Go Back   IWSTI.com: Subaru WRX STI Forums > GD Series STi Discussion (2003/4-2007) > GD-Marketplace > Vendor Classifieds > Brakes/Suspensions/Stiffening
View Poll Results: DBA or EBC
DBA ALL THE WAY 18 90.00%
EBC COMON MAN? 2 10.00%
Voters: 20. You may not vote on this poll
Closed Thread
Old 10-10-2007, 07:47 PM   #1
Feedback Score: 3 reviews
IWSTI Addict since: Jul 2007
Smile :) DBA, Brembo, EBC, Hawk, Power Slot, Motul- In Stock
*****BRAKE THREAD******
PM for all "Qoutes & Combos"
*Pads*
EBC
EBC Greenstuff Pads
MODEL#:
DP21661 Front Pads Subaru Impreza - 2.2 Outback (2003 - 2007) DP21687 Rear Pads Subaru Impreza - 2.2 Outback (2003 - 2007)
DP21661 Front Pads Subaru Impreza - 2.5 RS/TS (2003 - 2007)
DP21687 Rear Pads Subaru Impreza - 2.5 RS/TS (2003 - 2007)
EBC Yellowstuff Pads
EBC Yellowstuff (1793 Formula) street, race and track pad delivers world class braking designed for High Horsepower imports and Muscle cars where maximum stopping is prime requirement. Its dust rating is similar to OEM parts.
MODEL#:
DP41210R Front Pads Subaru Impreza - 2.0 Turbo WRX STi (2003 - 2004)
DP41538R Rear Pads Subaru Impreza - 2.0 Turbo WRX STi (2003 - 2004)
DP41210R Front Pads Subaru Impreza - 2.5 STi Turbo (2003 - 2004)
DP41538R Rear Pads Subaru Impreza - 2.5 STi Turbo (2003 - 2004)
DP41661R Front Pads Subaru Impreza - 2.0 Turbo WRX (2003 - 2005)
DP41687R Rear Pads Subaru Impreza - 2.0 Turbo WRX (2003 - 2005)
DP41661R Front Pads Subaru Impreza - 2.2 Outback (2003 - 2007)
DP41687R Rear Pads Subaru Impreza - 2.2 Outback (2003 - 2007)
DP41661R Front Pads Subaru Impreza - 2.5 RS/TS (2003 - 2007)
DP41687R Rear Pads Subaru Impreza - 2.5 RS/TS (2003 - 2007)
EBC Redstuff Pads
EBC Brakes have rebuilt their earlier Redstuff compound with Ceramic particles and other special ingredients to deliver perfection in stopping power for even the fastest street use. Ideal for High Horsepower imports, muscle cars and especially suitable for European high end cars. EBC Redstuff Ceramic pads cut the dust emitted by OEM pads in half, reduce rotor wear and last longer while delivering ultimate brake performance.
