Interior Power/ground/etc for aftermarket gauges - Subaru Impreza WRX STI Forums: IWSTI.com
STI Products
Go Back   STI Forums > > > Interior Power/ground/etc for aftermarket gauges
Old 04-20-17, 01:31 PM   #1
raisingAnarchy
Advanced Contributor Level 3
Car: CBS '16 STI
Fav Mod: Driver mod
raisingAnarchy will become famous soon enough
Default Power/ground/etc for aftermarket gauges
I bought Perrin oil temperature and pressure gauges. I'm curious if anyone has suggestions for which harness to tap into for power and dimming on the 15+ chassis. I've read many posts on this forum and others that suggest the clock harness; however, my concern is if that would hold true for the new multi-function display.
Also, is there a way to make adding additional gauges easier? Or do I need to splice each gauge into the same tapping point as they come? I've seen people mention add-a-fuse before and that seemed promising.
raisingAnarchy is offline
Old 04-20-17, 02:00 PM   #2
d0zxmustang
Feedback Score: 5 reviews
Fav Mod: proper maintenance
d0zxmustang will become famous soon enoughd0zxmustang will become famous soon enough
Default Re: Power/ground/etc for aftermarket gauges
add-a-fuse is what I used for power. Piggy-backed off one of the switched accessories (cant remember exactly which one, I think it was rear defrost maybe). As far as the dimming, I spliced into the dimming wire on the radio harness.
d0zxmustang is online now
Likes 1 Dislikes 0
Old 04-20-17, 02:08 PM   #3
SubySal
Advanced Mastery Level I
Feedback Score: 1 reviews
Fav Mod: everything done so far
SubySal will become famous soon enoughSubySal will become famous soon enough
I have a GD so my wiring method may not be useful to you, but I used the cigarette lighter wires for acc power, illumination, and ground. I derived constant power from an open relay port in the fusebox under the dash. By the way I love my Perrin gauges!
SubySal is online now
Likes 1 Dislikes 0
Old 04-20-17, 03:07 PM   #4
raisingAnarchy
Car: CBS '16 STI
Fav Mod: Driver mod
Your post about the Perrin gauges is what made me pull the trigger. I like their functionality a lot!
And that's my issue with a lot of the existing information on this site about installing gauges is there are a TON of walkthroughs on how to install a boost gauge on a GD chassis, but now the new chassis have all this touchscreen crap with extra screens that complicates the wiring.
Old 04-20-17, 03:10 PM   #5
raisingAnarchy
Car: CBS '16 STI
Fav Mod: Driver mod
Thanks for the info. The good thing is these Perrin gauges only draw 0.3w each according to the docs. Is the dimming wire bundled into the radio harness directly? Do you happen to remember which wire specifically?
Old 04-20-17, 03:31 PM   #6
d0zxmustang
Yes, its in the radio wiring bundle. The illumination wire should be the "violet" wire, and should be pin 1 (may be a different pin if you have navigation).
Old 04-20-17, 07:36 PM   #7
mheyman
Feedback Score: 4 reviews
Fav Mod: Nomal wear & tear
mheyman is a jewel in the roughmheyman is a jewel in the roughmheyman is a jewel in the roughmheyman is a jewel in the rough
Do the opening ceremonies of multiple Perrin gauges operate in sync?
mheyman is offline
Old 04-20-17, 08:24 PM   #8
SubySal
Cool! I really like the simplicity in their functionality as well. I can recall peaks very quickly after a run. Before I had to hold down buttons and such.
OK yea. I didn't think about that. I imagine the wiring on the new cars is way more complex. Still though the cigarette lighter/ 12v power port should be the same right? Mine had four wires. A power and ground for the little night illumination bulb and another power and ground for the socket itself. The constant hot I found by poking the open terminals in the fusebox with a meter while the car was off. I then cycled the ignition switch to make sure the power stayed on no matter what position that switch was in.
Yes. Mine do. They daisy chain together so I couldn't see them not syncing up. Both opening and closing ceremonies seem to sync up exactly.
Likes 1 Dislikes 0
Privacy Policy
