Go Back   IWSTI.com: Subaru WRX STI Forums > IWSTI Engine & Drivetrain > Built Motor Discussion
Old 05-27-2008, 09:10 AM   #16
Car: 07 OBP
IWSTI Addict since: Aug 2007
Send a message via AIM to The Black Beauty
Default Re: Gt65 Build
Originally Posted by mllrsti View Post
The build looks VERY solid for your setup. You don't necessarily need to do any work to the heads, your motor is going to flow really well. But if you have an extra grand or so laying around collecting dust I would at least get a mild port/polish. I would also suggest replacing your OEM intake and exhaust valves while the motor is apart. Phil Grabow stressed this issue when W1 and Phil were doing my build.
Thanks. what valves would you recommend? going to call garret and talk about this today.
The Black Beauty is offline   Reply With Quote
Old 05-27-2008, 09:13 AM   #17
Car: 07 OBP
Originally Posted by gabedude View Post
Do the headwork. Trust me. My motor has to pulled again for headwork now. The same cylinder that went toasted a valve as well.
Ya im starting to lean towards getting a mild p&p. this is starting to get way to expensive!
Old 05-27-2008, 09:16 AM   #18
Car: 07 OBP
MY stupid computer (double post)
Old 05-27-2008, 09:19 AM   #19
Car: 2008 STI
IWSTI Addict since: May 2008
Trader Rating: (12)
Send a message via AIM to FlyingPerformance
Call up Ron at Raw Performance(used to be Axis). Home
He is the man to talk to about anything engine related. He does amazing work. One of the only people I trust with motors and heads.
FlyingPerformance is offline   Reply With Quote
Old 05-27-2008, 12:57 PM   #20
IWSTI Addict since: Dec 2004
Yes call Garret. Great guy and the entire team including Phil G. are top notch. We went with Crower intake and exhaust valves. Tell Garret you spoke to Matt M..
mllrsti is offline   Reply With Quote
Old 05-30-2008, 07:50 PM   #21
Car: 05 CGM STI
Fav Mod: Element Tuning
IWSTI Addict since: Nov 2004
This would almost be identical to my setup. Built bottom end, stock heads with cams, but i have the element gt75 kit which makes no more power then the 65 without head work. You will be very happy with this setup, on pump and meth i made 492 whp and on race gas and meth i made 546 whp on a dynojet. The race map has gone 10.83 @ 131 mph with room for improvement.
Md05STI is offline   Reply With Quote
Old 05-30-2008, 08:27 PM   #22
GT R US
IWSTI Addict since: Dec 2003
This is my engine:
-Cosworth Pistons
-Cosworth Rods
-ARP head studs
-CP Ring Set
-Greddy Timing Belt
-Cosworth Head Gaskets
-High Performance Rod Bearing
-High Performance Main Bearing
-Cosworth Cams
-Cosworth Springs and Retainers
-Aermotive external fuel pump with 1150cc DW injectors
I am going to be running a big rotated turbo setup. (Element Gt65 kit) I will be around 500whp give or take on pump+meth. Just wondering everyone's thoughts on my setup, and how solid it is? I am debating getting the heads done, but my engine builder says they dont usually do the heads on a street car. By street car I mean canyon runs often, and many track days, but I have a daily driver. Is my engine ok without heads? By keeping the heads stock am I making the turbo work harder?
no. you are just not taking full advantage of it at the top end.
My car will be used on the street as well as the track. Going to try and hit the track up 2 times a month, but I drive through the canyons often and around the street when I feel the urge. If my engine is perfectly fine and doesn't need headwork then but if its just stupid to have all this done and not even a mild p&p then I wouldnt mind dishing out the extra cash. Just wondering if the stock heads with this kind of setup is detrimental.
not at all. it's easy to get macho with headwork if you have the cash but it's really stupid. extensive headwork can kill the fun factor in a street car.
your current plan is solid but, if you really don't mind spending the money, you can bring out the full potential of what youve invested in your bottom end and that gt65 kit with some modest additional work. consider it a crime of opportunity. you are already doing doing arp studs and the springs and retainers, which is the absolute minimum you should do.
- do a stage 1 p&p while you have the heads off. you don't need valves. you don't need cams but, once again, if you have the money and the heads are off you may want to consider a nice set of stg 2 or 3 avcs cams.
- if you are adding the a1000, you might as well do it right and add a 2 liter surge tank with it in the trunk. you can get one directly from element. also consider the aeromotive fuel pump controller; it's not necessary but it makes the pump less noisy at idle and low rpms. phil can give you the parts list for the fuel system. it'll cost about a grand but it'll be worth it. you can turn the car upside down and you'll never run out of fuel. i am not sure you need 1150 cc injectors. 1000 cc sounds right to me.
- you don't mention em but with what youre doing you should consider hydra.
- loose the cosworth head gaskets and do the oem gaskets. phil just had them on his most recent motor and ended up loosing a head gasket at 150mph then hydrolocking and completely destroying his motor.
Old 05-30-2008, 08:35 PM   #23
Car: 2008 STI
Trader Rating: (12)
He is already doing Cosworth cams along with the springs.
Old 05-30-2008, 08:48 PM   #24
GT R US
so he is...proof positive of human fallibility.
Last edited by Neanderthal Racing; 06-01-2008 at 12:51 PM. Reason: abuse of my beloved english language
Old 05-31-2008, 04:55 PM   #25
Car: 07 OBP
Neanderthal- I'm going to be running Hydra em + Hydramist.
Have other people had problems with the cosworth Head gaskets?
Old 05-31-2008, 05:19 PM   #26
GT R US
Neanderthal-
great. you'll loved it.
i don't have the answer to that question but, i personally see no need to change from the oem gaskets.
Old 05-31-2008, 09:32 PM   #27
Car: 2008 STI
Trader Rating: (12)
Who makes the Cosworth gaskets? Are they cometic or is it another manufacturer? The only head gasket problems I have ever heard of where with the cometic's blowing due to high boost. The OEM gaskets seem to handle the high boost just fine.
Old 06-01-2008, 10:53 AM   #28
Car: 07 OBP
Cosworth makes the head gaskets, dont they? im debating just using the stock head gaskets..
Old 06-01-2008, 12:41 PM   #29
Use new OEM head gaskets. They work GREAT.
Old 06-02-2008, 11:00 AM   #30
Car: 05 CGM STI
Agree! Mine see 30+ psi on a regular basis with no issue so far.
