Go Back   IWSTI.com: Subaru STI Forums > STi Marketplace > Vendor Classifieds > Brakes/Suspension/Stiffening
Old 06-07-2008, 11:19 AM   #1
Car: Subaru STI
Fav Mod: Tuning
Send a message via AIM to P&L Motorsports
Default P&L SS Brake Line Kit with FREE Motul/SuperBlue! Other Brake&Suspension Deals Inside!
New Lowered Price! $99.95
Fits 02-08 WRX and STI!
If you're considering upgrading your brake system, you can NOT afford to skip over these upgraded brake lines.
Stainless steel braided lines will help preserve pedal feel during the hardest of track days or spirited street use. Guaranteed not to stretch and weaken under high brake fluid PSI.
These lines are finished in a tough outer layer of clear coating to preserve life and keep the steel clean and working properly.
Available in 7 different colors!
Note: Gold, Blue, Gray, Bronze, and Red are special order colors and not kept in stock. Stainless Steel and Black are regularly kept in stock. Pictured below is the Stainless Steel color.
IWSTI SPECIAL!
If you mention in the comment section while ordering online that you are an IWSTI member, you will receive your choice of 1L of ATE Super Blue Brake Fluid or 1 500ml of Motul RBF 600 Brake Fluid free of charge. Please specify in the comment section which you would prefer. (Motul fluid is geared toward serious circuit racing and as such has a significant price increase over Super Blue . A second bottle of Motul will have a $15 charge. You will need 1L of either fluid to complete a fluid change.)
Purchase Them Here!
-Ty
P&L Motorsports is offline   Reply With Quote
Old 06-07-2008, 11:19 AM   #2
Car: Subaru STI
Fav Mod: Tuning
Default Re: P&L SS Brake Line Kit with FREE Motul/SuperBlue! Other Brake&Suspension Deals Ins
Endlinks - 04-07 STI
Old 06-07-2008, 11:20 AM   #3
Car: Subaru STI
Fav Mod: Tuning
We have thoroughly tested the Endura-Tech coilover set up, and we are nothing but impressed with their performance! The Endura-Tech coilovers deliver a PERFECT balance between performance and ride quality. They have a great ride for the street and with only a few adjustments they transform to a fantastic racing application suspension.
These coilovers are designed for the 05-07 Subaru STI.
The Endura-Tech coilovers feature:
- A twin tube structure
- Come with front pillow ball upper mounts with camber plate adjustment
- 10-way dampening adjustment
- Lower bracket height adjustability prevents having to adjust the spring seat offering maximum suspension travel
- Front Spring rates are 7kg (392 lbs./in)
- Rear Spring rates are 5kg (280 lbs./in)
Endura-Tech 2002-2007 WRX and 2004 STI Coilovers
Endura-Tech 2005-2007 STI Coilovers
Old 06-07-2008, 11:20 AM   #4
Car: Subaru STI
Fav Mod: Tuning
Recently we installed a set of STI rotors we hadn't seen before and were so impressed with the quality that we knew we needed to offer them to our customers. A few quick phone calls later we are offering you guys awesome deals on Girodisc!
Originally Posted by Girodisc
The Girodisc system is a direct replacement for the OE disc. No modifications are necessary. The disc will bolt directly to the car and work with OE calipers perfectly. By upgrading your brakes with lightweight high performance replacements as opposed to a big brake kit, your factory bias is maintained as well as your ABS efficiency. The Girodisc front rotors are approx 16.5lbs vs. 20.5lbs for the stock units. This reduction in rotational and unsprung weight allows for quicker acceleration and suspension response.
The central "hat" section of the disc is made from 6061-T6 aircraft specification aluminum. The disc is made from cast iron to the same specification and material as used by professional racing organizations. It is a curved vane design, developed in racing to act as a centrifugal pump to force cooling air through the disc.
The rotor and hat have a floating mount system, which utilizes 10 high strength alloy steel drive pins, manufactured by Girodisc to our own specifications and cadmium plated for a long lasting corrosion resistance. These pins take the load from braking actions while maintaining the axial and radial float between the hat and disc. In order to keep the rotors from making noise when cold, the pins are mounted with anti-noise spring washers on the rotor side which allow the rotor to grow with heat expansion but eliminate the rattle and noise associated with floating rotors. This float also allows the rotor to self center between the pads.
Once the Girodisc system is in place, simply replace the cast iron rotor when needed.
When used with performance pads and hi-temp fluid, you have what amounts to a truly amazing solution to overheating or warping rotors.
2 piece Girodisc front rotors - MSRP: $700 - P&L price: Too low to list!
Old 07-16-2008, 11:15 AM   #5
Car: Subaru STI
Fav Mod: Tuning
More sets of brake lines and brake fluid in stock today!
Old 08-15-2008, 02:16 PM   #6
Car: Subaru STI
Fav Mod: Tuning
Bump it
Old 08-16-2008, 05:47 PM   #7
Fav Mod: Proper Alignment
Do these brake lines fit the '08 STi?
UberWagon is offline   Reply With Quote
Old 08-16-2008, 06:05 PM   #8
Car: Subaru STI
Fav Mod: Tuning
I'll verify with the 08 STI we have at the shop on Monday.
-Ty
Old 08-29-2008, 04:32 PM   #9
Car: Subaru STI
Fav Mod: Tuning
Sorry for the delay, they do in fact fit perfectly on the '08 STI.
-Ty
Old 08-29-2008, 04:33 PM   #10
Car: Subaru STI
Fav Mod: Tuning
In case you guys step away from the grill/keg at any point in time this weekend, we're offering free shipping for EVERYTHING on our website!
Deal only lasts till Sept 2nd, so don't miss out!
Have a safe and happy holiday everyone!
-Ty
P&L Motorsports
P&L Motorsports - Home
