Go Back   IWSTI.com: Subaru STI Forums > STi Marketplace > Vendor Classifieds > Brakes/Suspension/Stiffening
Closed Thread
Old 04-14-2008, 05:35 PM   #1
Car: 01 Subaru WRX STi Spec C
Trader Rating: (13)
Default Brake combos from$239-Slotted Rotors$310-All Hawk On Sale-ALK From$175
All brake components on sale! Dont miss out on these awesome prices. Brake combos in stock from Mild Street to Full Track. Looking for full track upgrades Pm us for your needs.
Brake Upgrades
Stage 1 Brake Package
Street System
- Hawk HPS F&R Brake Pads
- Gruppe-S Brake Lines
- 1L ATE Brake Fluid
02-05 WRX $239 Shipped
06-07 WRX $259 Shipped
04-07 STi $269 Shipped
Stage 2 Brake Package
Performance Street System
- SP 1pc F&R Slotted Rotors
02-05 WRX $550 Shipped
04-07 STi $649 Shipped
Stage 3 Brake Package
Performance Street/ Mild Race System
- SPP 1pc F&R Slotted Rotors (WRX)
- Performance Friction 2pc Rotors/ SP 1pc Slotted Rear Rotors (STi)
02-05 WRX $589 Shipped
06-07 WRX $625 Shipped
04-07 STi $1125 Shipped
STi Stage 4 Race System
Full Race System
- Porterfield R-4 Full Race Compound Pads F&R
- 2L Motul RBF600 Brake Fluid
$1499 Shipped
Looking For Individual Brake Components?
All items In Stock Ready To Ship
SP Slotted Rotors
With SP Performance Slotted rotors, you will feel the difference. Its series of slots wipe the surface of the rotor forcing the gases to expel through the slots. The slots also greatly improve wet weather braking by preventing hydroplaning between the pad and rotor. The slots on SP Performance rotors are machined to the minimum thickness. This is done to insure that the rotor strength is not compromised, keeping safety and reliability in mind for virtually all automotive cars and trucks. This is a bolt-on, hassle free way to greatly improve your stopping performance. All rotors are provided with our gray ZRC coating. It provides long-lasting protection against corrosion in the most hostile salt-water environments. After being applied, ZRC provides the highest level of galvanic protection. The film of ZRC is conductive. After the coating heats up during use, it bonds permanently to the metal surface. It will not allow the metal to corrode, even when the surface is scratched.
02-05 WRX F&R
$310 Shipped
04-07 STi F&R
$435 Shipped
Hawk HPS Brake Pads
HPS (High Performance Street) Compound - provides advanced braking characteristics to enhance your driving experience. High performance street pads that are race worthy. All Hawk pads are compatible with factory brakes & A.B.S. systems.
02-05 WRX F&R
$160 Shipped
Free ATE Super Blue Brake Fluid
06-07 WRX F&R
$160 Shipped
04-07 STi
$195 Shipped
Performance Friction Race Rotors
These rotors allow you to retain the Stock STi Brembo Calipers (which are excellent pieces) while reaping all the benefits of a 2-piece rotor. They are 4.4 lbs. lighter per rotor than the stock pieces meaning that unsprung and rotational mass are dramatically decreased. This will create better feedback and improved handling. These rotors are also vaned to improve cooling over the stock pillared units. Finally, dimples ensure that your pads are adequately refreshed while maximizing surface of the rotor and preventing cracking (as compared to crossdrilled rotors).
-5X100 and 5X114.3 fitment!
-2-piece design allows aluminum hat for lightweight rotors.
-Full floating design allows expansion of rotor and hat at different rates to prevent pad coning.
-Lightweight - 17.6 lbs per rotor (stock rotors are 22 lbs.).
-Dimpled to increase surface area of rotor (promotes cooling), refresh pads, and less prone to cracking than cross drilled rotors.
-Vaned to promote cooling.
-Allows you to retain stock Brembo calipers.
04-07 STi Fronts
$599 Shipped
Gruppe-S Steel Braided Brake Lines
Gruppe-S Stainless Steel Braided Teflon Hoses could very well be the easiest and least expensive way to upgrade your braking system. In any braking system there is flex ? in the pedal, in the caliper, but most of the flex is in the hose. Every time you step on your brake pedal, up to 1500 pounds of pressure moves brake fluid from the master cylinder to the caliper. Most of the way, the brake fluid moves through rigid steel lines. Unfortunately, these steel lines cannot complete the journey all the way to the caliper because movement in the line is necessary to connect a non-moving part (the chassis) to a moving part (the brake assembly as attached to the wheel). These connecting hoses are made from rubber and nylon. Even with the nylon braiding inside the hose, when that much pressure hits it, it will expand. This expansion, or flex, weakens the braking system as it allows for loss of energy meant for the calipers. With Gruppe-S Stainless Steel Braided Teflon brake lines, this flex is reduced dramatically ? this means quicker pedal response and shorter braking distances.
