Go Back   IWSTI.com: Subaru WRX STI Forums > IWSTI Engine & Drivetrain > Built Motor Discussion
Old 10-07-2008, 06:15 PM   #1
Car: silver 07 sti
Fav Mod: blitz nur spec r
IWSTI Addict since: Feb 2008
Default Cams with stock turbo and cp pistons
I have an 07 sti and they have buggy pistons so I am already going to upgrade my pistons to cp forged pistons.
I will have pretty much everything you can do to the car without getting a different turbo
perrin fmic with thermal dispersant coating
perrin blow through maf tube
aps 70mm cai
gruppe s manifold with coating
ultimate racing uppipe with 44mm tial ewg
agency power inlet pipe
850cc injectors
agency power fuel rail
walborow fuel pump
invidia catless bellmouth dp
blitz nur spec r catback
cobb ap
after a while i plan to upgrade to a stock mount gt3071r hopefully or go to a perrin rotated mount turbo..
but for now im going to throw in the forged pistons and i want to put in cams that will work with the stock turbo well and also function with great with a gt30
i want cams with avcs and i'm looking for a pretty good idle
basically i want cams that will work great with the stock heads and later on work great with a gt30
what cams do you recommend and what duration?
aminorthreat99 is online now   Reply With Quote
Old 10-08-2008, 01:07 AM   #2
Car: silver 07 sti
Default Re: Cams with stock turbo and cp pistons
anybody have any advice?
Old 10-08-2008, 11:00 AM   #3
Car: silver 07 sti
please help!!!
Old 10-08-2008, 02:25 PM   #4
Fav Mod: 4th gear wheelspin
IWSTI Addict since: Nov 2004
Well you may be disappointed with cams + the stock turbo, but indeed now is the time to do it if your motor is apart.
I have cosworth 278/274 avcs cams in my STI and am happy with them. My idle isn't perfect but I believe that is more of a tune issue than an issue with the cams themselves. If I could do it again I would go with GSC cams since the GSC stg 2 cams have made more power across the board than the cosworth cams in back to back tests. The BC cams are hot now too.
Keep in mind that you need to replace more than just the cams. Also valvesprings, retainers, and a lot of valve buckets. Even if you have the valvestems ground down you will probably need a couple new buckets to get the lash correct.
If the cams do their job correctly you could end up needing a bigger fuel system too.
Old 10-08-2008, 04:37 PM   #5
Car: silver 07 sti
I have doing a bigger fuel system.. i listed all the parts above.
i'm pretty much doing everything i can with stock turbo for now.
so you saying gsc stg2 cams will be good with a protune on the stock turbo and with a gt30 they will function pretty swell also?
Old 10-09-2008, 12:34 PM   #6
Car: Never enough Subies
Fav Mod: Breast prints on hood !
IWSTI Addict since: Mar 2008
We can build your heads custom with stainless valves and stage 1 torque grind on your cams for around $2,000. 3 angle seat cut, and some minor casting cleaning up, not porting.
Jon @ Custom Import Heads subdivision of Delta Cam
DELTA CAM is offline   Reply With Quote
Old 10-12-2008, 03:50 PM   #7
BAMFkr
Fav Mod: Longblock
IWSTI Addict since: Jan 2008
Send a message via AIM to BANKAI Send a message via Yahoo to BANKAI
i have the bc 272 and they idle like crap...from my 1st tuner..2nd tuner made magic! so it's up to u! and yes top end with a gt30 is nice!
BANKAI is offline   Reply With Quote
