View Single Post
Old 04-11-2004, 03:38 PM   #8
Rev
STI Guru
Car: 06 V70R
Send a message via AIM to Rev
Default best radar detector?
Excerpt from the manual, Front Strut Install:
B: INSTALLATION
1) Install the strut mount at upper side of strut to
body, and then tighten with the nuts.
Tightening torque:
20 N·m (2.0 kgf-m, 14.5 ft-lb)
2) Position the aligning mark on camber adjustment
bolt with aligning mark on lower side of strut.
Install the strut to housing with a new self-locking
nut.
NOTE:
While holding the head of adjusting bolt, tighten the
self-locking nut.
Tightening torque:
175 N·m (17.8 kgf-m, 129 ft-lb)
3) Install the ABS wheel speed sensor harness to
strut.
Tightening torque:
33 N·m (3.4 kgf-m, 24.3 ft-lb)
4) Install the bolts which secure the brake hose to
strut.
Tightening torque:
32 N·m (3.3 kgf-m, 23.6 ft-lb)
5) Install the wheels.
For the rear struts:
B: INSTALLATION
1) Secure the strut mount to vehicle body using a
new self-locking nut.
Tightening torque:
2) Secure the rear strut to housing using a new
self-locking nut.
Tightening torque:
200 N·m (20.0 kgf-m, 145 ft-lb)
3) Install the brake hose to lower side of strut, then
insert the brake hose clip.
CAUTION:
• Check the hose clip is positioned properly.
• Check the brake hose for twisting, or excessive
tension.
• Do not subject the ABS wheel speed sensor
harness to excessive tension.
4) Lower the vehicle and tighten wheel nut.
Tightening torque:
90 N·m (9.2 kgf-m, 66 ft-lb)
5) Install the rear seat backrest and rear seat cushion.
(Sedan model)
6) Install the strut cap to rear quarter trim. (Wagon
model)
For instance, better get the FSM if you want to do it yourself. 870 PDF documents worth of information for $20.