The fitment portion of the Gruppe-S Stainless Steel Braided Teflon Brake Line includes an original swivel mechanism that allows for spinning to reduce tangling and decrease chances of breakage. This swivel mechanism can also be securely locked into place as well. Brake hose material is made out of a teflon tubing covered with SUS 304 stainless steel finely knit meshed blades. Additional black clear coating finish for protection against mud, gravel, cracking, and debris. Suitable for all seasons. Match and fitment test performed on each vehicle application to determine optimal hose layout for easy to use, correct installation.
02-07 WRX/STi
$99 Shipped
ATE Brake Fluid
ATE Super Blue brake fluid is designed for coping with the extreme demands posed by motor racing, and makes an excellent choice even for street-driven or autocrossed vehicles. Thanks to its outstanding wet boiling point, it has the highest of safety reserves. The dry boiling point is 535F (280C). Wet boiling point is 392F (200C). Exceeds all DOT4 standards, though is not DOT compliant due to the color (blue instead of yellow/gold). Safe for Subaru brake and hydraulic clutch systems. 1 liter container is plenty for bleeding- consider two cans for a full system flush. If flushing your Super Blue, consider using the Gold sold below to flush out the Super Blue, as it makes it very easy to tell when all the old fluid is out of your braking system.
1 Liter Bottle
$20 Shipped
Gruppe-S is offline
Old 04-14-2008, 05:35 PM   #2
Trader Rating: (13)
Default Re: Brake combos from$239-Slotted Rotors$310-All Hawk On Sale-ALK From$175
Helix Coilovers
Helix DNA Sport Coilovers are designed to suit the average vehicle enthusiast. Unlike race coilovers which often exhibit harsh ride characteristics, high cost, and sometimes excessive noise, Helix DNA Sport Coilovers are designed primarily for street service with mild track service in mind. Featuring excellent ride characteristics and lower cost, these coilovers are a fine balance of street function and track service. Fully rebuildable and available in multiple spring rates.
Specs:- Light aluminum Shock Body- 16 Pt Dampening / Rebound Adjustable- Full Upper Pillow Ball Mounts- Camber Adjustable- 8kg / 6kg spring rates
02-07 WRX/ 04 STi
05-07 STi
$899 Shipped
HKS Hipermax RS
1 set left
All HKS Hipermax Suspension systems utilize a mono-tube suspension structure which is a design where both the oil chamber and gas chamber are completely separated inside a single cylinder. Dampening is created as the piston moves up and down inside the cylinder. Dampening is maintained by applying constant load to the cylinder with the use of high pressure gas. There are many characteristics to the mono-tube design, which results in high durability, and comfort even in the harshest driving conditions. Mono-tube suspension structure requires an intense level of research and development as well as advanced manufacturing.
02-07 WRX/ 04 STi
$1499 Shipped
Hey guys now available in the USA!
HKS Hipermax III/ Hipermax III Sport
Now Available!!!
HIPERMAX III
Series Concept: Designed and tuned for street application / daily driving.
With the Hipermax III suspension series, the driver gains increased wheel control with improved performance of all vehicle dynamics and increased driver command in all conditions. Hipermax III combines track-quality control with excellent ride and handling characteristics at real-world street speeds. HKS' all-new Hiper Linear Piston Fluid Channel System damping system creates a positive relationship between piston speed and damping force, making it possible to produce a suspension that provides track-level control and feedback with exceptional ride quality at the same time.
In addition, the Hipermax III is shock-body adjustable (most applications) to allow vehicle height adjustment without affecting spring rate and piston stroke. With the Hipermax III’s range of adjustability, precise corner balancing can be achieved. Chrome-plated cylinder shafts provide excellent durability and newly-design rubber upper mounts reduce harshness. (For most applications, optional spherical bearing mounts are also available for enhanced steering feedback.)
Key Features:
• Hiper Linear Piston – Linear progression piston adjusts oil passages for precise stroke management resulting in smoother valve movements. As piston speed increases, dampening rate linearly increases.
• Strengthened rubber upper mounts – enhanced durability
• Monotube design
• Shock-body length adjustable (most applications)
• 65mm diameter springs – Cold wound and manufactured in-house at HKS to ensure quality and consistency
• Stainless lock nut & ride height adjuster – feature anti-rust & corrosion characteristics for enhanced durability.
• 30-way adjustable dampening
• Hard chrome-plated cylinder shaft
• Non-electrolysis Nickel plated shock bodies provide durability in severe weather conditions.
• Pillowball upper mounts optional on certain applications
• Dustboots standard
• 1 year limited warranty
HIPERMAX III SPORT
Series Concept: Designed and tuned for competition / track.
The Hipermax III Sport series has firmer spring rates and valving to take advantage of the smoother, more consistent pavement of race tracks allowing quicker, more precise transient response and instant direction changes necessary in competition. In addition, the Hipermax III Sport incorporates HKS' all-new Hiper Linear Piston fluid-channel system, shock-body length adjustability (most applications) and ultra-thick chrome plating of the cylinder shaft for excellent durability and reduced stiction (static friction). Spherical bearings, for precise steering and feedback, are standard - but reinforced, rubber upper mounts are available for those seeking reduced vibration from less-than-smooth pavement.
