Go Back   IWSTI.com: Subaru STI Forums > STi Marketplace > Private For Sale Classifieds > Brakes / Suspension / Stiffening / Wheels / Tires
Old 03-24-2008, 12:17 PM   #1
HowTo Contributor
Car: 2008 DGM (BBS+Navi)
Fav Mod: stock FTL?
Default SOLD!: (MD) brand new Whiteline Max-C camber plates
SOLD!
Got these a few months ago but never got around to installing them. I'm planning to sell the car in a few months so rather than installing them only to take them back off in a few months I'm going to sell them new and still unused.
About the plates:
The Whiteline Max-C adj. strut top mounts are an engineered solution toward keeping your camber and caster in the "sweet spot" for you Subaru.
After extensive suspension modeling Whiteline has come up with a solution to allow you to balance caster and camber at the same time. By moving camber toward 0* you gain static caster, while as you move static camber toward more a more negative inclination you move caster toward 0*.
These are the motorsports version which means if you are on coilovers you can get up to -5 degrees of camber, however you're limited to about -3 degrees on the stock struts or stock strut replacements (the stock spring size gets in the way.)
Forgive the quarter and Gatorade bottle in the picture, was using them as a size comparison. Also note that the strut spacers are missing in this photo, they weren't in the box originally (Whiteline forgot them) but the vendor I got them from quickly shipped me the spacers from another set of plates they had in stock, so I have EVERYTHING that you need and it's all brand new and unused!
$275 shipped. I'm in the Baltimore/DC area near Arundel Mills if you want to do local pick up and save a few bucks on shipping. PM me if you're interested.
Old 03-28-2008, 11:58 AM   #2
HowTo Contributor
Fav Mod: stock FTL?
Default Re: FS: (MD) brand new Whiteline Max-C camber plates
Sale pending.
Old 04-02-2008, 05:07 PM   #3
HowTo Contributor
Fav Mod: stock FTL?
Back up for sale.
Old 04-02-2008, 09:27 PM   #4
Car: 2007 STI OBP
Fav Mod: Suspension
These plates are for coilovers only...correct? i'm in the market for some Whiteline camber plates, but i'm looking at the street version due to their design for struts.
i'm still on stock sti struts
Boxer4u is offline   Reply With Quote
Old 04-03-2008, 04:17 AM   #5
HowTo Contributor
Fav Mod: stock FTL?
They will work with the stock struts as well. (I was going to use them on some JDM struts I have.)
Because the stocks strut/spring size is larger than a coilover you are limited to the street version's camber/caster ranges because if you try to go over that you'll end up hitting the springs.
This is what the folks @ TiC told me when I was looking at them anyway.
Old 04-03-2008, 06:32 AM   #6
Car: 05 OBP STi
What is the part number?
Kurokaze is offline   Reply With Quote
Old 04-03-2008, 06:47 AM   #7
HowTo Contributor
Fav Mod: stock FTL?
KCA251M
Whiteline Max-C adj. strut top mounts - sport Turn In Concepts
$360 new. Wow they've jumped in price...
HTML code is On
