IWSTI.com: Subaru STI Forum
Go Back   IWSTI.com: Subaru STI Forum > STi Technical Discussion > Engine, Power, & Performance > Built Motor Discussion
View Poll Results: which would you chose??
crower stroker kit econo 0 0%
crower stroker kit pro 4 16.00%
gruppe-s 650 block 9 36.00%
other 12 48.00%
Voters: 25. You may not vote on this poll
Old 07-28-2006, 08:54 AM   #16
Car: 08 Z06 Corvette
Fav Mod: Jack Jack
Do you have any links to info on the stroker kit? Personally, I would be all over the Cobb replacement block, as I might be if my engine pops. Given that I play in the ~380-400 rwhp circle, I cannot operate without being ready to buy a new shortblock.
RainMaker is offline   Reply With Quote
Old 07-28-2006, 09:07 AM   #17
Poor Speed Racer
Car: 96 328
There are a few people making HUGE power out of the 2.5L. Phil at element tuning has a 2.5L making nearly 600hp!!!! and its 80% stock (pistons are the big change).
I would just looking into what you really want to do. there may be no need for a stroker.
Old 07-28-2006, 11:26 PM   #18
Car: '99 M3/'03 WRX Avant
Fav Mod: Modification is wrong!
Originally Posted by WolfPlayer
Personally, I would just get a Cobb Tuner series shortblock for $2300 (no core trade required!). Our motors are incredibly stout except for the pistons. The stock crank and rods are forged. Honestly, we just need to replace the pistons and have the motor assembled correctly by top notch people. The Cobb Tuner series shortblock meets that. Plus, you get to keep your original block.
t
Yes, bearings, pistons, and clearances are part of the key. Might as well do the rods while you are there to get a better rod ratio and deck clearance all while keeping the same static compression. It'll maximise the effect of the chamber matched pistons.
Given Cobb's rods, pistons, and bearings, tuners are getting 40wtq more with less timing given the better volumetric efficiency with the same tune otherwise.
Once again, if the motor is apart...why not do head work. Heads alone make a large difference on the EJs. Cams...don't get me started. I can wait for heads and cams. Even a stage I port of the heads is easily worth the cash if you can spare it, IMO.
PS. if you're going to do head porting, make sure someone who knows what they are doing does the port. You can really mess with a motors flow if the intake and exhaust flow are not properly matched.
STirish is offline   Reply With Quote
Old 08-15-2006, 04:53 AM   #19
Car: 05 Crystal Grey
Fav Mod: AMR BIG MAF
Originally Posted by Mykl
I think it'd be pretty cool to get a nice, round 3.0. But I'm not entirely sure how realistic that is.
It is very nice that we have so many options though. Hopefully they'll all be around in four years when I'm ready for a better bottom end.
Yea they definitely are building there own motors. Went by there a couple days ago after I saw the website. I gotta start saving some cash.
SubySat is offline   Reply With Quote
