Go Back   IWSTI.com: Subaru STI Forums > STi Marketplace > Vendor Classifieds > Brakes/Suspension/Stiffening
Closed Thread
Old 07-15-2008, 08:50 AM   #1
Trader Rating: (50)
Default Put a little spring into your step
Swift STi R-spec springs
Drop:
* 04 STi: -20mm front, and -15mm rear
* 05 and up Sti: -25mm front and rear
Rates:
* Front: Progressive with a final rate of 5K (280lbs)
* Rear: Progressive with a final rate of 4.5K (252lbs)
Price is $309 shipped for free in the US. You can get them by clicking here.
Turninconcepts.com is offline
Old 07-15-2008, 08:52 AM   #2
Trader Rating: (50)
Default Re: Put a little spring into your step
RCE Blacks
Racecomp Engineering Black "Regular Guy" Springs
Introducing the RCE Regular Guy Springs (RCE Blacks), an OEM replacement spring for 2004-2007 Subaru WRX STi and the next in the Racecomp Engineering growing line of performance springs.
Designed for use with standard STi inverted struts or Ohlins Fixed Perch Replacement Struts, these springs are intended for both the daily driven street driver as well as the autocross and track day weekend warrior. Using similar spring rates as the extremely popular and successful RCE Yellow Springs, but having a much more subtle/mild drop in comparison, these are perfect for STi owners not looking for a ride height much lower then stock, and yet are still looking for increased spring rates. Spring rates are still 10% stiffer then JDM Pinks with an emphasis on the rear rate, so you will still be outpacing just about everything on the track and auto-x course.
Summer sale price of $309 with free shipping in the US. To get yours click here.
Old 07-15-2008, 09:03 AM   #3
Trader Rating: (50)
RCE Yellows
Racecomp Engineering Super Sport Street/Track Springs
The highly anticipated Super Sport Street/Track Springs, an OEM replacement spring for 2004-2007 Subaru WRX STi from Racecomp Engineering.
Using the very popular JDM STi springs as the benchmark, Racecomp focused on improving on track and autocross performance, while maintaining acceptable ride quality. Extensive research, design, and testing was performed to develop a completely new spring unlike anything currently available.
With springs rates increased approximately 25% stiffer then the popular JDM Pink Springs, the springs are perfect for those with wider tires worried about rubbing, as well those looking for a little more rear spring rate to promote a more neutral handling characteristic. Much care was taken not to exceed the limits of the stock struts. The mildly progressive design and spring rates properly matched with the dampers ensure that ride quality is not diminished over stock.
The car is lowered 20mm in the rear and 23mm in the front for an even look.
Old 07-17-2008, 05:53 AM   #4
Trader Rating: (50)
Boing!!!
Old 07-19-2008, 05:14 AM   #5
Trader Rating: (50)
bump.
Closed Thread
