Old 04-01-2008, 03:01 AM   #1
Car: silver 04 sti
Default built ej22T with version 7spec-c head
i have been trying to figure out which shortblock built ej22T( coated pistons, i beam rods, 79mm standard sti crank,bearings) or built ej257(coated piston , sleeved,i beam rod 79mm sti standard crank,bearings)
I already have jdm spec-c heads with kelford cams 274/272 10.4/10.2,dual vavletrain kit with crawford performance cp35r turbo kit .82 a/r with dr725 I/C
i will be usung the car for weekend drag race,with 96 octane rev 9000rpm final CR 8.1.1 with 28 psi looking to make 550-600
i know that ej22T will work out cheaper option but will it meet my goals,or i should do ej257 i dont wont low end torque im really want topend power with
rev limit 9000rpm
help me out here guys
shaz1980 is offline   Reply With Quote