MODEL#:
DP31210C Front Pads Subaru Impreza - 2.0 Turbo WRX STi (2003 - 2004)
DP31538C Rear Pads Subaru Impreza - 2.0 Turbo WRX STi (2003 - 2004)
DP31210C Front Pads Subaru Impreza - 2.5 STi Turbo (2003 - 2004)
DP31538C Rear Pads Subaru Impreza - 2.5 STi Turbo (2003 - 2004)
DP31661C Front Pads Subaru Impreza - 2.0 Turbo WRX (2003 - 2005)
DP31687C Rear Pads Subaru Impreza - 2.0 Turbo WRX (2003 - 2005)
DP31661C Front Pads Subaru Impreza - 2.2 Outback (2003 - 2007)
DP31687C Rear Pads Subaru Impreza - 2.2 Outback (2003 - 2007)
DP31661C Front Pads Subaru Impreza - 2.5 RS/TS (2003 - 2007)
DP31687C Rear Pads Subaru Impreza - 2.5 RS/TS (2003 - 2007)
EBC Ultimax Brake Pads
*OEM OR BETTER PADS*
MODEL#:
UD1001 Front Pads Subaru Impreza - 2.0 Turbo WRX STi (2003 - 2004)
UD961 Rear Pads Subaru Impreza - 2.0 Turbo WRX STi (2003 - 2004)
UD1001 Front Pads Subaru Impreza - 2.5 STi Turbo (2003 - 2004)
UD961 Rear Pads Subaru Impreza - 2.5 STi Turbo (2003 - 2004)
UD929 Front Pads Subaru Impreza - 2.0 Turbo WRX (2003 - 2005)
UD1004 Rear Pads Subaru Impreza - 2.0 Turbo WRX (2003 - 2005)
UD929 Front Pads Subaru Impreza - 2.2 Outback (2003 - 2007)
UD1004 Rear Pads Subaru Impreza - 2.2 Outback (2003 - 2007)
UD929 Front Pads Subaru Impreza - 2.5 RS/TS (2003 - 2007)
UD1004 Rear Pads Subaru Impreza - 2.5 RS/TS (2003 - 2007)
*Fluids*
Brembo Sport.EVO 500++ Brake Fluid: $18
Brembo Sport.EVO 500++ is a premium brake fluid that has been specially formulated to meet any ENTHUSIAST needs. For maximum safety and performance Brembo recommends that the fluid should be changed every year.
MODEL#:
BRE04816412EVO Subaru Impreza - 2.2 Outback (2003 - 2007)
BRE04816412EVO Subaru Impreza - 2.5 RS/TS (2003 - 2007) BRE04816412EVO Subaru Impreza - 2.5 STi Turbo (2005 - 2007) BRE04816412EVO Subaru Impreza - 2.5 WRX Turbo (2005 - 2007) BRE04816412EVO Subaru Impreza - 2.0 Turbo WRX (2006 - 2007)
Brembo LCF 600 Plus Brake Fluid: $35
Brembo LCF 600 Plus Brake Fluid has been formulated to provide the highest performance in all racing conditions and has an independently proven low compressibility at high temperatures. Exceeding the requirements of U.S. FMVSS 116 DOT4 specifications, the Brembo fluid also resists boiling at higher temperatures (both wet and dry) over other race fluids. Not suitable for brake systems containing magnesium parts.
MODEL#:
BRE04816411LCF Subaru Impreza - 2.2 Outback (2003 - 2007) BRE04816411LCF Subaru Impreza - 2.5 RS/TS (2003 - 2007)
BRE04816411LCF Subaru Impreza - 2.0 Turbo WRX STi (2003 - 2004) BRE04816411LCF Subaru Impreza - 2.5 STi Turbo (2003 - 2004)
BRE04816411LCF Subaru Impreza - 2.0 Turbo WRX (2003 - 2005)
*Rotors*
DBA ~ Disk Brake Australia
DBA 4000 Series
DBA 4000 Series Direct Replacement Rotor is a premium street performance rotor with aggressive appearance for the spirited street driver or performance modified street vehicle, the 4000 series XS premium cross- drilled and slotted design is the best option. Features
