View Single Post
Old 08-28-2008, 12:52 PM   #114
twiSTies
IWSTI Addict since: Oct 2005
Default Re: My RaceComp Engineered 2005 STi (Updated pg. 4 I can has Recaros)
Power:
APS 65mm Intake
Gimmick Motorsports MAF Hose
Gimmick Motorsports Turbo Inlet
Static X VF-39 Turbo Wrap
Cobb Turbo Heatshield
AREA1320 Ported Intercooler Y Pipe
Perrin Lightweight Crank Pulley
Perrin Equal Length Header (Coated)
Helix Catted Downpipe
Borla XR1 Catback
Walbro 255 Fuel Pump
Prodrive 3-Port EBCS*
Cobb AP w/ Street Tuner
Innovate LC-1 Wideband Kit*
TopSpeed PROtuned 306awhp/341awtq with the Helix dp, a K&N Typhoon, and a 3" ebay catback.
AREA1320 Sticker +50hp
Driveline:
Kartboy Exhaust Hangers
TiC Rear Differential Bushings
TiC Subframe Outrigger Bushings
Kartboy Botox Bolts
Whiteline Steering Rack Bushings
Kartboy Pitch Stop Mount
Kartboy Front Shifter Bushing
Cobb Double-Adjustable Short Throw Shifter
TiC Shifter Linkage Bushings
TiC Shifter Pivot Bushing
TiC Rear Shifter Stay Bushing
TiC Transmission Crossmember Bushings
Suspension:
RaceComp Engineering Tarmac IIs 500/400
Vorshlag Front and Rear Camber Plates
RaceComp Engineering 25.5-28.5mm Front Swaybar
RaceComp Engineering 25.5-28.5mm Rear Swaybar
Kartboy Front and Rear Swaybar Endlinks
Whiteline 'Comfort' Anti-Lift Kit
Whiteline Roll Center Adjuster Kit
Group N Lateral Links Bushings*
Group N Trailing Arms Bushings*
Brakes:
Ferodo DS2500 pads
DBA 4000 Series Front Rotors
Technafit SS Lines
Perrin Brake Master Cylinder Brace
ATE Super Blue Fluid
Chassis Stiffening:
Carbing Front Subframe Brace
CL Development X-brace
TiC Fender Braces
Interior:
EVO VIII Recaro Driver and Passenger Seats
Wedge Engineering Seat Brackets and Height Adjusters
JDM S203 Hazard Button
Autospeed Dead Pedal
JDM Auto Intercooler Spray Button
Prodrive Floormats
2007 OEM Radio w/ Aux. Input and Sub
2007 OEM Sirius SAT Radio Box
10th Street JDM Alcantara Shift Knob
Exterior:
JDM Rear Spats
AREA1320 Painted and De-Badged Front Grill
BeatRush Titanium Belt Cover
Greddy Titanium Radiator Cooling Plate
AMS lightweight battery kit to reduce weight
Grimmspeed Hood Dampers
Black O.Z. Ultraleggera 18x8 wheels w/ 245/40/18 Dunlop SP Sport 600 tires (Summer)
Stock BBS w/ 225/45/17 Toyo Proxes 4 tires (Winter)
* - waiting to be installed or on order.
** - waiting to be removed.
Future Mod List Goals:
-Perrin GT30R .82 rotated turbo kit w/ crinkle red piping
-Perrin Stealth FMIC with crinkle red piping
-Perrin Blow-Through Boost Tube
-Perrin CAI Extension
-Cobb AP V2
-Deatschwerks 850cc injectors
-TGV Deletes
-Cosworth Intake Manifold
-ACT clutch upgrade
-ACPT CF Driveshaft
-DBA 5000 front brake rotors
-DBA 4000 rear brake rotors
-Carbing Under Panel
-APR Strut Tower Bar
-Group N Engine Mount
-Group N Trans Mount
-Upgraded Oil Pickup
