Go Back   IWSTI.com: Subaru WRX STI Forums > IWSTI Engine & Drivetrain > Built Motor Discussion
Old 08-04-2008, 03:10 AM   #1
Car: 04 sti/ 06 M3
IWSTI Addict since: Sep 2007
Default motor built and need to know what weight oil..
I am finishing up my ej25 motor with just forged pistons and rods with a .05 overbore so its 100mm insted of 99.5.... I am using a stock headgasket and basicaly every thing else is stock.... I am just woundering what type and weight of oil will I have to use now????Thanks...
acivichb is offline   Reply With Quote
Old 08-04-2008, 09:40 AM   #2
IWSTI Addict since: Apr 2004
Default Re: motor built and need to know what weight oil..
The fact that you swapped pistons and rods doesn't change anything. If you'd played with bearing clearances, then yeah, it'd matter. I'd stick in some 5w30 or 10w-30 dino oil for the break-in, change it a few times until the car has the final tune on it, and then switch over to a synthetic. As for brands, it's your choice - if you change your oil frequently (which you should) any of the major brands will do the job. It's just my opinion, but I think some guys get way too anal about this stuff.
Old 08-04-2008, 09:56 AM   #3
OpenSourcerer
Fav Mod: ECU
IWSTI Addict since: Apr 2007
I use Shell Rotella-T 5w40 for my dropin piston motor. But its hot in Texas.
Old 08-04-2008, 05:51 PM   #4
Car: 04 sti/ 06 M3
ok thanks you guys well I did not do anything to the bearings except put acl race bearings but I believe that they dont change anything.... Well I live in Hawaii its really hot and humid here also... Thanks you guys...
« Cams | Need Help »