* Patented "Kangaroo Paw" ventilation design
* Thermal Stability Profiling
* Minimal bedding-in of rotor
* Premium non-directional cross-drilled and slotted design (XS)
* Thermo-Graphic paint markings for temperature monitoring
* Rotor protection paint on hub/hat surface
* Rapidly expels friction gases
DBA 4000 Cross Drilled & Slotted Series
MODEL#:
DBA 4648XS Front Subaru Impreza - 2.5L - RS/Coupe/Sedan - exc. WRX (1998-2005)
DBA 4644XS Rear Subaru Impreza - 2.5L - RS/Coupe/Sedan - exc. WRX (1998-2005)
DBA 4648XS Front Subaru Impreza - Wagon - exc.Outback & WRX (2002-2005)
DBA 4644XS Rear Subaru Impreza - Wagon - exc.Outback & WRX (2002-2005)
DBA 4650XS Front Subaru Impreza - WRX - exc. Sti (4-pot front) (2002-2005)
DBA 4644XS Rear Subaru Impreza - WRX - exc. Sti (4-pot front) (2002-2005)
DBA 4650XS Front Subaru Impreza - WRX - exc. Sti (2-pot front) (2002-2006)
DBA 4644XS Rear Subaru Impreza - WRX - exc. Sti (2-pot front) (2002-2006)
DBA 4654XS Front Subaru Impreza - WRX STI (5x100 bolt circle only) (2004-2004)
DBA 4655XS Rear Subaru Impreza - WRX STI (5x100 bolt circle only) (2004-2004)
DBA 4000 Slotted Series
MODEL#:
DBA 4648SL-SR Front Subaru Impreza - 2.5L - RS/Coupe/Sedan - exc. WRX (1998-2005)
DBA 4644SL-SR Rear Subaru Impreza - 2.5L - RS/Coupe/Sedan - exc. WRX (1998-2005)
DBA 4648SL-SR Front Subaru Impreza - Wagon - exc.Outback & WRX (2002-2005)
DBA 4644SL-SR Rear Subaru Impreza - Wagon - exc.Outback & WRX (2002-2005)
DBA 4650SL-SR Front Subaru Impreza - WRX - exc. Sti (4-pot front) (2002-2005)
DBA 4644SL-SR Rear Subaru Impreza - WRX - exc. Sti (4-pot front) (2002-2005)
DBA 4650SL-SR Front Subaru Impreza - WRX - exc. Sti (2-pot front) (2002-2006)
DBA 4644SL-SR Rear Subaru Impreza - WRX - exc. Sti (2-pot front) (2002-2006)
DBA 4654SL-SR Front Subaru Impreza - WRX STI (5x100 bolt circle only) (2004-2004)
DBA 4655SL-SR Rear Subaru Impreza - WRX STI (5x100 bolt circle only) (2004-2004)
DBA 5000 Series Direct Replacement rotors
DBA 5000 Series Direct Replacement rotor is for the serious driver, these 2-piece ultra -high performance rotors feature aerospace grade materials for added thermal (heat) protection to your vehicles wheel bearings. The aircraft-grade aluminium centre/hat/ bell provides greater resistance to distortion as it allows the disc to expand uniformly. Features
* Alumalite centre/hat/bell made form light weight 6061-t6 aircraft aluminium material (re-useable)
* Replacement disc rotors available (without aluminium centre)
* Directional slotted design (left-hand and right-hand disc rotors)
* NAS (National Aerospace Standard) bolts and lock nuts
* Thermal Stability Profiling (TSP)
* Thermo-graphic paint markings
* Also available in standard finish (non-slotted) for production car racing
