Old 04-17-2007, 12:14 AM   #1
Post Possible Gruppe-s Stage 2 built block issue!
Hey guys, I'm having some issues with my car right now. It's currently @ GST getting diagnosed for quite some time. It's making a really weird sound either from the drivetrain or the motor itself after getting the car back from a tune on a drive back home. The car will stall during idle, neutral coast, on the stop with first gear in, and etc. It's hard to describe the sound, but it's a combination of a hissing and grinding sound (kinda like a rattle snake sound) either the from the engine or the tranny . I have a gruppe-s built block with about 3000 miles of break in miles with a safety base map/stock turbo and I've performed many oil changes and each time copper metal flakes were found in the oil. I'm guessing it's a bearing problem, but the car was never starved of oil and the motor was professionaly installed by Gruppe-s during the date of the purchase and gives me reason to believe that I was given a defective motor. Either way, someone owes me a new motor if there is something wrong with it.
The other issue that the mechanics @ GST are telling me is that it could be the drivetrain possibly be the tranny or the center diff to be more specific. Now I've had my share of broken diffs, and have friends that have blown center diffs so I know exactly what some of the symptoms are. Being a certified mechanic myself I can confirm that the gears are fine, I can shift through all the gears with no issue. There is no check engine light pointing towards the dccd or tranny. No locking or binding during corners or driving in straight lines. The clutch is fine (which we thought first was the culprit), and even with the clutch depress in or out I can still here the sounds during free revs. I took my tranny out in the shop and shook it a couple times with a few man power and there was nothing loose in the tranny. The input shaft spinned freely with no binding what so ever. So everything seems ok in the tranny. I can also disconnect some sensors and that should turn off the dccd/diff, but I really can't do that since the car is not in my possesion.
There has been no oil/tranny oil changes done to check for metals recently. So I can't confirm if there are large amount of metals in the motor or in the tranny oil. But I've seen copper flakes on the oil dipstick when checking the oil. I'm currently @ the mercy of GST so all work and time is done through them or borrowed time to use the lift. All I want is to come to a conclusion with the car so it can be fixed, so any help or opinion would be great.
Now here are some of my question to anyone that can answer them or verify things that I know and don't know just to check if I'm in the same page with everyone else so can I rule things out.
1. Can it be center/front diff? What kind of symptoms are people getting with broken diffs? Can it cause the car to stall and die during idle or in gear.
2. Could it be a bearing problem? Now even with a rod bearing or etc., the car can still be driven with no stalling/dying out issues. I don't remember hearing a clanking sound, but there is definitely something wrong. Now will a car with a bearing problem cause the car to die or stall out? The motor is not seized, so it's still running.
3. Oil pump issues? Probably from all the metal flakes.
4. I can go on and on, but I think I will leave it at this and get more ideas from you guys since it's getting late.
Any helpful info would be great!. I will chime in more tomorrow when my mind is fresh.
Thanks,
Ron
BLUE STINGER is offline   Reply With Quote
Old 04-17-2007, 06:06 AM   #2
Car: 05 Subaru WRX STi
Fav Mod: Cobb StreetTUNER
Default Re: Possible Gruppe-s Stage 2 built block issue!
One of my timing belt idlers was bad after I got my motor swapped. It took a little bit to hunt down the source.
Old 04-17-2007, 07:02 AM   #3
Car: 06 Subaru Sti
Send a message via AIM to Boxer112
i suggest b4 u post here where there is a possibility of someone getting blamed, you contact appropriate vendors
Boxer112 is offline   Reply With Quote
Old 04-17-2007, 08:31 AM   #4
Not too sure what you're trying to say here, but I'm not here to target any vendors. I have an issue with my car that I'm trying to get opinions in, I currently have a professional shop working in my car and we don't know what's wrong with it. Regardless, thanks for the advice.
Ron
Old 04-17-2007, 08:33 AM   #5
I will look into that.
Ron
Old 04-17-2007, 09:05 AM   #6
Car: 06 Subaru Sti
im not saying you are targeting vendors but it doesnt mean other people wont.I honestly hope everything works out for you though.
Old 04-17-2007, 09:21 AM   #7
if GST can not find the problem, take it to LIC. Can't beat the level of service, and professionalism there.
mcdrama is offline   Reply With Quote
Old 04-17-2007, 09:25 AM   #8
"Formerly Surfa2527"
Fav Mod: Dyslexia
Trader Rating: (13)
Gruppe-s is the one diagnosing it?
The idling issue sounds like a tune problem or vacuum line off. The other sounds may be a totally different issue.
After 3k, I would not think you would still be seeing metal flakes.
Old 04-17-2007, 10:58 AM   #9
Car: aka - DownSTi
Fav Mod: Big Thanks to Jeremy @ Crucial Racing and ED @ EQ - Tuning
good luck with it my homie
i hope everything works out and you find the answere here ron
BUMP for my homie ron
sean
13onesti is offline   Reply With Quote
Old 04-17-2007, 11:20 AM   #10
Car: 06 Black STI
Fav Mod: Turbo
No GST are the one's trying to diagnose the problem... There mechanics @ GST are telling him is that it could be the drivetrain possibly be the tranny or the center diff to be more specific...
gilmore25 is offline   Reply With Quote
Old 04-17-2007, 11:21 AM   #11
Car: 06 Black STI
Fav Mod: Turbo
sean
Old 04-17-2007, 11:33 AM   #12
I think Ron and I already discussed what the problem is
BM_STi is offline   Reply With Quote
Old 04-17-2007, 12:43 PM   #13
Fav Mod: Dyslexia
Trader Rating: (13)
If it's Grupp-S's motor & they installed it, why don't you take it back to them?
Old 04-17-2007, 12:59 PM   #14
You shouldn't be seeing much, if any, bronze colored glitter in the oil after the first 2 oil changes - most of it is the [piston/bearing] coating sluffing off and that happens right away. But, if this is bearing material you have to realize this could be coming out the turbo as well - they do share the same oil.
Old 04-17-2007, 01:25 PM   #15
Thanks for the advice Flycaster. I've have done probably 7 oil changes on this new block if I can recall. Each time during start up, I primed the oil by removing the coil packs. I check my oil all the time and I'm very thorough with my car since I do most of the work on it myself. It was broken in with my stock turbo, and even with my new turbo with less than 200 miles copper flakes are still present in the oil dipstick.
Ron
