Old 12-28-2007, 02:08 PM   #1
Default Pauter or Manely rods
Did a search didnt find anything on them. Which would you use for an engine build?
GL4662 is offline   Reply With Quote
Old 12-28-2007, 02:15 PM   #2
Fav Mod: CP35r 440whp
Default Re: Pauter or Manely rods
pauter. period.
they are some of the absolute best rods for our subaru's. Don't even think twice if you "have" to have rod's.
Old 12-28-2007, 02:19 PM   #3
that's what I trhought. Because I know axis uses them but top speed uses manely so, maybe I can specifiy to use pauters.
Old 12-28-2007, 02:21 PM   #4
Crawford also uses Pauters......they are a good rod.
pretty much bomb proof...
Old 12-28-2007, 02:29 PM   #5
Car: 07 sti
Fav Mod: whats a mod?
which manleys? the regular ones arent anything special, but the turbo tuff ones are as good or better than pauters in my opinion.
Old 12-28-2007, 02:31 PM   #6
Manly can make some good stuff.
Note that I didn't say anything bad about them. The OP was asking for opinons
I know the motor you have, has manley's.
Old 12-28-2007, 02:34 PM   #7
Car: 07 sti
it does? im not even sure. i know its either the h beam manleys or eagles. i tried sneaking a peek in there and couldnt see a logo. i would guess eagles based on the vein down the open end of the beam. i thought that was an eagle thing?
Old 12-28-2007, 02:36 PM   #8
Last I heard, ARFab was using Manley's. I didn't think they like eagles at all
I'd bet you have Manley's
Old 12-28-2007, 02:39 PM   #9
Car: 07 sti
i checked an old email i had from them and they use eagles, but manleys are a no cost option. i bet they are forged in the same chinese plant anyways!
Old 12-28-2007, 02:41 PM   #10
FWIW, a quick look on their website:
Subaru Pricing
This Service package includes:
  • Teardown of the Customers' Short Block and Inspection
  • Custom forged Arias Pistons 9.5:1 Compression Ratio with Modified Compression Height
  • Manley Forged 4340 H-Beam Rods
  • Competition Race Bearings
  • Inspection, Balance and Polish Crankshaft
  • Bore and Hone with Billet Deck Plates
  • Blueprint, Clearance and Assembly
Old 12-28-2007, 02:54 PM   #11
Car: 07 sti
Subaru Pricing
i guess i can call them and ask. i need to get their opinion on a turbo anyways.
Old 12-28-2007, 03:12 PM   #12
Im sure you have a build number and whatnot that you can call and ask. I'm surprised you didn't get a sheet.
Old 12-28-2007, 03:16 PM   #13
Car: 07 sti
i have a spec sheet with the bearing and piston clearances, but nothing about the piston dish, deck clearance or parts used. im guessing at .0045" piston to wall clearance, its going to be a rattler when its cold!
Old 12-28-2007, 03:43 PM   #14
... im guessing at .0045" piston to wall clearance, its going to be a rattler when its cold!
and burn a bit of oil.....
Old 02-28-2008, 06:46 PM   #15
Fav Mod: Custom tuning by Ed @ EQ Tuning
When I first started talking to AR Fab about my motor Howard stressed that he never uses Eagles. He also made it a point that the Manley H-beams are made in the USA. Eagle, Scat, Crower econo billets are all made at the same plant in China.
Back on topic, my next motor will have Pauters. Pauters all the way, best design out there! I'm also using them in my best friends 2.0 LS/VTEC GT40R setup.
BM_STi is offline   Reply With Quote
