Go Back   IWSTI.com: Subaru STI Forums > STi Marketplace > Vendor Classifieds > Brakes/Suspension/Stiffening
Old 06-22-2007, 02:31 PM   #1
Car: 2005 WRX
Send a message via AIM to THMotorsports.com
Exclamation >>>DBA, Hawk, GTSPEC, STANCE, HKS, KW, Unbeatable Prices<<<
THMOTORSPORTS PRESENTS:
DBA ROTORS WITH HAWK PADS UBER HOT COMBO
IN UBER HOT PRICE$$$$$$$$$!!!!!!
4000 SERIES Wiper-Slot disc Brake Rotor
4000 SERIES XS
4000 SERIES 6X6
5000 SERIES 2 PIECE RACING
DBA 5000 2-piece - For the serious driver, these 2-piece ultra-high performance rotors feature aerospace grade materials for added thermal (heat) protection to your vehicles wheel bearings.
STANDARD
STANDARD GOLD
STOCK
OUR FAVORITE: DBA 4000 SLOTTED
If you like to be hard on your brakes and demand more from a rotor than these should be your next set of rotors. DBA stands for Disc Brake Australia, and is OEM in Australia....they are lucky. These feature Thermal Stability Profiling for improved heat handling and Thermo-Graphic paint markings for effective heat monitoring. The unique 6x6 Wiper Slot is designed to efficiently clear dust and debris while maintaining consistent friction and a cleaner disc surface. Another awesome thing about the 4000 series rotors is their innovative Kangaroo Paw ventilation design. This feature helps let the brake system run cooler, stronger and it outperforms traditional straight vane disc rotors by up to 20%. This is good shhiiii people!!! Call us for more details on these.
www.dba.com.au
PM FOR SUPER LOW PRICES
HAWK BRAKE PADS
HAWK HPS stops your vehicle...hot or cold! For ultimate street performance, HAWK Cera-Metalic pads provide consistent braking power to match the needs of a more spirited driver....like us!!! With these pads on, you are drastically improving the stopping power over conventional OE compounds, delivering a stable friction coefficient of 0.38 – 0.42 in a 100 – 700°F operating range. With reduced noise, dust and superior braking comfort and with advanced friction retention systems, shims, slots and chamfers ensure performance, comfort and enhanced safety under all driving conditions. Theres are the good stuff peoples!!! Highly recommend these!!
IN STOCK READY TO SHIP
PM FOR SUPER HOT PRICES
How to order?: CALL US OR PM US
www.THmotorsports.com
Call 1-800-959-0145 ext 4 (Adam K)
**Master Card, Visa, Discover, AMEX** OR PM US!!!!!!!
EMAIL: AdamK@thmotorsports.com
WE ALSO USE AIM: adamkthm
MYSPACE:http://www.myspace.com/thmotorsports
THMotorsports.com is offline   Reply With Quote
Old 06-22-2007, 02:31 PM   #2
Car: 2005 WRX
Exclamation Re: >>>DBA, Hawk, GTSPEC, Tokico, HKS, KW, Unbeatable Prices<<<
GTSPEC CHASSIS BRACES
Strengthen the vulnerable points of an OEM chassis that are prone to chassis flex under lateral g-force loads, to maximize the road adhesion potential of your STi.
GTSPEC Chassis reinforcement and tower braces feature:
* 6061 / 7075 Aircraft grade aluminum
* Carbon Fiber
* Titanium
* CNC cut mounting socket
GTSPEC Type D Front Strut Brace For 02+ WRX/STI
GTSPEC front strut bar for Subaru 2002+ Impreza WRX. Hallow internal struture for stronger support. ***fits 06 STI with a/c line tweak. Picture above taken with brace installed on a 06 STI.
GTSPEC Type F Rear Strut Brace For 02+ WRX/STI
GTSPEC Rear Strut Tower Brace for 02+ Impreza WRX/STI. The strut bar come with triple internal hallow wall struture for stronger support. The actual bar is make of alumimum with high polish. Constructed by air craft 6061 grade aluminum for rigidity and strength.
GTSPEC Type R Rear Strut Brace For 02+ WRX/STI
Round tube style rear strut brace for 02+ Impreza WRX/STI. The rear strut bar is constructed of air craft grade 6061 aluminum for high rigidity. It's 40mm in diameter.
GTSPEC Subframe Reinforcement Brace (3 piece set) For 02+ Impreza
GTSPEC 3 piece subframe reinforcement brace. They are constructed by the same aircraft grade 6061/6063 vacuumed out aluminum with hallow triple wall design that is used in all GTSPEC suspension products. The result is incredible rigidity and a total weight saving of 6 kg/13.25 lb (half the weight of a stock Subaru Impreza). This is a 3 piece set, including one front piece and two side pieces.
GTSPEC Front Lower Tie Brace For 02~05 WRX/STI
GTSPEC front lower tie brace for 02~05 WRX/STI. Replace stock jacking plate with CNC cut center piece. Tie front left and right control arm to the center jacking plate. Will work with GTSPEC 3 piece subframe brace and 4 point ladder brace.
GTSPEC 4 Points Front Ladder Bar For 02+ WRX/STI
This four point undercarriage brace reinforcing the connection between the control arms and chassis, improves road handling and structural integrity.
GTSPEC Fender Reinforcement Brace for 02+ WRX/STI
Known as the "Gacchiri Support" in Japan or CAWL Support by SPT. This chassis reinforcement will greatly improves the handling dynamics of your car. Mounts onto the door hinge and inner fender, creating a triangular support that greatly increases rigidity over OEM. Confidence in steering is gauranteed while reducing flexing of the unibody.
