Go Back   IWSTI.com: Subaru STI Forums > STi Marketplace > Vendor Classifieds > Brakes/Suspension/Stiffening
Old 07-18-2008, 02:33 PM   #1
Car: 07 sti
Fav Mod: chassis
Send a message via AIM to Methodbuilt.com
Default 5Zigen Carbon/FRP Brake Ducts, Beatrush, and JIC Supsension blowout!!! seriously...
Blowout price on DC Sports Titanium Rear Strut Tower Bar! $260!!!
With year of experience in motor sports, Laile, which manufactures, brands, and operates Beatrush has collected sufficient data information on the tracks of Japan to produce high quality and functional products. Located in Yokohama, Japan, Laile manufactures most of their products with their high precision machinery. All the unique products developed by Laile offers superior safety and plenty of pleasure both in track and the street, as well to look at.
Adjustable Control Rods
Performance Bar
Transmember Bushing
Strut Tower Brace Bar
PM for pricing and details
5Zigen Carbon/FRP Brake Ducts for GDB ( Impreza WRX/STi )
Bring direct airflow to the brake rotors.
Available for OCT delivery, are Tanabe's Front Upper Strut Brace and the Front Underbrace.Get on our list and be one of the first to have their's delivered.
Underbrace:
Often overlooked, especially on vehicles that are reaching higher levels of modification, is the importance of reinforcing the chassis. All vehicles experience flexing of the unibody under various handling loads. Twisting of the chassis is also very common on higher horsepower vehicles. The SUSTEC UNDERBRACE prevents this unwanted behaviour by connecting specific points of the undercarriage to reinforce the chassis. Unique internal double-i-beam construction is highly rigid, and lightweight, so the chassis may be significantly reinforced without adding surplus weight.
Noticeable gains in balance and stability are gained after it's simple bolt on installation.
Will update with pic in future
Strut Bar:
The strut tower bar is arguable one of the least expensive upgrades that can provide a very high degree of benefit that is felt immediately after installing. Often one of the first modifications performed on a vehicle, the strut tower brace improves handling and stability of a vehicle. The Sustec Tower Bar has been very popular due to its low price and high functionality. By connecting the strut towers, and creating a balance, the shocks are prevented from independently moving and causing small changes in suspension geometry.
picture is not on an 08, though it is what tanabe has on their website. will update accordingly later!
Methodbuilt.com is offline   Reply With Quote
Old 07-26-2008, 01:24 PM   #2
Car: 07 sti
Fav Mod: chassis
Default Re: 08 STI Tanabe Parts
bump for office saturday
Old 07-29-2008, 01:59 PM   #3
Car: 07 sti
Fav Mod: chassis
tuesday bump
Old 07-29-2008, 02:10 PM   #4
Car: 07 sti
Fav Mod: chassis
Default JIC Magic Brake Pads now at unbeatable prices!
Ideal for the weekend autocrosser and weekend warrior, the REAL D2 Brake Pad has been designed for aggressive driving on an auto x course and harsh driving situations. Like the REAL S2 brake pads, the brake dust is reduced far more than
factory and performance gains are noticed right away.
The REAL S2 Brake Pads are ideal for street performance and everyday usage on factory calipers and rototrs. They provide excellent braking during both everyday driving and more spirited driving conditions and pads are also engineered to give better braking performance without the headache of excessive dust.
Old 07-29-2008, 02:30 PM   #5
Car: 07 sti
Fav Mod: chassis
Default Insanely low prices on JIC Magic coilovers!!
The JIC FLT-TAR is the flagship coilover system. All FLT-TAR coilovers are designed on US-spec vehicles for US streets, fitment and performance is unmatched. Included in the kits are pillow ball upper mounts with adjustable camber plates. For flexibility, the dampers have 15-way compression and rebound adjustability. The spring rates are of the linear-rate type with independent ride height adjustable lower brackets. This allows adjustment without compromising damper compression or rebound travel. Based off of racing technology, the FLT-TAR is a street performance suspension, customizable for full time track use.
The JIC FLT-FAS is a coilover suspension set up ideal for the enthusiast that will use the suspension on a daily basis and occasionally for the track. FLT-FAS features a 10 way adjustable damper. For strength, strut-type suspensions feature a wide shaft while multi-link type suspensions feature the smaller shaft damper.
FLT-FAS include front pillow ball upper mounts and front adjustable camber plates.
Also included are springs of the linear-type for laser precision handling and adjustable lower brackets for ride height adjustments that do not affect damper travel.
We also have replacement springs available, for those that want to change the available height or stiffness of the FLT-FAS and -TAR systems.
PM for details and pricing
Old 07-29-2008, 02:47 PM   #6
Car: 07 sti
Fav Mod: chassis
Default JIC Magic Rear Trailing Arms available at unbelievable prices!
JIC Rear Trailing Arms are ideal to reduce excessive movement in the suspension. Reduces rear squat, inner edge tire wear, and increases traction. Super Strong trailing arms enhance traction and feature pillow balls to ensure accurate suspension geometry. Allows for slight wheelbase changes. For race use only.
Old 07-29-2008, 02:55 PM   #7
Car: 07 sti
Fav Mod: chassis
Default JIC Magic Rear Camber Adjustable Upper Arm and Lower Link now available!
Essential for automobiles that are lowered or have increased wheel diameter. Corrects uneven tire wear or adds negative camber for aggressive driving. Super Strong adjustable lateral links feature camber and toe adjustability, as well as pillow balls at each end to ensure accurate suspension geometry. For race use only.
Old 07-29-2008, 03:37 PM   #8
Car: 07 sti
Fav Mod: chassis
Default JIC Magic Lower Arm Bars now available at rock-bottom prices!
JIC Lower arm bar 1 and 2 eliminate flexing common in the low-mounted rear control arms improving stability and handling in all driving situations.
( will only fit 02-07 Impreza's, including WRX and STi, will not fit GC8 chassis )
Old 08-06-2008, 11:40 AM   #9
Car: 07 sti
Fav Mod: chassis
Default Re: JIC Supsension blowout!!! seriously...
up for new pricing on the JIC FLT-AR's shipped $PM me
Old 08-07-2008, 02:58 PM   #10
Car: 07 sti
Fav Mod: chassis
Default Re: Beatrush and JIC Supsension blowout!!! seriously...
bumpity bump!
Old 08-12-2008, 05:49 PM   #11
Car: 06 STI & FXT
Fav Mod: painted Hella horns!
Can you let me know the availability and pricing of the Beatrush adjustable lateral links shipped to 60646?
covert747 is offline   Reply With Quote
Old 08-18-2008, 12:20 PM   #12
Car: 07 sti
Fav Mod: chassis
PMs answered. Bump
Old 08-20-2008, 10:38 AM   #13
Car: 07 sti
Fav Mod: chassis
bumpage
Old 08-21-2008, 10:20 AM   #14
Car: 07 sti
Fav Mod: chassis
bumps
Old 08-25-2008, 10:30 AM   #15
Car: 07 sti
Fav Mod: chassis
monday bumps
