Old 02-19-2008, 05:40 PM   #1
OpenSourcerer
Fav Mod: ECU
Default My build
After the teardown, I found #1 had a cracked ringland, no signs of terrible DET on the bearings, but I did lean missfire (tehcnically pre-ignition due to running out of injector and going lean) it at 3k or so 3-4 times reproducing an issue. Anyway after 11.5K miles worth of experimenting and hard tuning, here are the results. #1 ringland went. From my logs, there was some odd fueling stuff going on when it went, so I am upgrading to DW 750's and will have my old injectors tested (especially #1).
So I already have the info I need on nasioc, and will be posting pics of my build up here. I saved the bores so its gonna be a hone and a call to CP pistons after mic-ing out the bores. Here are some pics:
The broken one (casting defect)?:
The bores are still good!
Hopefully the CP pistons will hold up to the 20G and meth for a good while.
The build will start soon.
Old 02-20-2008, 01:35 PM   #2
Car: 2006 WRX Wagon DOM3
Fav Mod: Dom3
Default Re: My build
Damn Gabe, I didn't know it broke. First Braden and now you.
06rexwagon is offline   Reply With Quote
Old 02-20-2008, 01:41 PM   #3
Car: 05 Aspen White STI
Fav Mod: Defi Gauges
Send a message via AIM to STI_Mike
ouch sorry to hear!
STI_Mike is offline   Reply With Quote
Old 02-20-2008, 03:44 PM   #4
OpenSourcerer
Fav Mod: ECU
I foudn some debris in my oil pump pickup. Looks like paper towel. :/
I will post pics tonight of everything. Including the rod bearings which are mint.
Old 02-20-2008, 10:15 PM   #5
Fav Mod: Tires and Brakes!
Ouch, but at least your looking at the bright side of things. Doing anything else besides pistons?
I quit lurking around that other forum because of its requirement to have a low IQ, your better off here
gosu is offline   Reply With Quote
Old 02-20-2008, 10:20 PM   #6
Fav Mod: Custom built TBE FTW!!!
Send a message via AIM to CenCali07STI
paper towel huh? that cant be any good no matter what it is.
CenCali07STI is offline   Reply With Quote
Old 02-21-2008, 06:17 AM   #7
OpenSourcerer
Fav Mod: ECU
Yeah it was a piece of paper towel. I guess I was so paranoid about checking my oil, I got some in there one time. It was not enough to block any oil from getting top the heads though.
Old 02-27-2008, 05:06 PM   #8
Car: 07 UGM STi
Fav Mod: Gabe's stage 1 flash
Send a message via AIM to SubieDave
Welcome to the good side Gabe!
Looking forward to seeing where you go with this. Good luck.
SubieDave is offline   Reply With Quote
Old 03-02-2008, 07:40 AM   #9
OpenSourcerer
Fav Mod: ECU
Ok Got her torn down!
These bearings are all AOK! Time to just clean her up, replace the gaskets, put the two rods back on, and sew her back up with some CP pistons.
Old 03-02-2008, 07:47 AM   #10
Fav Mod: CAR LIFT & Protune!
nice GL man!
Old 03-03-2008, 12:54 PM   #11
Car: 2007 STI SWP
Fav Mod: Whiteline Sways + RCE Blacks = :)
Send a message via AIM to jordanretro1223
Except for the 2 or 3 pistons that are cracked everything looks practically brand new.
jordanretro1223 is offline   Reply With Quote
Old 03-03-2008, 04:50 PM   #12
Car: 07 UGM STi
Just the CP pistons Gabe? Ya going to do any other upgraded parts while it's open?
Old 03-04-2008, 05:50 AM   #13
OpenSourcerer
Fav Mod: ECU
Only #3 had the bad crack. The others are just hairline cracks and they are on the driver side which gets less fuel. #3 cracked the ringland on the passenger side, mainly due to the casting defect, but #1 is pristine. I will get a flow report when I send my stock injectors in (already ordered upgraded injectors).
I am sure they will be off by a good margin, but some of the abuse was my own doing. I ragged the snot out of the car, made one map for like 2 weeks that would only pull .35 degrees (Stock is 1.4, 06 STI is 2.0) per knock event.
Old 03-04-2008, 05:53 AM   #14
OpenSourcerer
Fav Mod: ECU
I thought about it (did much research and my own inspection), but unless I am going to ductile iron sleeve it, I am just not gonna spend the $$$. With just pistons, the block will be fine. I am only going TD05H 20G 8CM^2 + Meth. Plus I am just gonna take it easy on her now. Gonna set the Meth up with a switch that turns boost on + Meth, Otherwise, I will just drive around on WG boost.
However, I do see myself having that button on most of the time.
Old 03-04-2008, 06:00 PM   #15
have a big question fo all u sti owners i have a 06 im planing on getting a built block from axis also planning on puting a gt35 turbo set-up on it aswell do u all think that the heads will handle the power and what about the trany thank you all for ur opinions every comment counts.
GreekSTI is offline   Reply With Quote
