Old 04-14-2008, 04:57 PM   #1
Car: 2006 black sti
Fav Mod: ecutek
Default another cam Q
o.k. heres the list
2006 sti
1. perrin gt30r .82
2. aps dr725
3. pe850's
4. aps fuel rails
5. adj. fuel pressure reg.
6. hks evc v
7. ecutek
8. exedy twin plate
9. wiesco pistons - coated, all new bearings - coated
10. egale rods
11. ti retainers, stiffer valve spring, 5 angle valve job
12. tvg deletes
13. all balanced
14. CAMS, ????????
now, my tuner wanted to set me up with a gt30r .63, with 278/274 cosworths. i said no way to the .63, and got the .82.
now the cams, i still think 278/274 are to big for the gt30r .82
this car is only my fun car, canyons, freeway runs, little drags, dirt, autoX (fo fun), all around. what do you think i need 264/264, no cams, what?
thanks
FizzyMilk is offline   Reply With Quote
Old 04-14-2008, 05:01 PM   #2
Car: 06 STI, 08 GSXR 750
Fav Mod: WC Lathe Werks Shift Knob
Default Re: another cam Q
I have no personal experience but my gut feeling is that those cams are too big for a 30r. Stock cams are probably all you need for a 30r but there's gotta be power to be made running the 264's.
Hitman83 is offline   Reply With Quote
Old 04-14-2008, 06:36 PM   #3
Car: 2006 black sti
Fav Mod: ecutek
word, and i want to make power past 7k not drop at 6800
Old 04-16-2008, 04:06 AM   #4
Car: 2006 black sti
Fav Mod: ecutek
bump it up
Old 04-16-2008, 04:29 AM   #5
Car: Your STi ;)
Fav Mod: Everything
I support your tuner on the .63 and suggest the GSC cams. We did make a few other changes, but going from the Cosworths to the GSC's opened our power curve in both directions (under boost theshold and over 6k rpm)
Siegel
Old 04-16-2008, 05:06 PM   #6
Car: 2006 black sti
Fav Mod: ecutek
ill look at the gsc's but what size?
