Go Back   IWSTI.com: Subaru STI Forums > STi Marketplace > Vendor Classifieds > Accessories & Misc
Old 04-03-2007, 03:29 PM   #1
Trader Rating: (45)
Send a message via AIM to Z1 Performance
Default All in stock Electronics! Gauges, Engine Management, Boost control, MUCH more!
We've just received a large order of our first batch of the STRI Guages.
These gauges combine all the best features of many popular meters on the market, in a cost effective solution.
There are several different gauge types offered, which allows you to set up your interior how you want!
The first type is called the DSD Line.
These feature a Micro Stepper Motor, ensuring quick reaction and accurate measurements.
DSD Line FUNCTION
- User Preset Warning
- Peak Recall
- Auto Self Calibration
- 270 Degree Sweep
- Short circuit auto detect
- Sequential open / closing mode
- Dimmer function
- High brightness LED
- Light weight aluminum casing
- All sensors included
- Mounting solution included
- Available in smoke lens - amber or white LED backlight (similar look to the Defi BF
- Available in 52mm or 60mm size
Black Face/White Lighting/Clear Lense
http://www.z1auto.com/Images/striboost1.jpg
White Face/Amber Lighting/Clear Lense
http://www.z1auto.com/Images/strics3.jpg
Smoke Lense/Amber Lighting
http://www.z1auto.com/Images/dsdslmsmokedonamber.jpg
No Control Unit Needed! And, prices are VERY reasonable (see links below)!!!!
The DSD series comes in 52mm or 60mm, Imperial Measurement (Boost in PSI, Temperature in Fahrenheight
There also is another series (less expensive!) called the X Line, which I'll have pics of tomorrow
Here is a copy of their ad in Option Magazine (Japan)
http://www.z1auto.com/images/stri-japan-option.gif
Info for the various gauges can be found on our site here:
52mm with Smoked Lense: http://www.z1auto.com/prodmore.asp?m...mt&prodid=2615
60mm With Smoked Lense: http://www.z1auto.com/prodmore.asp?m...mt&prodid=2627
52mm with Clear Lense: http://www.z1auto.com/prodmore.asp?m...mt&prodid=2603
60mm with Clear Lense: http://www.z1auto.com/prodmore.asp?m...mt&prodid=2609
Last edited by MKIVSupra : 05-19-2007 at 06:24 PM. Reason: Title change requested by the OP
Z1 Performance is offline   Reply With Quote
Old 04-03-2007, 03:44 PM   #2
Car: 06 White/Gold STi
Fav Mod: The Driver Mod
Do these match the sti cluster as well as the Defis? Is the sweep the same? What can ya do for me on a 3 pack combo 52mm, amber, smoked, 30 psi boost, egt, and oil temp?
scoobtothenoog is offline   Reply With Quote
Old 04-04-2007, 01:40 PM   #3
Trader Rating: (45)
They are a terrific match for the STi cluster
Check your PM in a bit!
Old 04-07-2007, 12:19 PM   #4
Trader Rating: (45)
installed!!!
Old 04-07-2007, 01:16 PM   #5
Car: 07 WRX STi Limited
Fav Mod: Trunk Monkey
Do these do the startup dance?
JiveMasterT is offline   Reply With Quote
Old 04-07-2007, 02:15 PM   #6
Trader Rating: (45)
yep..they have an opening and closing "ceremony"
Old 05-04-2007, 02:06 PM   #7
MORE GAUGES!
--AEM--
Wideband Air Fuel Ratio Meter
~Bosch wideband sensor included, along with mounting bung and wiring harness.
~24 Color-coded LED display lights provide immediate reference to engine’s air/fuel ratio (AFR) or Lambda
~Integrated three-digit display reveals AFR or Lambda in real time
~User-programmable 0-5v analog output included for use with data loggers and ANY engine management system
~Ideal AFR monitoring tool for carbureted applications and engine dynamometers
~Does not oscillate AFR like narrow band sensors
~Serial data stream included for output of AFR (RS 232)
~Accurate to 0.1 AFR
~Includes black and white face, as well as black and silver bezels, all ~included with the gauge so you can tailor it to match your interior!
Tru Boost
this beautiful boost gauge will look perfect inside your impreza. very high quality, tons of nifty features(see below) and...