Key Features:
• Hiper Linear Piston – Linear progression piston adjusts oil passages for precise stroke management resulting in smoother valve movements.. As piston speed increases, dampening rate linearly increases.
• Pillowball upper mounts standard
• Monotube design
• 65mm diameter springs - Cold wound and manufactured in-house at HKS to ensure quality and consistency
• Lightweight Aluminum lock nut & ride height adjuster
Hipermax III
Pm For Price
Hipermax III Sport
Pm For Price
KW Variant 3 Coilovers
Free Peak Performance Pillow Ball Top Mounts
The new Variant 3 is state-of-the-art technology for the skilled and experienced driver. The separate and independent compression and rebound damping options allow a truly individual driving set-up. These unique systems with the 3 individually adjustable components, allows for adjustment of the compression of the damper in the low-speed range, while the highspeed set-up, so decisive for driving comfort, has been preset by our engineers. True 2 way. Independently adjustable damping technology -rebound and compression damping. Inox-line stainless steel technology. High-quality components for long life.
02-07 WRX/ 04 STi
05-07 STi
PM for price
*** Peak Performance Mounts are currentley in the final stages of development. Scheduled delivery date for mounts is aprox 4 weeks away. Coilovers will imediately ship out as soon as the order is placed. Once top mounts arrrive we will ship them out ***
Click Here For More Information on the Peak Performance Upper Mounts
Ohlins Flag Coilovers
Ohlins coilovers for street cars dramatically improves traction, handling and at the same time the comfort of the car. The shock absorbers are produced in Sweden and Japan with the specifications, and above all, the development made in Sweden.
All Ohlins shock absorbers are individually tuned for each model and its specific characteristics. They test themselves by fitting shock absorbers to each vehicle and conducting thorough tests. As usual, we believe in trying to combine the hard-to-define ‘feeling’ of our experienced drivers with measurement data obtained from their advanced equipment.
PM For Price
Ohlins Fixed Perched Struts
Ohlins Fixed Perch Strut Kit are a great alternative to coilovers. They are 25 way adjustable, for compression and rebound simultaneously.
Great option for those looking to increase performance with out sacrificing ride quality. This is a choice for weekend warriors that still like to enjoy a comfortable ride on the weekdays.
They are used with stock or after market stock location springs. And with stock style top hats.
Include 2 front and 2 rear struts.
PM For Price
Anti-Lift Kits
Anti-Lift Kit increases your vehicle's dynamics by preventing lift under acceleration while cornering. This helps to diminish understeer during acceleration and in turn allows you to put the gas on earlier in turns.
Perrin PSSR $175 Shipped
Whiteline ALK (Comfort, Med Or Race Bushings) $215 Shipped
Add a Pair of Prothane Urethane Lower Control Arm Bushings for Only $30
Endlinks
Endlinks are CNC machined from high strength aluminum. These make an excellent replacement for your factory plastic endlinks which tend to twist and bend upon corner-loading.
Helix Spherical 02-07 Wagon Only $150 Shipped
Kartboy Drop Links 02-07 WRX/ 04-07 STi $195 Shipped
Perrin Spherical Endlinks 02-07 WRX/ 04-07 STi $230 Shipped
Whiteline Bushing Endlinks 02-07 WRX/ 04-07 STi$230 Shipped
Whiteline Spherical Endlinks 02-07 WRX/ 04-07 STi $230 Shipped
Gruppe-S is offline
Old 04-15-2008, 10:12 AM   #3
Trader Rating: (13)
Gruppe-S is offline
Old 04-16-2008, 10:24 AM   #4
Trader Rating: (13)
Gruppe-S is offline
Old 04-16-2008, 07:54 PM   #5
_
Fav Mod: 2008 STi
Send a message via AIM to Spaceman Send a message via Skype™ to Spaceman
Do you have any coilovers available for an '08 STI? If so, could you please email me some prices. Thanks.
Spaceman is offline
Old 04-17-2008, 10:38 AM   #6
Trader Rating: (13)
The only thing available at this time is Cusco. Special order 6-10 weeks from . Unfortunately pricign has not been finalized at this time.
Thanks
Gruppe-S
Gruppe-S is offline
Old 04-17-2008, 05:53 PM   #7
_
Fav Mod: 2008 STi
Thanks
Gruppe-S
That's a bummer. Thanks though.
Spaceman is offline
Old 04-21-2008, 11:01 AM   #8
Trader Rating: (13)
Sorry but the car is still really new so MFG are still rushing to make parts.
Thanks
Gruppe-S
Gruppe-S is offline
Old 04-22-2008, 11:20 AM   #9
Trader Rating: (13)
Gruppe-S is offline
Closed Thread
