| Silver Member Car: 08 WRX STi Fav Mod: Volks/OZs Location: The North Shore, IL Posts: 184
IWSTI Addict since: Aug 2008 Trader Rating: (1) | Did a little homework, seems a 255 is a 1/2 inch wider than stock (245/40/18), but only a fraction if an inch of a taller sidewall. At 55 mph, the speedo is only off by 1 mph. Seems like this would be a great replacement tire size in order to give a little more tire to the ground without screwing up the total tire diameter size. my 2 cents. This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #3 |
| Junior STI Driver | from what I understand, fatter tires (on the same rim) can give you more overall grip because of increased contact patch, but it can feel less responsive. a narrower tire (on the same rim) essentially preloads the sidewalls, making the tire respond a bit quicker. I believe fatter tires will also overheat easier if driven aggressively (like on a track, etc) from the carcass moving and squishing around more. |
| | #5 |
| STI Driver | I'm running 265/35R18 on offset 55 wheels ![]() You'll probably want to run a bit higher tire pressures to avoid sidewall flex. Use a temp gun to make sure the center's not ballooning out and getting hotter than the rest of the tire. |
| | #6 |
| Professional STI Racer
Car: 02 Penis Extender Fav Mod: Autotrader.com Location: Philly Posts: 821
IWSTI Addict since: Jan 2006 Trader Rating: (1) | That's hardly a change in size at all. They will be fine. |
| | #7 |
| Senior STI Driver
Car: White 08 STI Fav Mod: Volk RE30's and 255-35 Dunlop Z1's Location: Redondo Beach Posts: 337
IWSTI Addict since: Sep 2006 Trader Rating: (0) | 255-35-18 here, no problems with em. |
| | #9 | |
| Grassroots STI Racer
Car: '08 STI, OBP Fav Mod: hammer down! Location: Gaithersburg, MD Posts: 555
IWSTI Addict since: Jun 2008 Trader Rating: (0) | Quote:
Frank | |
| | #10 | |
| Junior STI Driver | Quote:
| | #11 | |
Frank | |
| | #12 |
| Junior STI Driver | 18x9.5 +45 TR wheels with 255/40/18 (Azenis RT-615). Would like to go to a 265/35 or a 275/35 with the next purchase. They fit on the stock set up but were tall so I did a minor finder roll in the rear. Tiny clearance at 1/2 turn at the front but no rub. Vorshlag- powered by SmugMug ![]() |
| | #14 | |
| Silver Member Car: OBP 08 STI Fav Mod: AccessPort Location: NJ Posts: 91
IWSTI Addict since: Jan 2008 Trader Rating: (1) | Quote:
Are you putting these tires on the stock rim? I'm curious because I am considering putting on 255/40/18 on the stock non-bbs rims and wanted to make sure I would not have any clearance issues. Anyone else chime in on this? | |
| | #15 |
| Grassroots STI Racer Car: BLUE STEEL GREY STI Fav Mod: Prodrive GC010G's Location: Seattle Posts: 512
IWSTI Addict since: Nov 2007 Trader Rating: (1) | Depends how wide the rim is in comparison to the tire. Otherwise its like wearing your dads shoes, as in like when you were 5. This ad is not endorsed by this member. Please register or login to hide this ad. |
