IWSTI.com: Subaru STI Forum
Go Back   IWSTI.com: Subaru STI Forum > STi Technical Discussion > Engine, Power, & Performance > Built Motor Discussion
Old 11-30-2006, 01:53 PM   #1
Car: 05 STI 2.0L 6speed JDM
Default CAMs Q? please help.
i called XX tuning for an order of cams set. JOHN tolled me i need to tell him if i have AVCS or not. he said in the us 2.5L has them and the 2.0L dos not.
my Q:
how do i know if my car has them or not ? is it some thin from the inside of the engine or outside the engine ?
hope you can help me ?
what cam is good for street and Little strip
Assami is offline   Reply With Quote
Old 11-30-2006, 02:03 PM   #2
Car: 05 Crystal Grey
Fav Mod: AMR BIG MAF
If you have an STi or a 06+ WRX then YES you have AVCS. If you have a 2.0L WRX then NO you DONT.
SubySat is offline   Reply With Quote
Old 11-30-2006, 02:19 PM   #3
Moderator
Car: 05 Ram 3500 CTD
Fav Mod: Majin
all usdm STi's have AVCS...
Why do you want cams? there are better performance upgrades unless you are already running a big turbo built block with EM...
Old 11-30-2006, 02:59 PM   #4
they are for a Friend, we pulled his engine and we need the best for street and strip
it is a 2005 STI 2.0L 6SPEED
Old 11-30-2006, 03:02 PM   #5
DUD. HOW SURE ARE U ?
Old 11-30-2006, 03:36 PM   #6
If you have a 6 speed equipped STi drivetrain it has AVCS. If you have AVCS it is easy to identify by the 3 way oil line on the head going to the turbo and up to the front for the AVCS. You can run a non AVCS cam in an AVCS car but you will lose the AVCS capability. Remember that AVCS will not increase top end power at all. It is fully retarded once you are over 5000 RPM anyway but it will help with spool up and response a bit.
Guru is offline   Reply With Quote
Old 11-30-2006, 04:11 PM   #7
Moderator
Fav Mod: Majin
I dont think the 2.0l got AVCS, but ill let the experts chime in...
Old 11-30-2006, 04:56 PM   #8
Car: 06 acura tsx
Fav Mod: soon to come
Send a message via AIM to whitson01 Send a message via Yahoo to whitson01
wait a min, is this a usdm or what?
whitson01 is offline   Reply With Quote
Old 11-30-2006, 05:09 PM   #9
Moderator
Fav Mod: Majin
apparently not with the 2.0l
Old 11-30-2006, 11:01 PM   #10
It Is For The Medial East Market ( So I Think It Is Jdm )
Old 12-02-2006, 10:33 AM   #11
LOOKING AROUND AND FUND THIS:
http://www.drivesubaru.com/Win05_WhatsInside.htm
Old 12-02-2006, 11:02 AM   #12
Car: 06 acura tsx
talk to: cosworth, ar fabrication, brian crower etc.. these are companies that make cams or build motors (or both) and they should be able to direct you..
