.
my .02
SupraJaySTI is offline   Reply With Quote
Old 08-02-2007, 06:28 PM   #29
Fav Mod: LS6 and T-56 swap :D
WTF? I thought this thread was about revving to 8000+ RPM. Smaller A/R? Nitrous? That was pretty random
Anyway, I was pretty curious myself because I wouldn't mind being able to rev to 8k when the time comes to build my engine. So I guess there is no power to be had above 7k without any headwork and cams?
Rookie84 is offline   Reply With Quote
Old 08-02-2007, 09:26 PM   #30
Fav Mod: Big Turbos
it was just a suggestion thats all
