View Single Post
Old 12-30-2005, 11:15 AM   #1
WolfPlayer
Moderator & ECU Tech
My StuffSubaru Parts
Fav Mod: mo boostaz
IWSTI Addict since: Jun 2004
Default Tales of a Daily Driver (Headers coated! Post #600)
My Subaru 2005 STi Modifications
Yes, this car gets driven every day. Yes, I bought it new in 2004. It gets groceries, delivers kids to school, and I depend on it for work.
I have links to pics on my site for most modifications. I usually have lots of pics. If you want to see more, simply backup to the directory in the URL. I have file browsing enabled and there are lots of pictures of each thing.
Wheel Horsepower Dyno (SAE Corrected [which reduce whp by 10])
Intake
1. APS 70mm CAI
2. APS Turbo Inlet Pipe
3. APS DR525 Front Mount Intercooler with T-Bolts
4. Polished/Knife-edged Throttle Body
5. Ported Stock STI Intake Manifold
6. TGV Deletes by pnpheads.com
7. KSTech 8mm Phenolic Spacers
8. APS Dual-Vent BPV/BOV
9. Thermo-Tec Cool Tube
Old Intake mods removed:
a. Samco Turbo Outlet to Intercooler hose
b. Samco Intercooler to Throttle Body hose
c. Samco Airbox Hose
Exhaust
1. APS Full 3" Turbo-Back Exhaust with Metallic Substrate Converter (removed)
2. JetHot 2000 Coated APS downpipe heatshield
3. Kartboy Exhaust hangers
4. Full-Race 1.5 scroll Header and Uppipe - SwainTech coated, ACL Heatshielding (Waiting to install)
Engine Management
1. Cobb AccessPort
2. Cobb StreetTUNER, custom tuned by me.
3. ECUFlash, RomRaider, and Tactrix
Turbo
1. Stock VF39 (no mods, never been removed)
  • Deadbolt SZ49 (Waiting to install) - my budget turbo. Do I want to run this specific turbo? No. But, a man of my little financial means has to make hard decisions. I got this turbo for a great price from a guy who I trust. It's the crappy 7cm housing but I have some tricks up my sleeve.
2. JetHot 2000 Coated stock heatshield
3. SPT Heatshield
4. GM BCS (Removed Perrin EBCS) in place of stock wastegate solenoid
5. Custom boost-controlled fully automatic intercooler sprayer
6. Removed: 11.5lb Wastegate helper spring (the spring breaks on a regular basis so I don't advise using it anymore)
7. Custom Turbo Oil Feed + AVCS line.
Engine
1. Killer B Motorsports Ruggedized oil pickup (Waiting to install).
2. Killer B Motorsports Aluminum oil pan (Waiting to install).
Fuel
1. Walbro 255ltr/hr Fuel Pump
2. Nismo/JECS 730cc Injectors, blueprinted by WitchHunter
3. APS Fuel Rails
4. SX-Performance Regulator /w Aeromotive gauge and Aeroquip Fittings
Ignition
1. NGK LFR7AIX one-step colder plugs
Cooling
1. 160d Motorad Thermostat
2. SPT Radiator Shroud
3. Throttle Body Coolant Bypass
Brakes
1. Hawk HPS pads
2. Goodridge G-Stop DOT approved stainless steel brake lines
3. ATE Super Blue fluid
Suspension
1. Whiteline 27-29 Front Swaybar [BSF36XXZ]
2. Whiteline 22-26 Rear Swaybar [BSR37XZ]
3. Whiteline Spherical Bearing Front Endlinks [KLC39]
4. Whiteline Spherical Bearing Rear Endlinks [KLC047]
5. Cobb Adjustable Rear Swaybar Brackets
6. Whiteline Steering Rack Bushings
7. SPT Front Strut Tower Bar
8. SPT Rear Strut Tower Bar
9. SPT Lower Chassis H-Brace
10. TIC Fender Cowl Braces
11. 18 x 8 Gunmetal Rota P1 Rims with Kuhmo ECSTA SPT tires [Summer]
12. Stock BBS Rims with stock RE070s [AutoX]
13. 17 x 7 Sport Edition A7 Rims with Blizzak LM25 Tires [Winter]
14. Maxed stock negative camber [-0.7] (nhluhr special)
Electrical
1. Innovate Motorsports LC-1 Wideband Oxygen Sensor with custom control
2. Omori 45mm Boost Gauge in stock pod
3. Omori 52mm Electrical EGT, Oil Temp, and Oil Pressure in WRXtra modified stock SOA housing.
4. TurboXS Knocklite
5. Greddy oil filter sandwich adapter for Oil Temp and Oil Pressure
6. StaticX Grounding Kit
Transmission / Driveline
1. SPT Group-N Engine Mounts
2. SPT Group-N Transmission Mount
3. SPT Group-N Rear Differential Mount
4. Kartboy Pitch Mount
5. KartBoy Front Shifter Bushing
6. KartBoy Rear Shifter Stay Bushing
7. KartBoy Transmission Crossmember Bushings
8. TIC Shift Linkage Bushings
9. TIC 6MT Pivot Bushings
Fluids
1. Motul Gear 300 Synthetic Transmission Fluid
2. Renewable Lubricants 5W-40HD Motor Oil
Interior
1. AutoSpeed Dead Pedal
2. S203 Hazard Button
3. JDM Auto Intercooler Spray Switch
4. SOA HomeLink Auto-Dimming Rearview mirror with Compass
5. SOA Rear Cargo Net
6. SOA Rear Cargo Tray
7. DUAL Simpson Child Safety Seats
8. AndrewSS custom camera mount
9. Autozone mats to trap my dirt/water
10. Trunk Monkey
11. WC Lathe Works 2.125" Copolymer Shift Knob
Sound
1. Jazzy Electronics Aux-In board + PAC Ground Loop isolator
2. PAC IC-AV2 iPhone 3G connector (charge and play with one connection)
3. 2007 Aux-In dock
4. 10” Polk Subwoofer fed by a 400W U.S. Acoustics Amplifier
Exterior
1. WRX Hood Scoop (yay for smaller scoops!)
2. Dewinged! (thank goodness, I don't need no picnic bench on my trunk for taking kids to school )
3. Curt Hitch (woo! now I can carry my bike out to the trails on my Thule hitch mounted carrier )
4. JDM Foglights
5. Pillarless front grill
6. Debadged trunk except for the STI emblem
7. SOA SPT license plate frame
Miscellaneous
1. Custom Hood Scoop Screen
2. SPT Oil Filler Cap
3. SPT Battery Hold-down
4. FilterMag Filter Magnet
5. Fumoto Engine oil drain valve
6. AMW Catch Can for Breather Vents
7. AMW Catch Can for PCV
8. Relocated Factory Upgraded Security System Horn
9. Hella SuperTone Horns
10. SOA Engine Block Heater
Next Round of Modifications ...
SZ49 Goodness. I got a great deal on a used turbo so it is now time to upgrade!
Full-Race header and uppipe. Oh yea. This thing is the awesomeness ...
Click image for larger version