FREE SHIPPING
~Complete stand-alone boost controller gauge
~On-board pressure sensor included for boost levels up to 29 PSI (can control up to 75 psi with the optional sensor)
~Two user selectable units
~Peak boost memory
~User selectable over boost alarm with overboost shutdown
~User scaleable bar graph display
~User selectable waste gate delay for quick turbo spool
~External warning lamp driver
~No external interface required for programming
~Easy to install harness allows for quick and easy installation
~Boost hose and fittings included for easy hookup to on-board pressure sensor
~TURBO TIMERS~
--Blitz--
need a little cool down after romping on the subie? Blitz has you covered for any kind of turbo timer you could want. TONS of info here:
http://z1auto.com/prodmore.asp?model...gmt&prodid=438
(prices on the site do not necessarily reflect the prices you will recieve. PM for details!)
--Apexi--
another very functional nice looking piece. silver or black.
--GReddy--
The new GReddy Full Auto Timers pack tons of features in one economical, compact unit. In addition to two standard programmable count down presents (P-1, P-2) our timer also has two Auto Timer modes,(A-L, A-H) which estimates the driving RPM according to the vehicles alternator signal and then recommends a count down time. And now there is a Stopwatch/Lap Time mode, and Attack mode. There is also a built in Voltmeter and Speedometer. Still standard are the optional Parking Brake and Speedo Safety hook-ups. Available in silver, white or black.
--HKS--
Turbo Timer Type 0
Available in silver or black.
multiple preset times, audible alarms, up and down control buttons, power and memory buttons, and an easy to read back-lit digital display. Additionally, new models feature a more compact polyurethane casing, back-lit button controls, a larger dual color LCD panel, a volt monitor function to monitor battery power, and an auto mode feature that adjusts engine idle time according to the most recent driving pattern.
BOOST CONTROLLERS
--HKS--
free shipping
I personally use this boost controller in my own car. Very user friendly...very easy to adjust, easy to read display, easy to install, and packed with so many features it will make your head spin:
http://z1auto.com/prodmore.asp?model...mt&prodid=2268
(prices here may not necessarily reflect what you will pay. PM for details!)
--GREDDY--
Profec B Spec 2
II's basic function to increase boost is as easy as the original, with an added built in boost pressure display and optional features like real-time, peak or last boost display (in either kPa or PSI). There are optional warning and boost limiter functions that can be programmed to offer much more control. The two presets values can be stored and are executed by a larger capacity inline solenoid valve. This unit does not require extensive programming and is ideal for low to high boost levels for single or twin turbos with actuator or external wastegates. The GReddy PRofec B-Spec II is available in black or silver
--APEXI--
AVC-R
the premium closed-loop electronic boost controller on the market. The AVC-R allows flexible control over virtually every aspect of boost control and adds new innovative functions such as injector pulse monitoring and gear specific boost control. Some key functions include:
Highly flexible boost control with revolutionary new functions
Vacuum Fluorescent Display (VFD).
RPM-based boost and solenoid duty cycle control
scramble boost
self learning mode
2D ghost map trace mode
analog display mode
real time replay and peak hold data modes
The AVC-R utilizes an ultra-fast microprocessor and a high quality solenoid valve to control boost. The result is ultra-fast response and accurate, stable boost control
Durran@Z1Performance is offline   Reply With Quote
Old 05-04-2007, 02:15 PM   #8
Car: 04 Aspen White STi
Fav Mod: exhaust powered intake
Default Re: New STRI Gauges!!!!
price for boost and oil pressure amber 60mm black face, thanks
B4RSTiwsnc is offline   Reply With Quote
Old 05-05-2007, 04:20 PM   #9
ENGINE MANAGEMENT
--cobb--
Accessport Version 2.0
--turbo xs--
UTEC
DEFI SUPER SALE!!!!!!
you wont find better deals...anywhere. PM for pricing thats so good, even your mom will want some gauges.
available in imperial and metric, white and amber, 52 and 60mm, with many mounting options, and any other way you'd prefer. Let us hook you up.
beautiful gauge pod:
anything else DEFI you need, ask away!
Old 05-05-2007, 04:21 PM   #10
30psi
Old 05-05-2007, 04:25 PM   #11
You got it.
Durran
Old 05-09-2007, 01:36 PM   #12
bumpity.
Old 05-09-2007, 02:32 PM   #13
Car: 06 STI (blue)
Fav Mod: car itself ;)
price for boost (30)and oil pressure,fuel pressure, amber 60mm black face,+ pod+ all needed hardware shipped to 02673 . tnx
Originally Posted by Durran@Z1Performance
bumpity.
Want3D is offline   Reply With Quote
Old 05-11-2007, 03:03 PM   #14
PM sent Want3d!
Old 05-11-2007, 03:20 PM   #15
Car: 04 WRB STi
Fav Mod: Shooting 5ft flames =)
price of boost, EGT, and fuel pressure 60mm, black face with amber light and smoked lens sent to 34119. Thanks Durran
BlackNBlueSTi is offline   Reply With Quote
