Old 01-08-2007, 12:24 AM   #16
Fav Mod: Starving my STI
Trader Rating: (13)
Originally Posted by BruceChapman
i read the same thread. i've done enough investigating to be comfortable with my decision. those sinc issues turned out to be installation issues and and not a quality control problem. phil was very involved in the thread and i'll be trailering it down to him for tuning when it's finished.
pitcherman, you mean 1000cc injectors will negatively impact fuel economy?
So all else being equal, did the 1000CC injectors negatively affect fuel economy?
Old 01-08-2007, 12:26 AM   #17
Trader Rating: (13)
good question, sniper. the 816's are cutting it at the current power level but they are running out of room at phil's current power level (i think about 545 whp) and i expect to easily exceed that. phil does not like pe 850's particularly and has already installed rc 1000's on the element time attack with good results. i follow him. he's also experimenting with larger turbos and who knows what i'll be swapping onto my rotated setup as we move forward.
What about it doesn't he like? I can't decide whether I should go with PE850, Nismo 740, that "Deutch 750" brand , or the Perrin Modifieds (I'm not too thrilled with some of Perrin's products, so I'm a little scared with going that route like you did previously).
Old 01-08-2007, 12:27 AM   #18
Trader Rating: (13)
Old 01-08-2007, 04:58 AM   #19
GT R US
he doesn't like tuning them. the best thing is to discuss your upgrade plan with your tuner before ordering injectors. if you have confidence in your tuner, it doesn't matter what anyone else thinks.
btw, the dpr cams were returned after 3 efforts by dpr to get them right. if you are familiar with my current situation, you know that one of my kelford avcs exhaust cams was incorrectly ground and has to be replaced. this past entire years racing effort has been a waste of time. when it comes to aftermarket cams, trust no one .
Old 01-08-2007, 05:07 AM   #20
Trader Rating: (13)
We run and have many customers running 1000cc low imp injectors with the Hydra and they will happily run at 14.7 during cruise (if the car will). You will not use any more fuel with the 1000cc injectors as the Hydra has the pulse width resolution to tune them correctly. Go for it!
Thanks,
Phil
www.elementtuning.como
I just read the above after going through countless threads on the topic... based on that, it looks like RC1000 cc are the way to go... even with my minimal mods... so I'll be ready for the GT65 in the fall or late summer...
I am my own tuner so it makes things both more challenging but also more rewarding in the end... I have to research and learn everything myself... which is a lot on an STI if you want to do it right.
Old 01-08-2007, 05:39 AM   #21
Car: 2003 Z06
Good luck with this man. I hope to see this all come together for ya
jgheels2003 is offline   Reply With Quote
