IWSTI.com: Subaru STI Forum
Go Back   IWSTI.com: Subaru STI Forum > STi Technical Discussion > Engine, Power, & Performance > Built Motor Discussion
Old 06-06-2006, 08:19 PM   #1
Car: 06 WRB STI, 04 SVT L
Fav Mod: Forced Induction
Send a message via Yahoo to lightningdriver
Default cosworth cams
Is anyone here running cosworth cams or any aftermarket cams with avcs for that matter, I need to order some in the next few days and wanted to hear from sti owners using them ,
,thanks, andrew
lightningdriver is offline   Reply With Quote
Old 06-07-2006, 06:59 AM   #2
Car: 05 Sti
Fav Mod: AP Racing Brakes
Running a set of HKS cams on a 05Sti. It is HKS's valcon V-cam kit which links into the V-Pro ECU.
Blatman is offline   Reply With Quote
Old 06-07-2006, 07:05 AM   #3
Car: 05 STI
Fav Mod: DPR cams
running dpr stage 2 cams. seen about 60 whp gain with port and polish ecutek reflash. with stock turbo.
chile is offline   Reply With Quote
Old 06-09-2006, 09:28 AM   #4
Default cams
do you know the lift #'s and durations on your cams, also the cost.
Old 06-09-2006, 09:42 AM   #5
Car: 04 Subaru STi
Fav Mod: AMR Pro-Street block, Cosworth Cams, Race heads, BIG turbo!!
I have Cosworth Stage 1 cams in my car. Here is the technical information from Cosworth's website. You can get these cams for $949 from Automaster of Westchester. I have these cams in my car, and the car is an animal on the street. Here is my build up thread:
04 STI 11.39@130mph
From Cosworth's Website:
Cosworth, Inc. Torrance California. USA
310 534 1390
cosincsales@cosworth.com
PERFORMANCE CAMSHAFT DATA
Manufacturer Subaru
Model WRX STI
Engine Type EJ25 AVCS
Cosworth Part Number KK3766
Checking Height .010"
Intake Exhaust
Valve Clearance .008" .010"
Peak Cam Lift 10.9mm 10.28MM
Rocker Ratio 1 1
Peak Valve Lift 10.71mm 10.03mm
Centerline 107deg. 113deg.
Open 29.5BTDC 70.9BBDC
Close 69.3ABDC 23.4ATDC
Degrees Duration 278 274
Special Notes:
For WRX EJ25 solid tappet With AVCS (North America)
Complete set of 4 cams
Strong mid to high RPM performance
Works well with bigger turbo
Notice: Performance camshafts may require improved valve train for proper operation.
Always check for spring coil bind. Cam followers should be in good condition or replaced
with new parts. Follow proper break-in procedure for maximum cam life.
For off-road racing use only.
2FastCars is offline   Reply With Quote
Old 06-09-2006, 09:49 AM   #6
thanks for the reply that is the type of info i was looking for i will order them soon that is the only part from my sig that i have not ordered yet. I went with a cobb stage 2 race blcok and stage 3 heads thos so a little different route than you . what is the car now?
Old 06-09-2006, 09:50 AM   #7
do you have any vids of the idle sound or full throttle sound?
Old 06-09-2006, 09:53 AM   #8
520
STi > EVO... Wait what???
Car: 03 EVO
Fav Mod: stock :(
Send a message via AIM to 520
dpr stage II here, will let you know on gains after tune.
idle is a little different but not that noticeable
Old 06-09-2006, 12:00 PM   #9
Car: 04 Subaru STi
I have the car right now, but I'm dropping it off at Automaster today for it's final tune next week. I do not have any vids as of yet, but when I get back I will surely do a nice vid. At idle, you can hardly tell I have cams.....the idle is rock solid. At full throttle, you can hardly hear yourself over the whine of the turbo and the wastegate and blowoff valve going off.
Old 06-09-2006, 12:20 PM   #10
STI Guru
Car: 2001 Honda Accord EX
Fav Mod: STickers
Send a message via AIM to 305STi Send a message via MSN to 305STi Send a message via Yahoo to 305STi
Damn! lightningdriver you have all those cars and you are still dropping in 20K+ into your STi.
305STi is offline   Reply With Quote
Old 06-09-2006, 08:05 PM   #11
GT R US
jeremy just installed a set of custom ground kelford acvs cams:
lift: .413
duration: 232
lobe separation: 113 degrees
