Old 03-05-2008, 06:07 AM   #16
OpenSourcerer
Fav Mod: ECU
Default Re: My build
Depends on the block. The Stage 2 block should be able to handle it just fine as long as it is tuned conservatively. If you end up tracking it alot, then it will finally spin a rod bearing or crank bearing instead of a ringland failure (or just blow out the cylinder wall).
Oh and the tranny will be fine. Your clutch will not last though.
Old 03-05-2008, 06:13 AM   #17
Car: 06 White/Gold
With a GT35R setup, you will want to do valve springs so you can rev the motor a little bit higher. If you step up to the Axis stage 3 it comes with a cross drilled crank and some other good things. The cross drilled crank helps oiling at high rpm. The trans will be fine, but like gabe said, the clutch wont last.
rjacobs is offline   Reply With Quote
Old 03-05-2008, 06:14 AM   #18
OpenSourcerer
Fav Mod: ECU
I has 08 STI intercooler (and steak dinner)! I traded my 07 intercooler + tune I did on an 04 WRX wagon (the windshield washer tank is in the way, the 08 STI IC only fits 06+ cars).
Man that thing is huge compared to the 07 IC. I need my STI logo on it though.
