Go Back   IWSTI.com: Subaru STI Forums > STi Marketplace > Vendor Classifieds > Brakes/Suspension/Stiffening
Old 06-07-2008, 08:43 PM   #1
Car: 07 sti
Fav Mod: chassis
Send a message via AIM to Methodbuilt.com
Default JIC FLT RS custom set up FOR 08 STI
Hi,
We are offering two JIC FLT RS for 08 STI. These two particular sets will be set up for track or street use. Due to the design of the subaru suspension the set up can be for either application. Price on these is 2099.99 Shipped. If you are interested please email us and we will send you a form you can fill out to describe you application. That data will be used to match the spring rates and set up dampening as well as piston piston size.
FLT-RS Custom Set Up
Custom tuned suspension for the masses! Our FLT-RS starts with our FLT-TAR coilovers. We work with the racer to custom tune the coilovers to the individual's needs. We choose custom springs and dampers suited to each track or driving style. When necessary, helper springs are added to ensure the full stroke of the damper is utilized. Standard features are light weight 15 way adjustable monotube dampers that ensure high strength and fade free performance. The ride height is adjustable separate from the spring perch, giving you maximum suspension travel at any setting. This also allows for proper corner weighting of the vehicle without effecting spring preload settings. Linear springs give laser precision steering response. All models include upper pillow ball mounts. Most MacPherson strut designs utilize front camber plates and feature high tensile steel brackets. Multilink suspension designs feature CNC machined aluminum lower brackets.
Methodbuilt.com is online now   Reply With Quote
Old 06-12-2008, 08:30 PM   #2
Car: 07 sti
Fav Mod: chassis
Default Re: JIC FLT RS custom set up FOR 08 STI
pm's replied , thank you.