GTSPEC Trunk Cage for 02~06 WRX/STI
GTSPEC Trunk Cage effectively reduce rear chassis flex and improve handling and steering response. The trunk cage connects the rear strut tower brace to the trunk brace creating a cage system. Increase vehicle response and preditability.
GTSPEC HAS SOM GREAT THING TO HELP IMPROVE YOUR SUBARU'S POTENTIAL. PLEASE FEEL FREE TO CONTACT US WITH ANY QUESTIONS. WE WOULD BE MORE THAN HAPPY TO CHAT. HAPPY MOTORING!!!
Old 06-22-2007, 02:32 PM   #3
Car: 2005 WRX
GDB WRX STi GR+
Coilovers
STANCE Coilovers. Monotube suspension offers many benefits over conventional twintube suspension. Oil and gas are completely separated, which results in precise dampening characteristics. Monotube design allows heat to dissipate much quicker. Inverted monotube design can resist extremely high lateral forces compared to an upright twintube suspension.
Oversize diameter shocks allow large pistons for ultimate performance and response. 15-way adjustable damping allows the driver to tune the shocks for any conditions and handling characteristics. With huge range of adjustment that can be felt and seen, GR+ offers serious performance for all levels of drivers. GR+ coilovers are built with highest quality materials and tolerances to ensure durability and performance.
15-Level Damping Adjustable
Adjustable Camber Uppermount
Pillowball Uppermount
Cold Wound Linear Spring for smooth performance.
Monotube shocks and inverted shocks provide extended durability.
Aluminum Collars and Upper Mounts are lightweight and durable.
Height Adjustable Lower Bracket
HKS Hipermax RS Coilovers
The all-new Hipermax Racing Sport (RS) coilover suspension kits are the first Hipermax line to be engineered as a truly global suspension system. HKS suspension engineers’ spent over a year developing the Hipermax RS, testing on various race tracks throughout the world, auto cross events and street testing in both Japan and the United States.The result of all this testing and development is a coilover suspension system that has been precisely valved to dramatically improve handling at a competitive track level, yet still be comfortable even on the harsh road conditions in the United States. HKS was able to achieve this versatility by using an F1 inspired single tube structure coupled with an oversized piston and dual oil and gas chambers. A shortened cylinder body allows suspension travel to be maintained when the car is lowered. The Hipermax RS also features HKS’ trademark 30-way dampening and rebound adjustability that is adjusted simultaneously for easy tuning. The included anodized aluminum upper pillowball mounts improve steering response, traction and offer a more direct feel to the driving surface. On certain applications camber can be adjusted on the upper pillowball mounts. All HKS Hipermax RS coilover suspension kits are built in-house at HKS Headquarters in Japan.
Adjustable Front Pillowball Mounts
Dual Rear Helper Spring
Front Spring Rate - 6kgf/mm
Rear Spring Rate - 4 + Helpkgf/mm
KW Variant 3 Coilovers
The new KW Variant 3 Coilover System is state-of-the-art technology for the skilled and experienced driver. The separate and independent compression and rebound damping options allow a truly individual driving set-up. These unique systems with the 3 individually adjustable components, allows for adjustment of the compression of the damper in the low-speed range, while the highspeed set-up, so decisive for driving comfort, has been preset by our engineers
* 30-55mm / 1.2-2.1in Lowering Front
* 25-45mm / 0.9-1.8in Lowering Rear
* 455 lbs/in Front Spring Rate
* Progressiver Rate Rear Spring
* Independently adjustable damping technology -rebound and compression damping
* Inox-line stainless steel technology at no extra charge
* Individual height adjustment
* German TUEV-tested adjustment parameters
* High-quality components for long life
* Comprehensive documentation for ease of use
* Infinitely adjustable rebound damping
* 14- level adjustable compression damping
* Unique, independently functioning damping power adjustment
THMotorsports - In stock performance superstore - Homepage
MYSPACE:MySpace.com - THMotorsports - 29 - Male - NORTHBROOK, US - www.myspace.com/thmotorsports
Old 06-25-2007, 05:51 AM   #4
Car: 2005 WRX
Default Re: >>>DBA, Hawk, GTSPEC, Tokico, HKS, KW, Unbeatable Prices<<<
Bump! monring time
Old 06-26-2007, 05:53 AM   #5
Car: 2005 WRX
Pm's replied
Old 06-26-2007, 03:38 PM   #6
Car: 2005 WRX
Thanks for the PM's .... all replied!!
Old 06-27-2007, 10:56 AM   #7
Car: 2005 WRX
Bumpshizzle!!!
Check us out. We are the new kids on the block!!
Old 06-28-2007, 08:23 AM   #8
Car: 2005 WRX
Thanks for all the emails and PM's. All replied to!!!
Old 07-02-2007, 08:11 AM   #9
Car: 2005 WRX
Best prices on hawk!!!!
Old 07-02-2007, 03:25 PM   #10
Car: 2005 WRX
Bump!!!
check us out for prices on DBA and HAWK pads!!!
PM us!!
Old 07-04-2007, 03:08 PM   #11
Car: 2005 WRX
Thanks for the support....happy 4th!!!!
Adam
Old 07-05-2007, 09:48 AM   #12
Car: 2005 WRX
Best prices!!!
Old 07-05-2007, 03:15 PM   #13
Car: 2005 WRX
And to the top!!!
Old 07-06-2007, 10:07 AM   #14
Car: 2005 WRX
Sick prices!!!
pm us for pricing!!
Thanks for the orders!!!
Old 07-09-2007, 07:48 AM   #15
Car: 2005 WRX
Best prices!!!
