so i snapped mine while changing the rear diff oil.
there was actually 2 nuts there, 1 for the sensor seat, 1 for the actual sensor. i removed the actual sensor since i only had a 19mm deepsocket and nothing fit the other nut. while re-tightening it per 60nm torque spec i guess they were referring to the second nut and not the actual sensor.
anyone know the part number for the temp sensor,
also whats the size socket for the main nut that goes into the differential where the sensor sits. i tried a 21mm as the largest size i had and that didn't fit.
Throw me in the "snapped sensor" club. I am soooo pissed!! Oh well, live and learn. Anyone know the torque specs for that sensor? My service manual said 44.3 ft/lbs but I am living proof that is WRONG!!! I did not even get close to 44.3 ft/lbs before I felt $120 slip through my hands.:tdown:
Mine has a paint mark across the sensor to the housing (form the factory). I was about to snap it too I think before I chickened out of tightening it to spec. So I just lined it up to that piant mark..
I'm glad I'm not the only one that did this, I felt like a complete idiot today. I also didn't have a deep 22mm to get to the larger drain plug so I used the 19 to get the sensor out and when I put it back in I was also torquing to the wrong spec apparently because it snapped really easy
Luckily I found a plug to put in place of the sensor until I buy a new one. I guess I'll have the rear diff temp light staring at me for a while :lol:
They should have made a note in the specs that the sensor requires way less torque than the bolts. Hopefully you can glue yours back together...mine shattered into a bunch of pieces
It was a while ago when I replaced the rear diff fluid, but I can't recall doing anything other than unplugging the sensor; I didn't touch it otherwise...hmmm
I broke mine too when installing Perrin rear diff cover. The cost sucked but it took like three months to get it. I just threaded the busted off end in with some sealant to hold me over.
I tried to do that with mine but my sensor cracked on the threads and I didn't want to risk it. Luckily, I found a nice little plug from ACE hardware in their misc bolts/screws section. It was in a box labeled automotive plugs. That has worked out for me until I grab another sensor. Just make sure you put some loctite on the plug if you use my quick fix.
Has anybody found the CORRECT torque for the temp sensor into the nut/well? I didn't break mine, but i did remove it instead of the two pieces as one. Can't believe the service manual doesn't even list them as separate parts!
I think this is where some people are running into problems. I didn't have a deep 22mm socket so I used a 19mm to remove the sensor instead. And I would assume the sensor torque is something like have of the torque the plug calls out...it's VERY fragile.
definitely go out and spend the $5-10 on the 22mm deepsocket if you don't have one so you can undo the primary plug.
that sensor is ridiculously fragile and costs too dam much to risk breaking it.
I just snugged the sensor into the well with a normal size 3/8 handle and when i checked the torque it was ~ 30 NM. So half of the well nut torque should be good.
OMG.. So i thought i'd do the nice thing and replace the rear diff fluid before selling my car and I do the same f***ing thing! Ugh.. how long will it take Subaru to get me this part?!!?
If your local Subaru dealer doesn't have it in stock, shouldn't take more than a week to get it. I've ordered all kind of things from local dealerships and it's never taken more than a week to come in if they had to order it.
So iwas just changing the rear diff fluid and really wish I read this thread. I over torqued the sensor and it sliced right off. The threads from the sensor are still actually in the bigger bolt. I am going to buy a new sensor but im not sure if I can get the old sensor out of the bigger bolt. Any ideas?
It's super easy. There's a couple threads that have pics in the How To section but it's basically just taking the two plugs out of the rear diff, drain all the fluid, then put the bottom plug back in and fill the fluid until it starts coming out the top hole and then plug the top hole up and you're done.
It's a pain getting the fluid back into the rear diff so I bought this small $10 hand pump that screws on the top of like any fluid bottle and I just use that to pump the fluid into the rear diff.
Always ask if they can give you a better price. Especially if you have a general idea of what it should cost.
All the part's guys I ever dealt with either tell me they'll give me the normal price up front, or if they quote their high margin price I ask them and they usually will drop it.
no... I just did a search... didnt notice the GR section...
ignore the tard in the thread :-D
Related Threads
IW STi Forum
4.1M posts
121.3K members
Since 2001
