Go Back   IWSTI.com: Subaru STI Forums > STi Marketplace > Vendor Classifieds > Brakes/Suspension/Stiffening
Old 07-15-2008, 05:02 PM   #1
Car: 01 Subaru WRX STi Spec C
Trader Rating: (13)
Default Cheap Brake Packages-STi Pinks Sold-KYB AGX$475-KYB AG2$299
We got some awesome deals this week guys. I got a huge shipment of Eibach Springs and Kyb Struts in Stock! Best prices anywhere. Also I have one set of J-Spec Pink Struts in Stock. Not that US Spec KYB AGX that some people try to paass off. All Items listed in stock ready to ship.
Eibach Springs
In Stock
Pro Kit 02-03 WRX $225 Shipped
Pro Kit 04-07 WRX $225 Shipped
Pro Kit 04-07 STi $249 Shipped
Pro Kit 2008 Impreza $225 Shipped
Pro Kit 2008 WRX $225 Shipped
Pro Kit 2008 STi $249 Shipped
STi Pink Struts
Arai Spec
JDM STi Pink 4-Way Adjuastable Struts! Fits 05+ STi. Super rare in the states and very hard to find!
SOLD!!!!
Ohlins Fixed Perched Struts
Competition Spec
Ohlins Fixed Perch Strut Kit are a great alternative to coilovers. They are 25 way adjustable, for compression and rebound simultaneously.
Great option for those looking to increase performance with out sacrificing ride quality. This is a choice for weekend warriors that still like to enjoy a comfortable ride on the weekdays.
They are used with stock or after market stock location springs. And with stock style top hats.
Include 2 front and 2 rear struts.
PM For Price
KYB AGX
4 Way Adjustabability
These are the same struts the Subaru ReBrands as SPT. Save $$$ over the dealerships overpriced option.
1- Allow drivers to adjust damping to match specific driving conditions
2- Manually adjustable multistage damping.
3- Adjusts from street to strip to track in seconds.
4- No need to lift vehicle or use special tools.
5-Competition grade engineering and construction.
-Velocity-sensitive valving - Multistage valve compression enables the shock to adjust to driving conditions automatically. Under gentle road conditions, the valving allows the shock to travel freely for maximum ride comfort. As conditions get rougher, the shocks is compressed faster. The valving responds instantly, to make the shock response firmer, maintaining tire contact and vehicle control.
-Sintered iron pistons and guide rods - Sintered metal provides far greater strength than traditional metals, extending shock life and durability.
-Micro-smooth, hard-chromed piston rods - KYB has the smoothest hard-chromed rods in the business for extra-long life and reliability.
-Seamless cylinders and eye rings - Most shock cylinders & eye rings are made from flat metal and welded at the seam. KYB cylinders and eye rings are extruded as seamless cylinders, eliminating weak points created by welded seams.
-Multi-lip seals / self-sealing packing - KYB uses a triple-lip oil seal to keep the oil in and contaminants out.
-Patented check valve - KYB uses a special check valve to minimize foaming caused by the mix of oil and gas inside the shock. This helps maintain reliable performance, even under tough conditions.
-Fast on car adjustment - Convenient external dial or slot at top of rod (depending on model) allows for simple hand adjustment of the damping forces for strip, street, cruising, or high speed driving. Eliminating the need to remove parts or lift the vehicle.
2002-2003 WRX (Sedan Only) $475 Shipped
*** Due To The Stiffer Spring Rate on the 04-07 WRX Premature Strut Wear Can Occur and Is Not Recomended For 04-07 Applications****
KYB GR2
OEM Replacement
GR-2 gas shock absorbers, strut cartridges and complete struts are affordably priced, twin tube designs that blend a smooth ride quality with enhanced road control. A low-pressure gas charge and patented check valve minimize foaming and aeration to help make sure the ride stays consistent, even under rough conditions. When you want to blend like-new vehicle ride qualities with a little more control, you want KYB GR-2 gas series shock absorbers, strut cartridges or complete struts.