DBA 5000 Series Sloted and Cross Drilled Direct Replacement rotor
MODEL#:
DBA 5000BLUXS Front Rotor (Blue Hat) - Subaru Impreza - WRX - exc. Sti (4-pot front) (2002-2005)
DBA 5000GLDXS Front Rotor (Gold Hat) - Subaru Impreza - WRX - exc. Sti (4-pot front) (2002-2005)
DBA 5000REDXS Front Rotor (Red Hat) - Subaru Impreza - WRX - exc. Sti (4-pot front) (2002-2005)
DBA 5010BLUXS Front Rotor (Blue Hat) - Subaru Impreza - WRX - exc. Sti (2-pot front) (2002-2006)
DBA 5010GLDXS Front Rotor (Gold Hat) - Subaru Impreza - WRX - exc. Sti (2-pot front) (2002-2006)
DBA 5010REDXS Front Rotor (Red Hat) - Subaru Impreza - WRX - exc. Sti (2-pot front) (2002-2006)
DBA 5654BLUXS Front Rotor (Blue Hat) - Subaru Impreza - WRX STI (5x100 bolt circle only) (2004-2004)
DBA 5654GLDXS Front Rotor (Gold Hat) - Subaru Impreza - WRX STI (5x100 bolt circle only) (2004-2004)
DBA 5654REDXS Front Rotor (Red Hat) - Subaru Impreza - WRX STI (5x100 bolt circle only) (2004-2004)
DBA 5000 Series Sloted Rotor
MODEL#:
DBA 5000BLKSL-SR Front Rotor (Black Hat) - Subaru Impreza - WRX - exc. Sti (4-pot front) (2002-2005)
DBA 5000BLUSL-SR Front Rotor (Blue Hat) - Subaru Impreza - WRX - exc. Sti (4-pot front) (2002-2005)
DBA 5000GLDSL-SR Front Rotor (Gold Hat) - Subaru Impreza - WRX - exc. Sti (4-pot front) (2002-2005)
DBA 5000REDSL-SR Front Rotor (Red Hat) - Subaru Impreza - WRX - exc. Sti (4-pot front) (2002-2005)
DBA 5010BLKSL-SR Front Rotor (Black Hat) - Subaru Impreza - WRX - exc. Sti (2-pot front) (2002-2006)
DBA 5010BLUSL-SR Front Rotor (Blue Hat) - Subaru Impreza - WRX - exc. Sti (2-pot front) (2002-2006)
DBA 5010GLDSL-SR Front Rotor (Gold Hat) - Subaru Impreza - WRX - exc. Sti (2-pot front) (2002-2006)
DBA 5010REDSL-SR Front Rotor (Red Hat) - Subaru Impreza - WRX - exc. Sti (2-pot front) (2002-2006)
DBA 5654BLKSL-SR Front Rotor (Black Hat) - Subaru Impreza - WRX STI (5x100 bolt circle only) (2004-2004)
DBA 5654BLUSL-SR Front Rotor (Blue Hat) - Subaru Impreza - WRX STI (5x100 bolt circle only) (2004-2004)
DBA 5654GLDSL-SR Front Rotor (Gold Hat) - Subaru Impreza - WRX STI (5x100 bolt circle only) (2004-2004)
DBA 5654REDSL-SR Front Rotor (Red Hat) - Subaru Impreza - WRX STI (5x100 bolt circle only) (2004-2004)
DBA 5000 Series Drilled/Slotted Replacement Rotor Set
MODEL#:
DBA 5000.1XS Front Rotor Subaru Impreza - WRX - exc. Sti (4-pot front) (2002-2005)
DBA 5010.1XS Front Rotor Subaru Impreza - WRX - exc. Sti (2-pot front) (2002-2006)
DBA 5654.1XS Front Rotor Subaru Impreza - WRX STI (5x100 bolt circle only) (2004-2004)
DBA 5000 Series Slotted Replacement Rotor Set
MODEL#:
DBA 5000.1SL-SR Front Subaru Impreza - WRX - exc. Sti (4-pot front) (2002-2005)
DBA 5010.1SL-SR Front Subaru Impreza - WRX - exc. Sti (2-pot front) (2002-2006)
DBA 5654.1SL-SR Front Subaru Impreza - WRX STI (5x100 bolt circle only) (2004-2004)
