Go Back   IWSTI.com: Subaru STI Forums > STi Marketplace > Vendor Classifieds > Brakes/Suspension/Stiffening
Closed Thread
Old 02-28-2008, 08:49 AM   #1
Car: 04/08STI 95SVX 86E30
Trader Rating: (53)
Default RCE, Whiteline, Swift, Vorshlag, Tokico, TiC, Kartboy
Racecomp Engineering "Regular Guy" Black springs
In stock at TiC!!!!
Great aggressive street rate with a very mild drop to let you focus on suspension dynamics. For the guys on stock STi struts, Ohlins fixed perch struts, or even you guys running around on the Tokico D-specs or AGX or even the guys who have done Koni inserts.
RCE Black springs go for $329, and you can get them from TiC by clicking here.
Turninconcepts.com is offline
Old 02-28-2008, 08:50 AM   #2
Trader Rating: (53)
Default Re: RCE, Whiteline, Swift, Vorshlag, Tokico, TiC, Kartboy
Swift R-spec STi springs
Along the same lines as the RCE Blacks these have a nice aggressive street rate, and a more mild drop than traditional lowering springs (seeing a theme here?). When comparing the two they are slightly stiffer, and have slightly more drop (by about 5mm).
Drop is about 25mm front and rear.
Front rate is about 286lbs
Rear rate is about 275lbs
Price is $309 shipped for free in the US.
You may be wondering - why carry both the swifts and the RCE. Simple - people may be looking for any number of solutions, but when looking for good solutions they should only need to go to one place, TiC.
Oh, and you can snag the R-spec Swifts by clicking here.
Old 02-28-2008, 08:51 AM   #3
Trader Rating: (53)
Tokico strut adjustment extenders
We've got them. If you have D-specs and a sedan then you want them. Trust us.
These go for $30 shipped in the US. Yeah, we know they are cheaper elsewhere, but we didn't see anywhere offering free shipping and handling either so if paying for hidden charges is your cup tea then enjoy it. Us? We're more the coffee type.
To get your adjustment extenders click here.
Old 02-28-2008, 08:51 AM   #4
Trader Rating: (53)
Tokico D-spec fixed perch struts
These are a GREAT solution for the 5x100 02-07 guys looking to replace their stock struts with something better. They work great with any number of lowering springs (the ones mentioned above are a good example).
We've been working long and hard to bring you these, and in the end the only way we can pull it off and be competitive on the price and still offer free shipping in the US is to drop ship them. That's not something we normally do, but since everyone else does we're kind of stuck doing it this way. Since they are a drop ship item if you are in a hurry to get them then contact us first so we can check the stock levels.
If you plan on using 04-07 rear tophats (to use the springs listed above for example) then you MUST use a spacer for the rear. Fortunately, we also have the scooby921 strut spacer which is designed for this exact purpose (more on that one in a bit).
The Tokico D-specs go for $540 shipped in the US, and you can get them by clicking here.
I don't have a good pic of them. Perhaps someone will be kind enough to help us out in that regard.
Old 02-28-2008, 12:38 PM   #5
Trader Rating: (53)
Vorshlag front camber plates are back in stock
KW guys - if you're running the stock 60mm ID springs then these are a GREAT camber plate for you. In fact, the stack height is so short that we had one KW user who had to raise his spring perches by 1/2" to get back to his previous ride height.
AST and Whitline G4 guys, these are a GREAT camber plate for you too!!!!
  • Steel plate to resist any bending forces from your suspension.
  • Steel bearing carrier
  • Some of the largest spherical bearings offered on any camber plate built
  • Integrated sealed bearing in the included upper spring perch (sized for 60mm ID springs) to allow for free rotation of the spring to help prevent binding
  • Incredibly short stack height of about 37mm to allow for tons of bump travel
  • Backset of camber slots to add approximately .75* of caster
These go for $425 shipped in the US, and you can get them by clicking here.
Old 02-28-2008, 06:57 PM   #6
If in doubt, flat out
Trader Rating: (23)
where are the vorshlag rears or should i say when will they be available?
snorky is offline
Old 02-28-2008, 07:05 PM   #7
Sold My Soul For Mods
Car: '05 CGM STi
Fav Mod: Track Time
Trader Rating: (14)
Clint, do you know what size the hex head on the tokico adjusters is? I have an idea...
BoostJunkie is offline
Old 02-29-2008, 04:00 AM   #8
Trader Rating: (53)
I'm waiting for an update from Vorshlag. I know I sound like a broken record, but we should be getting close.
I think I know the idea you've got, but I haven't figured out a way to keep them bouncing out of the KW dampers. We need something to hold them in place.
Old 02-29-2008, 11:12 AM   #9
Trader Rating: (53)
Whiteline ALK SPORT back in stock
As the title says, they are back in stock. $200 shipped for free in the US.
You can get them from TiC by clicking here.
Old 03-06-2008, 11:48 AM   #10
Trader Rating: (53)
A couple more sets of RCE Black springs just arrived.
Old 03-06-2008, 03:09 PM   #11
Fav Mod: 57fs
wheres the KB stuff
wrxcelration is offline
Old 03-07-2008, 07:31 AM   #12
Trader Rating: (53)
Originally Posted by wrxcelration View Post
wheres the KB stuff
Haven't listed it yet, but we do have it on our site.
Old 03-07-2008, 07:34 AM   #13
Trader Rating: (53)
Whiteline roll center adjustment kit
Help to correct the geometry of the front end of your car by lowering the outboard connection of the control arm. This will keep you in the "nice" camber range of suspension movement for longer.
Also includes new outer tie rod ends to correct the bumpsteer that's changed with lowering the pickup on the control arm.
KCA313 Whiteline RCA kit - $175 shipped for free in the US.
You can pick it up from TiC by clicking here.
Old 03-10-2008, 05:12 AM   #14
Trader Rating: (53)
Kartboy STi rear endlinks
Plain and simple, you need these. The stock endlinks are awful, and it would be a benefit to any STi owner to get new and stronger rear endlinks.
Kartboy's STi rear endlinks ship for free in the US and the price is $115. You can pick them up from TiC by clicking here.
Old 03-14-2008, 11:41 AM   #15
Car: '05 CGM STi
Fav Mod: Track Time
Trader Rating: (14)
So they are the right size but they won't stay put? I wonder if a dab of blue loctite would do the trick without making it permanent... I may have to give this a try.
Closed Thread
