Go Back   IWSTI.com: Subaru STI Forums > STi Marketplace > Vendor Classifieds > Brakes/Suspension/Stiffening
Old 04-18-2008, 12:00 PM   #1
Car: STI's ;)
Fav Mod: Coolest Vendor Ever
Send a message via AIM to RallySportDirect Send a message via Yahoo to RallySportDirect
Default New 2008 STi/WRX Cusco Braces are HERE! IN STOCK! Make it Stiff!
Cusco has relised the 2008 STi/WRX Power Braces! AND WE HAVE THEM IN STOCK!
These are a great way to increase chassis stiffness, with out sacrificing ride quality and comfort.
Front Lower Arm Bar Type II 170.00
The Type II lower arm bar is made of tubular aluminum to help reduce weight over the stock bracing without compromising strength. Coated in the classic Cusco blue paint, it offers years of protection against the elements while adding to the overall look of the bar. The Type II bar is a multi-point setup and includes all the required hardware for installation. It bolts on easily using normal hand tools.
Center Floor Brace 430.00 SHIPPED
This Cusco Center Floor Power Brace will not allow the front and the middle of the chassis to flex by themselves. This will provide a crisper turn in response and eliminate some of the chassis flexing during hard driving.
Made out of light weigh aluminum, to help keep weight down. And help increase chassis stiffness.
Rear Member Brace
275.00 Shipped
Rear Member Brace helps keep the back sub-frame from shifting during hard cornering. Made out of light weight metal. To help keep weight down and stiffness of the chassis up.
Direct Bolt on and comes with all hardware required.
Rear Floor Brace 140.00
These Cusco Rear floor Power Braces help to make the rear of the inside chassis and the outside of the chassis more reinforced. This will not allow the inside and the outside of the rear chassis to move independently. Allowing the rear to be more stable during hard cornering.
Made out of light weight aluminum.
Rear End Brace 195.00
This Brace replaces the OEM Rear Bumper Beam. Now only are you increasing chassis stiffness so that he right and he left side of the chassis move more uniformly. You are also loosing weight. And on a +3000lbs Chassis, any weigh loss helps.
Replaces OEM Rear Bumper Beam.
Rear Cross Member Brace 95.00
This Cusco 2008 STi/WRX Rear Power Member Brace Connects both sides of your rear cross member. It helps to keep the rear member from flexing, and adds rigidity. Direct bolt on and does not require any modification and comes with all the required hardware.
THESE ARE ALL IN STOCK! READY TO SHIP!
Please Call or Visit the link below.
LINK CLICK ME!
Thanks
Kirill
RallySportDirect.com
801-748-4910 ext 1006
RallySportDirect is offline   Reply With Quote
Old 04-22-2008, 01:09 PM   #2
Car: STI's ;)
Default Re: New 2008 STi/WRX Cusco Braces are HERE! IN STOCK! Make it Stiff!
Make it stiff bump
Old 05-06-2008, 08:16 AM   #3
Car: STI's ;)
H brace installed on our shop STi, and its a nice improvement!
Old 05-15-2008, 10:47 AM   #4
Car: STI's ;)
To the top!
Old 05-30-2008, 08:47 AM   #5
Car: STI's ;)
Getting another pallet today!
Old 06-05-2008, 08:37 AM   #6
Car: STI's ;)
In stock bump!