DBA Gold Street Series (Drilled & Slotted) Rotor Set
MODEL#:
DBA 648X Front Subaru Impreza - 2.5L - RS/Coupe/Sedan - exc. WRX (1998-2005)
DBA 644X Rear Subaru Impreza - 2.5L - RS/Coupe/Sedan - exc. WRX (1998-2005)
DBA 648X Front Subaru Impreza - Wagon - exc.Outback & WRX (2002-2005)
DBA 644X Rear Subaru Impreza - Wagon - exc.Outback & WRX (2002-2005)
DBA 650X Front Subaru Impreza - WRX - exc. Sti (4-pot front) (2002-2005)
DBA 644X Rear Subaru Impreza - WRX - exc. Sti (4-pot front) (2002-2005)
DBA 650X Front Subaru Impreza - WRX - exc. Sti (2-pot front) (2002-2006)
DBA 644X Rear Subaru Impreza - WRX - exc. Sti (2-pot front) (2002-2006)
DBA 654X Front Subaru Impreza - WRX STI (5x100 bolt circle only) (2004-2004)
DBA 655X Rear Subaru Impreza - WRX STI (5x100 bolt circle only) (2004-2004)
DBA 42654XS Front Subaru Impreza - WRX STI (5x114.3 Bolt) + (2005-2006)
DBA 42655XS Rear Subaru Impreza - WRX STI (5x114.3 B) + (2005-2006)
JBK Performance.com is offline
Old 10-10-2007, 07:48 PM   #2
Default Re: :)DBA,Brembo,EBC,Hawk,Power Slot,Motul- In Stock
DBA Street Series (Slotted) Rotor Set
MODEL#:
DBA 648SL-SR Front Subaru Impreza - 2.5L - RS/Coupe/Sedan - exc. WRX (1998-2005)
DBA 644SL-SR Rear Subaru Impreza - 2.5L - RS/Coupe/Sedan - exc. WRX (1998-2005)
DBA 648SL-SR Front Subaru Impreza - Wagon - exc.Outback & WRX (2002-2005)
DBA 644SL-SR Rear Subaru Impreza - Wagon - exc.Outback & WRX (2002-2005)
DBA 650SL-SR Front Subaru Impreza - WRX - exc. Sti (4-pot front) (2002-2005)
DBA 644SL-SR Rear Subaru Impreza - WRX - exc. Sti (4-pot front) (2002-2005)
DBA 650SL-SR Front Subaru Impreza - WRX - exc. Sti (2-pot front) (2002-2006)
DBA 644SL-SR Rear Subaru Impreza - WRX - exc. Sti (2-pot front) (2002-2006)
DBA 654SL-SR Front Subaru Impreza - WRX STI (5x100 bolt circle only) (2004-2004)
DBA 655SL-SR Rear Subaru Impreza - WRX STI (5x100 bolt circle only) (2004-2004)
DBA 2654SL-SR Front Subaru Impreza - WRX STI (5x114.3 Bolt) +JDM (2005-2006)
DBA 2655SL-SR Rear Subaru Impreza - WRX STI (5x114.3 Bolt) +JDM (2005-2006)
EBC Sport Rotor (Dimpled & Slotted) Rotor Set
GD1056 Front Rotor Subaru Impreza - 2.0 Turbo WRX STi (2003 - 2004)
GD1057 Rear Rotor Subaru Impreza - 2.0 Turbo WRX STi (2003 - 2004) GD1056 Front Rotor Subaru Impreza - 2.5 STi Turbo (2003 - 2004)
GD1057 Rear Rotor Subaru Impreza - 2.5 STi Turbo (2003 - 2004)
GD972 Front Rotor Subaru Impreza - 2.0 Turbo WRX (2003 - 2005)
GD728 Rear Rotor Subaru Impreza - 2.0 Turbo WRX (2003 - 2005)
GD729 Front Rotor Subaru Impreza - 2.2 Outback (2003 - 2007)
GD728 Rear Rotor Subaru Impreza - 2.2 Outback (2003 - 2007)
GD729 Front Rotor Subaru Impreza - 2.5 RS/TS (2003 - 2007)
GD728 Rear Rotor Subaru Impreza - 2.5 RS/TS (2003 - 2007)
Power Slot Slotted Rotors- PM WITH MAKE
COILOVERS:
TEIN TYPE FLEX
02+ WRX/04 STI - $1530 SHIPPED
05+ STI - $1530 SHIPPED