2002-2003 WRX (Sedan Only) $289 Shipped
2002-2003 WRX (Wagon Only) $289 Shipped
HKS Hipermax RS
1 Set Left
All HKS Hipermax Suspension systems utilize a mono-tube suspension structure which is a design where both the oil chamber and gas chamber are completely separated inside a single cylinder. Dampening is created as the piston moves up and down inside the cylinder. Dampening is maintained by applying constant load to the cylinder with the use of high pressure gas. There are many characteristics to the mono-tube design, which results in high durability, and comfort even in the harshest driving conditions. Mono-tube suspension structure requires an intense level of research and development as well as advanced manufacturing.
02-07 WRX/ 04 STi
$1299 Shipped
KW Variant 3 Coilovers
Free Peak Performance Pillow Ball Top Mounts
The new Variant 3 is state-of-the-art technology for the skilled and experienced driver. The separate and independent compression and rebound damping options allow a truly individual driving set-up. These unique systems with the 3 individually adjustable components, allows for adjustment of the compression of the damper in the low-speed range, while the highspeed set-up, so decisive for driving comfort, has been preset by our engineers. True 2 way. Independently adjustable damping technology -rebound and compression damping. Inox-line stainless steel technology. High-quality components for long life.
02-07 WRX/ 04 STi
05-07 STi
PM for price
Click Here For More Information on the Peak Performance Upper Mounts
Ohlins Flag Coilovers
Ohlins coilovers for street cars dramatically improves traction, handling and at the same time the comfort of the car. The shock absorbers are produced in Sweden and Japan with the specifications, and above all, the development made in Sweden.
All Ohlins shock absorbers are individually tuned for each model and its specific characteristics. They test themselves by fitting shock absorbers to each vehicle and conducting thorough tests. As usual, we believe in trying to combine the hard-to-define ‘feeling’ of our experienced drivers with measurement data obtained from their advanced equipment.
PM For Price
Helix Coilovers
Helix DNA Sport Coilovers are designed to suit the average vehicle enthusiast. Unlike race coilovers which often exhibit harsh ride characteristics, high cost, and sometimes excessive noise, Helix DNA Sport Coilovers are designed primarily for street service with mild track service in mind. Featuring excellent ride characteristics and lower cost, these coilovers are a fine balance of street function and track service. Fully rebuildable and available in multiple spring rates.
Specs:- Light aluminum Shock Body- 16 Pt Dampening / Rebound Adjustable- Full Upper Pillow Ball Mounts- Camber Adjustable- 8kg / 6kg spring rates
02-07 WRX/ 04 STi
05-07 STi
$899 Shipped
Whiteline Swaybars
In Stock
Whiteline STi 22mm Front Adj. $174 Shipped
Whiteline STi 22mm Rear Adj. $174 Shipped
Whiteline WRX Wagon 22mm Front Adj. $199 Shipped Free Helix Sperichal Endlinks
Whiteline WRX 24mm Front Adj. $199 Shipped Free Helix Sperichal Endlinks
Whiteline WRX 27mm Rear Adj. $249 Shipped Free Helix Sperichal Endlinks
Gruppe-S is offline   Reply With Quote
Old 07-15-2008, 05:03 PM   #2
Trader Rating: (13)
Default Re: Cheap Brake Packages-STi Pinks$999-KYB AGX$475-KYB AG2$299
Hey guys get ready for some great Brake Combos! From Street to Full Race we have a system that fits your budget. Dont miss out these are super red hot and selling out fast! BBK also on sale dont miss out before prices go up!
All brake packages are for front and rear.
