Old 11-12-2007, 04:10 PM   #1
Car: 05 sti
Fav Mod: APS tsr70
Default Cams on an STI with stock heads ; Thoughts and Perspectives?
Does anyone have eny experience with cams on stock sti heads? I'm considering purchasing a cosworth head package, but in the event the heads remain stock, I was wondering if anyone had real world perspectives to share.
For context; the car is an 05 sti with 20K miles, with previously an UR GT35, Hydra, and other relevant mods. The 05 motor will be coming out in 2 weeks (bad rings from detonation with the gt35) for an 07 sti motor with 1200 miles including trans and drivetrain (tired of the short 3rd and 4th in the 05). I was planning on building the block, but with numerous horror stories, I would prefer to keep it stock at this time. More than likely, I'll install a full race header, gt52, and Hydra 2.6 once the motor is swapped (end of november)
having said that any thoughts or experiences with a stock STI heads and cams; and if so which cams? I was considering the cosworth 262? or 274?.
Thanks in advance.
syoung298 is offline   Reply With Quote
Old 11-12-2007, 04:19 PM   #2
Default Re: Cams on an STI with stock heads ; Thoughts and Perspectives?
If you're going to push it hard enough to use the cams, you really ought to at least put in a set of forged pistons while you have the motor out. As for the rest, I'll leave it to others who've done it. Go forged, amigo, and mitigate the risk of breaking a piston.
Old 11-12-2007, 06:30 PM   #3
I hope you're not considering using the stock valvetrain. BTW, Cosworth has 278/274 AVCS cams available. The price/power ratio for their head package to me isn't the best bang for the buck, the turbo you use has a lot to do with it.
mllrsti is offline   Reply With Quote
Old 11-12-2007, 06:38 PM   #4
Car: 05 sti
Fav Mod: APS tsr70
The more I think about it; the more I'm leaning towards a stock shortblock with cosworth heads and cams.. Since i don't plan on exceeding 400whp, I hope this won't be an issue. My primary concern is reliability, and I'm not completely convinced that any aftermarket engine builder can gaurantee a motor that is as reliable, albeit more sout, than a stock Subaru shortblock.. perhaps axis or cosworth...
Old 11-12-2007, 07:51 PM   #5
Fav Mod: when it's not blown up
A $5k head/cam package on a $1500 shortblock with 400whp goals just does not make sense.
Other than that... Flycaster said everything!
Old 11-12-2007, 10:42 PM   #6
Car: 05 STI
Fav Mod: GT30R
I dont think that's a very good idea at all.. The stock heads/cams are plenty for 400whp, the weak link is the pistons.. If i were you i would drop in some forged pistons and call it a day, hell i've been running my 30R @ 22psi for 17K miles now on the stock longblock without any issues, and im making a bit under 400whp so if you want reliability then forged pistons is the way to go.. I dunno why you are so worried about the heads if you dont plan on exceeding 400whp, people have pushed 500+whp out of the stock heads/cams and they flow fine..
STimo is offline   Reply With Quote
Old 11-13-2007, 12:05 AM   #7
Car: 05 STI, 08 CBR1000RR
Fav Mod: None
^ This right here pretty much says it all. Why mess with head work when the STI weak link is pistons and rings. Plus I hope you get a better tune or have learned what caused the first motor to take a dump on you. Going with a smaller turbo and sticking around the 400whp mark doesn't guarantee that you'll be reliable. In fact your more liable to be doing this all over again in the near future at the 400whp mark. There have been plenty of STIs that have gone tits up with the stock turbo and a bad protune. It doesn't take much to destroy an engine.
Old 11-13-2007, 07:05 AM   #8
Car: '08 335xi Coupe
Fav Mod: Dinan Reflash
What he means is, a bad tune on an otherwise stock car will grenade an engine.
As for building up an engine, the most important part of engine building is making sure all the parts match each other. If you run a GT35R with a cosworth head and cam package on a stock long block you are asking for trouble. The reason is that the stock pistons and rings were designed to last 150,000 miles at stock 220-240 whp range. When you slap on racing heads, racing cams and a huge turbo you are going to be making close to double this amount of power. All this extra air and fuel create cylinder pressures that the stock bottom end is simply not equipped to deal with. If you are going through the hassle of rebuilding the engine, do it right the first time and put in a forged rotating assembly. Otherwise you are likely to pop this new engine in short order and be back at the drawing board.
Old 11-13-2007, 07:21 AM   #9
Originally Posted by Tortfeasor STi View Post
...do it right the first time and put in a forged rotating assembly...
And, the only parts not forged in the stock rotating assembly are the pistons.
Old 03-02-2008, 06:15 PM   #10
Support Our Sponsors
i recommend upgrading your valve springs and retainers if you have the heads off and get the opportunity. also, it's very manly to do a lot of headwork until you realize what that dramatic shift to the right will do for your fun factor on the street.
Old 04-21-2008, 05:24 PM   #11
Fav Mod: Junior Tuned
Send a message via AIM to boostedrex05
buy a cosworth block for 5400 and call it a day.. maybe up grade the valve springs retainers and cam's
boostedrex05 is offline   Reply With Quote
Old 05-02-2008, 10:01 AM   #12
Car: 07 OBP STi
Fav Mod: All
Basically the only benefits of the Cosworth Heads and Cams are if you are looking for more TOP End Horsepower. The Intake Valves flow 15% more and Exhaust Valves flow 31% more than stock which allows more fuel and air for High Horsepower applications.
subydude1974 is offline   Reply With Quote
Old 05-02-2008, 10:16 AM   #13
Car: 08 STI,sr20det 510
Fav Mod: boob job for wife
Tomei has some cams tuned for the jdm big port heads (07 08 ports are bigger than prior years) with no porting. If I were you I would do a cobb short block with the forged pistons and the tomei 252 cams.
Old 05-06-2008, 10:20 PM   #14
Car: 05 CGM STI
Fav Mod: Element Tuning
I have completely stock heads with Kelford 274's and have had no issues at all. The car made just shy of 550whp and rev's to 8k. To make use of the cams I'd say you would need a built bottom end like others have already said.
Md05STI is offline   Reply With Quote
Old 05-08-2008, 11:20 PM   #15
what kinda dyno did you make shy of 550whp on? I made 512 on a dyno dynamics stock engine stock heads and cam's 0 correction so it's really like 10-20% more from what i herd.