Spring Rates: 9kg/mm Front, 6kg/mm Rear
TEIN SUPER STREET DAMPER W/PILLOW BALL UPPER MOUNTS
02+ WRX / 04 STI - $1249 SHIPPED
Spring Rates: 5kg/mm Front, 5kg/mm Rear
05+ STI - $1249 SHIPPED
Spring Rates: 6kg/mm Front, 5kg/mm Rear
ADD TEIN EDFC UNIT FOR $379 SHIPPED
BUDDY CLUB D1 SPEC DAMPER
02+ WRX -$1099 SHIPPED
Spring Rates: 6kg/mm Front, 4kg/mm Rear
BUDDY CLUB RACING SPEC DAMPER
02+ WRX / 04 STI - $1599 SHIPPED
Spring Rates: 8kg/mm Front, 6kg/mm Rear
SPRINGS:
2004 STi
S Tech -DROP Front: 1.6" / Rear: .9" - PM 4 EXTREMELY LOW $
H Tech -DROP Front: 1.0" / Rear: .4"
2005 STi
S Tech -DROP Front: 1.7" / Rear: 1.2"
H Tech -DROP Front: 1.1" / Rear: .6" - PM 4 EXTREMELY LOW $
2002-3 WRX
S Tech -DROP Front: 2.0" / Rear: .7"
H Tech -DROP Front: 1.4" / Rear: .6" - PM 4 EXTREMELY LOW $
2004+ WRX
S Tech -DROP Front: 2.4" / Rear: 1.3"
H Tech -DROP Front: 1.8" / Rear: .7" - PM 4 EXTREMELY LOW $
APPROXIMATE LOWERING SPECS:
04-06+ WRX Sedan: 2.0" Front, 1.8" Rear
04-06+ STi: 2.5" Front, 2.25" Rear
PM FOR PRICE
STRUT BARS:
Carbing Front Strut Tower Bar
Fits 02+ WRX/STI - $270 SHIPPED
Front Strut Bars by TEIN:
Fits 02+ WRX/ 04+ STi - $130 SHIPPED
Rear Strut Bars by TEIN:
HOTCHKIS SWAYBAR KITS
02-06+ WRX Street Kit: - PM 4 EXTREMELY LOW $
02-06+ WRX Competition Kit: - PM 4 EXTREMELY LOW $
02-06+ WRX Sedan & Wagon Autocross Rear Swaybar:
04-06+ STi Street Kit: - PM 4 EXTREMELY LOW $
04-06+ STi Competition Kit: - PM 4 EXTREMELY LOW $
04-06+ STi Autocross Rear Swaybar: - PM 4 EXTREMELY LOW $
Integrated Performance LLC
PAYMENT METHODS:
Google Checkout,Visa, Master, Discover, American Express, Paypal, BankCheck, Wiretransfer
GOOGLE CUSTOMER? Ask for a Google Checkout Invoice Keep all your personal information SAFE and secure with iGOOGLE!
EMAIL:
Any Questions - Contact@IntegratedPerformancellc.com
Order info\Tracking - Orders@IntegratedPerformancellc.com
INSTANT MESSAGING:
YAHOO: Integratedperformancellc
AOL: IpllcJason , IpllcAlex
MSN: IntegratedPerformancellc@gmail.com
SKYPE: IntegratedPerformancellc
Old 10-20-2007, 08:34 PM   #3
Default Re: :) DBA, Brembo, EBC, Hawk, Power Slot, Motul- In Stock
Major Ebc, Power Slot And Dba Sales
Old 10-28-2007, 11:12 AM   #4
Thanks for the sales guys
Old 11-01-2007, 11:51 AM   #5
bring it up
Old 11-01-2007, 09:47 PM   #6
Feedback Score: 6 reviews
Car: OBP 05 STi/silver
Fav Mod: RCE Tarmac II's
IWSTI Addict since: May 2006
Send a message via AIM to soob'n
Can you PM me a price for the DBA 2 piece slotted front rotors for an 05' STi shipped to 95125?
soob'n is online now
Old 11-02-2007, 03:25 PM   #7
ALL SENT SEMA DEALS -EDITED PART NUMBERS FOR STi
Old 11-05-2007, 02:55 PM   #8
DBA 5000 Series INSTOCK
Old 11-18-2007, 03:06 PM   #9
Whoa More Fresh Power Slot And Dba Landed, Lets Do A Group Deal ...
Old 11-25-2007, 05:03 PM   #10
Bring Up The Stop Tech And Dba Post
Closed Thread
Privacy Policy