Brake Upgrades
Stage 1 Brake Package
Street System
- Hawk HPS F&R Brake Pads
- Gruppe-S Brake Lines
- 1L ATE Brake Fluid
02-05 WRX $239 Shipped
06-07 WRX$259 Shipped
04-07 STi$269 Shipped
Stage 2 Brake Package
Performance Street System
- SP 1pc F&R Slotted Rotors
02-05 WRX $550 Shipped
04-07 STi $649 Shipped
Stage 3 Brake Package
Performance Street/ Mild Race System
- SPP 1pc F&R Slotted Rotors (WRX)
- Performance Friction 2pc Rotors/ SP 1pc Slotted Rear Rotors (STi)
06-07 WRX $625 Shipped
04-07 STi$1125 Shipped
STi Stage 4 Race System
Full Race System
- Porterfield R-4 Full Race Compound Pads F&R
- 2L Motul RBF600 Brake Fluid
$1499 Shipped
SP Rotors
With SP Performance Slotted rotors, you will feel the difference. Its series of slots wipe the surface of the rotor forcing the gases to expel through the slots. The slots also greatly improve wet weather braking by preventing hydroplaning between the pad and rotor.
02-05 WRX $318Shipped
04-07 STi $480 Shipped
Powerslot Rotors
Excessive heat can cause resins in your brake pad to vaporize or "outgas." As the brake pad wears, the used friction material turns into a fine dust. This boundary layer of heat, gas and dust builds up between the pad and rotor surfaces and inhibits performance. Here's where Power Slot's slotted brake rotors make a big difference.
02-05 WRX $377 Shipped
04-07 WRX $460 Shipped
Performance Friction Rotors
These rotors allow you to retain the Stock Evo Brembo Calipers (which are excellent pieces) while reaping all the benefits of a 2-piece rotor. They are 4.4 lbs. lighter per rotor than the stock pieces meaning that unsprung and rotational mass are dramatically decreased. This will create better feedback and improved handling.
04-07 STi $740 Shipped
Gruppe-S Steel Braided Brake Lines
Gruppe-S Stainless Steel Braided Teflon Hoses could very well be the easiest and least expensive way to upgrade your braking system. In any braking system there is flex ? in the pedal, in the caliper, but most of the flex is in the hose.
$99 Shipped
Hawk Brake Pads
HPS
Hawk Performance HPS-High Performance Street disc brake pads are designed for sports cars, coupes, sedans and pickup trucks and sport utility vehicles used for high speed driving or that may encounter repetitive heavy braking. Hawk Performance HPS Ferro-Carbon compound brake pads provide advanced braking characteristics to enhance the driving experience. This unique compound combines the safety and quality of aerospace design partnered with the braking technology of motorsports.
HP+
Hawk Performance's HP Plus disc brake pads are designed for sports cars, coupes and sedans for sport driving in autocross, Solo II and many “track day” applications. Additionally, the Hawk Performance HP Plus Ferro-Carbon compound can take the heat at the track and get you home safely without having to change your brake pads in and out. This compound was designed for the serious street and autocross enthusiast.
Warning! Due to the dramatic friction levels produced by this product to achieve "race-level" braking, rotor wear, noise, dust, and pad life may be affected.
The high friction level of Hawk HP Plus pads will be more responsive than most standard original brakes and their high resistance to brake fade makes them a superb upgrade for high performance streetcars used in competition, for high speed driving or that encounter repetitive heavy braking.
Blue
For over 15 years, Hawk Performance has dominated the racetrack by providing champions with cutting-edge friction materials. Whether you are looking to improve your braking ability during the next lapping day or looking to make your move on the final lap, Hawk has you covered with a wide array of Motorsport Compound Pads.
SPECIAL NOTE: Due to the aggressive nature of the Hawk Performance Motorsports Compound pads, they are not recommended for street use.
Blue 9012 Compound
Temp Range: 250-1,000 degrees Fahrenheit
Torque: Medium to high
Recommended Use: Hawk's most popular Motorsport Compound offers excellent modulation and braking power for a wide variety of applications. Strong initial bite combines with exceptional pedal feel to give drivers confidence during road racing and stage rally events. Also popular with experienced lapping day and driver school participants.
