Old 08-19-2008, 11:41 AM   #1
IWSTI Addict since: Sep 2006
Default Anyone switch over to AMSOIL?
AMSOIL - Signature Series 0W-30 100% Synthetic Motor Oil (SSO)
I heard this is supposed to be a great oil. Lasting up to 7500 miles, tested. Found it on the evo boards.
Any inputs?
GL4662 is offline   Reply With Quote
Old 08-19-2008, 11:45 AM   #2
Fav Mod: Owning it...
IWSTI Addict since: Feb 2007
Send a message via AIM to deeksmooth Send a message via MSN to deeksmooth Send a message via Yahoo to deeksmooth
Default Re: Anyone switch over to AMSOIL?
i ran amsoil in my hondas, loved it... i don't know about 0-30 in the STi though - at least not where i live where its 110~ or higher degrees.
deeksmooth is offline   Reply With Quote
Old 08-19-2008, 11:47 AM   #3
Car: '05 CGM
Fav Mod: HPDEs
IWSTI Addict since: May 2006
I've run Amsoil's Series 2000 Racing Oil in my 2002 WRX and my 2005 STi. Both cars have run perfectly with it. But they also ran perfectly on non-synthetic oil.
I've never used the extended drain intervals and have always stayed with 3,000 mile intervals (unless I'm doing track events in which case the oil is changed immediately before an event regardless of mileage).
Series 2000 was discontinued and replaced with the Signature Series oils.
Gary
Old 08-19-2008, 12:00 PM   #4
Car: 06 STI CGM
Fav Mod: Line X
IWSTI Addict since: Jun 2007
Running Amsoil 5W-30 for 25000 miles. No issues. Change every 3000 though.
Also 75W-90 in tranny, every 10,000 miles. that has worked well for me as well. Easy shifting.
I tried the EaO oil filter, but it always kind of seeped out, the subaru oil filter never leaks.
Kept with the Subaru LSD 90 for the rear end though, never went synthetic. Amsoil never came out with a LSD diff oil.
Brushfire is offline   Reply With Quote
Old 08-19-2008, 12:03 PM   #5
well its around 80 here in MN, could i run it in the winter?
Old 08-19-2008, 12:19 PM   #6
Car: '05 CGM
Fav Mod: HPDEs
Check your Owner's Manual and see what oil is specified. Then see if the Signature Series oil meets that specification.
For my '05 the manual says:
<B>Recommended grade and viscosity
Oil grade:
ILSAC GF-3, which can be identified with the new
API certification mark (Starburst mark)
or API classification SL with the words “ENERGY
CONSERVING” (if you cannot obtain the oil with
SL grade, you may use SJ grade “ENERGY CONSERVING”
oil).
The Amsoil web site lists these specifications for the Signature Series oil:
APPLICATIONS
AMSOIL Signature Series 0W-30 Synthetic Motor Oil is recommended for use in gasoline engines, diesel engines (API CF, ACEA B5) and other applications requiring SAE 0W-30, 5W-30 or 10W-30 with the following worldwide specifications:
• API SM/CF, SL, SJ …
• ILSAC GF-4, 3 …
• ACEA A5/B5-04
• GM 4718M, 6094M
• Ford WSS-M2C929-A
• Honda HTO-06
• Daimler Chrysler MS-6395N
• VW 503.00
So it meets the API SL and SJ requirements listed in my '05 Owner's Manual.
The web site also notes that it offers excellent cold flow properties down to 60 below.
Gary
</B>
Old 08-19-2008, 12:29 PM   #7
Car: OBP 2007 STI
Fav Mod: Brake dust
IWSTI Addict since: Dec 2007
I'd run 0w30 in the winter since 0w has lower pour point (lower cold viscosity) at start up.
Kamrulz4ever is offline   Reply With Quote
Old 08-19-2008, 12:39 PM   #8
Car: 08 STi, DGM
Fav Mod: Stage 2
IWSTI Addict since: Jul 2008
I run Amsoil in my track car (Turbo Acura). I plan to run it in my '08 STI once I put enough miles on it. It's simply the best oil I've ever used. They have claimed that it can last upwards of 25,000 miles, although anyone to test that would be crazy. I HIGHLY recommend their engine flush as well.
SRH_STi is offline   Reply With Quote
Old 08-19-2008, 01:41 PM   #9
Fav Mod: Advan RS 18x9. TurboXS downpipe.
IWSTI Addict since: Jan 2008
I've been running amsoil 5w-30,
I've run Signature Series 0W-30 in all my previous cars. Will be switching to that soon.
paikman is offline   Reply With Quote
Old 08-19-2008, 01:46 PM   #10
IWSTI Addict since: Apr 2005
10w40 Amsoil in my built '07 motor, 15w50 for track days.
The stuff is good .
Old 08-19-2008, 04:11 PM   #11
Car: 2008 STI
IWSTI Addict since: May 2008
Trader Rating: (12)
Send a message via AIM to FlyingPerformance
Gonna run Amsoil 5W-30 in the 08 even though my dealership gave me free oil changes for life every 3500 miles. Ran it in my 05 WRX and 06 STI and never burned a drop. Their filters are also awesome, full synthetic element vs. a paper element. They are the only filter that I know of that uses the full synthetic element.
FlyingPerformance is offline   Reply With Quote
Old 08-19-2008, 08:05 PM   #12
IWSTI Addict since: Apr 2006
I use Amsoil 100% synthetic and Amsoil Ea012 filter in my 08. I change it every 4,000 miles due to the fact I really dont beat on the car too much. Seems to be great oil, well worth it.
KillerBlackBird is offline   Reply With Quote
Old 08-19-2008, 08:06 PM   #13
Car: 08 STI WHITE ! ! !
I'm running Amsoil 5w-30. . No complaints
bklynpanman is offline   Reply With Quote
Old 08-19-2008, 08:36 PM   #14
Car: OBP, 2008
IWSTI Addict since: Jul 2004
Send a message via AIM to method
Running AMSOIL 5W-30 since the first oil change...however read the fine print on AMSOIL's website, they don't recommend going over the recommended change frequency with turbocharged Subaru's due to the filter screen on the feed line.
I ran AMSOIL 10W-30 in my LOB Ltd when I had it, went 10,000/per change with no issues.
I recommend using their oil filter along with their oil.
method is offline   Reply With Quote
Old 08-20-2008, 04:09 AM   #15
Car: 05' STi
Fav Mod: JDM Fogs
IWSTI Addict since: Dec 2005
been on Amsoil since 30K and good to go.
