Old 10-30-2006, 07:11 PM   #1
Car: 2004 STi
Fav Mod: Ohlins Sportlines
Default building my block
I have been playing with the idea of building my block and going with the GT35R. I would go with cobb pistons and rods. New rod and main bearings. I know i would have to get my crank rebalanced and i was thinking about a small bore on the engine to start out with clean cyliders. Other than this, anything else that i need to take into consideration? I know i'm going to have to really keep up on oil changes and tranny fluid. Any other things that i will really have to keep a close eye on?
shorty5198 is offline   Reply With Quote
Old 10-30-2006, 07:15 PM   #2
Car: 02 WRX 675whp 584ftt
Fav Mod: 8 1600cc injectors
With a small bore to clean the cylinders up you will lower the power you can go with it...since you will be making the sleeve slightly thinner by .020" or .5mm. The stock sleeve is already pretty thin and weak since it is a grey iron casted sleeve.....What are your goals?
Howard
AR Fab is offline   Reply With Quote
Old 10-30-2006, 07:30 PM   #3
Car: 2004 STi
my goal is 500 to the wheels. I'm gunna run alcohol injection as well. What about cobbs stage 3 street block? I've been looking into their blocks and they look good
Old 10-30-2006, 08:03 PM   #4
retired mod
Car: 99 WRX STi V5
Fav Mod: JDM Air Freshener
Send a message via AIM to eatV8 Send a message via MSN to eatV8
Cobbs blocks are great, as to is AR Fab blocks and a couple of others.
eatV8 is offline   Reply With Quote
Old 10-31-2006, 06:32 AM   #5
knowing how thick the cylinder walls are on a subie block I would make sure your buying a new block instead of reusing yours. We offer a core discount for your old ones or I would suggest Sleeving. Not only does sleeving allow for added strength for more power it also keeps its shape during high cylinder pressures so you will get better ring sealing which = more power than a stock sleeve....
Something we have noticed....Honda blocks have a thicker cast cylinder than a Subie but its rare that you see a Turbo Honda running more than 450whp on stock sleeves....one reason is the stock Honda Knock sensor is better off in the trash can.....the other is people have been sleeving them for 8 yrs now and they know the advantages of aftermarket sleeves....its a matter of time before everyones first engine mod is sleeving in the Subie comunity. The cost value of a Honda sleeving job 8 yrs ago was over $1500 now the average is $950.....some day the Subies will be this low too...but since there are only a small handful of engine shops that have the capability the cost is high....
Anyone can offer a 500whp package utilizing a new short block from Suby....add in some cheap H-Beam rods and a replacement forged piston that uses the factory wrist pin locks and factory rings.....but as many have learned this could lead to incorrect piston-wall clearances or no ring sealing due to improper ring installation on the piston. These shops are not engine shops guys....we call them "Parts Hanging Shops" and they have no clue what they are doing they just know its worked a few times before and decided to sell the package and do not care about you and what you are doing. We dont really have a set package for engines and we update what we do for engine builds on a daily basis. I have engineered, yes you read this correct, our own piston for the Suby engine to help remedy common problems that are associated with built Suby engines. We sleeve our blocks in-house. We balance our rotating assemblies in-house. We have had bearings made to my specifications also. So when our clients come to us for an engine build we will taylor it for them. We are even working with Dan at DPR to create our very own CNC ported head profiles to work with our engine setups as well. As much as I dont like the East to West coast distance between us, he is the only person I would trust to do what I am asking for rather then just jamming some sanding rolls on a die grinder and calling it ported! I can build any engine combo comparable to any other shop for the same or slightly better pricing, thats easy, but when you want something thats well engineered for you....there are only a few that can do this.... Im on that list!
Howard
Old 10-31-2006, 11:44 AM   #6
retired mod
Car: 99 WRX STi V5
^ sorry for going a little off topic here, but RE: strenth, it will be interesting to see how Subarus new Diesel block is. This could possibly be the new block to build an engine from considering the cylinder pressures etc produced within a diesel engine. Of course assuming the gas cylinder heads etc all mate up.
Old 10-31-2006, 02:31 PM   #7
im sure the block will be iron