HPS 02-05 WRX $156 Shipped
HPS 06-07 WRX $157 Shipped
HPS 04-07 STi $195 Shipped
HP+ 02-05 WRX $205 Shipped
HP+ 06-07 WRX $205 Shipped
HP+ 04-07 STi $235 Shipped
Blue 02-05 WRX $260 Shipped
Blue 06-07 WRX $289 Shipped
Blue 04-07 STi $385 Shipped
Free Bottle of ATE Fluid with Purchase of F&R Brake Pad Set.
Endless Brake Pads
Vita Nuova
Endless has produced the Vita Nuova compound for entry-level users who are seeking improved performance while retaining maximum comfort. Designed for everyday street conditions
CC-A
The CC-A compound is a ceramic carbon compound that provides maximum pedal feel. We have designed this compound to exhibit little to none of the negative characteristics that ceramic carbon compounds are known to have.
CC-X
With the Ceramic Carbon Metal series, the CC-X is considered the standard. A Ceramic Carbon Metal characteristic is direct brake feel. To bring this brake feel to a wide range of users, we�ve researched and developed a compound blend that is rotor-friendly, works at low temperatures, has good front and rear balance and a reasonable price with high performance in mind. Direct pedal feedback enables one to modulate their brakes easily.
Vita Nuova $189 Shipped
CC-A $315 Shipped
CC-X $420 Shipped
Project MU B-Force
The Project mu B-Force brake pads are a non-asbestos, economical street-type brake pad with superior initial stopping power. With the clear objective to improve overall performance above that of stock brake pads, the street-type brake pad was developed for street use where initial stopping power and resistance to fading is of prime importance.
$235 Shipped
Porterfield R4
R-4 Full Race Compound – Designed specifically for heavy-duty motorsports. The carbon based semi-metallic R-4 materials allow the pad to absorb tremendous amounts of heat and dissipate it at very even rate. Carbon Kevlar material warms up to race temperature quickly, which is quite helpful during restarts, and when track time is limited.
02-05 WRX $229 Shipped
06-07 WRX $235 Shipped
04-07 STi
$358 Shipped
Looking to for more stopping power? Check out our BBK.
Endless Six-Pot
The 6-Pot big caliper with cost-effective performance can be used with a rotor diameter up to 370mm. The caliper is made of lightweight forged aluminum with excellent heat resistance characteristics. Piston sizes of differing diameters are staggered to ensure even pad wear and increased feedback. The braking force of these calipers is a perfect match for high horsepower street cars.
PM For Price
Old 07-16-2008, 09:28 AM   #3
Trader Rating: (13)
Old 07-17-2008, 12:43 PM   #4
Trader Rating: (13)
Default Re: Cheap Brake Packages-STi Pinks Sold-KYB AGX$475-KYB AG2$299
Old 07-18-2008, 01:00 PM   #5
Trader Rating: (13)
Old 07-21-2008, 10:38 AM   #6
Trader Rating: (13)
Old 07-22-2008, 04:13 AM   #7
Fav Mod: a garage
How much for a full brake package for an 04 sti shipped to 20136:
-HPS pads
-upgraded lines
-fluid
-DBA basic rotors or SP slotted rotors
Thanks
Old 07-22-2008, 10:26 AM   #8
Trader Rating: (13)
-HPS pads
-upgraded lines
-fluid
Thanks
I have the price listed in the 1st post for your combo you are requesting. I dont stock DBA because its really expensive and there is no real benefit over the SP rotors.
Old 07-23-2008, 11:40 AM   #9
Trader Rating: (13)
Old 07-24-2008, 11:36 AM   #10
Trader Rating: (13)
Old 07-25-2008, 10:06 AM   #11
Trader Rating: (13)
Old 07-28-2008, 01:44 PM   #12
Trader Rating: (13)
Old 07-29-2008, 10:20 AM   #13
Trader Rating: (13)
Old 07-30-2008, 11:15 AM   #14
Trader Rating: (13)
Old 07-31-2008, 10:04 AM   #15
Trader Rating: (13)
