Re: Waramp's 2011 Subaru WRX STI - 19" Gold Advan RS & ChargeSpeed CF Kit on its way! Racecomp Engineering Install -------------------------------------------------------------------------------- Install List- Racecomp Engineering Steering rack bushings
- Racecomp Engineering Yellow Springs
- Racecomp Engineering 25mm Front Sway Bar
- Racecomp Engineering 25mm Rear Sway Bar
- Test Fit Some Matte Black Rotas 18x9.5 +40, 265/35/18 with 2.75" of lip!
Alignment:- Front Left/Right Caster 6.40/6.40
- Front Left/Right Camber -1.50/-1.50
- Front Left/Right Toe 0/0
- Rear Left/Right Camber -1.60/-1.60
- Rear Left/Right Toe 0/0
Arriving at Dales Alignment (Canadian distributor for Racecomp Engineering) first thing in the morning to meet with Jason Trentini. Stock Springs vs Racecomp Engineering Yellow Springs Stock 22mm Front Sway Bar vs Racecomp Engineering 25mm Front Sway Bar Preparing to hoist the car. Getting ready to start the install. This little guy (stock) allows a lot of camber adjustment for the front. This would be considered "suspension porn" to some people Racecomp Engineering Yellow Springs are now installed Racecomp Engineering 25mm Rear Sway Bar Racecomp Engineering 25mm Front Sway Bar After installing all the Racecomp Engineering hardware we decided to test fit some Matte Black Rotas 18x9.5 +40, 265/35/18 with 2.75" of lip!. The STI is going into the bay to get an alignment. Another Angle Another Angle Getting the Alignment done. Picture of the rear after the alignment A special thanks goes out to Jason Trentini. I now know why he's considered by many to be one of the top Subaru suspension guru's.
__________________ 2011 Subaru WRX STI - Sport Tech Sedan Mad Dad / JPM Coachworks / TWM Performance / WC Lathe Werks / Blue Bat Overlays / Perrin Performance / Kartboy/ Subtle Solutions / Charge Speed / Advans / Kics / SMY - Cluster Maker / Rally Armor / Racecomp Engineering
