Old 07-20-2008, 08:26 PM   #211
Car: DGM 2008 STI
Fav Mod: 292 WHP!! 352 TQ!! RaWr
Default Re: Magnaflow CBE
Originally Posted by WRXGuyInUSA View Post
The catalytic converter actually causes a chemical reaction with eliminates a lot of the toxic gases and emissions a car produces... but removing it, your exhaust is about as un-healthy as it gets, and obviously it's NOT good to breath in the fumes. It smells because it's just raw exhaust... and there's not much you can do about it.
Thanks for the heads up. Im actually getting used to it now hehe
My magnaflow exhaust crackles and pops only on warm up, then it levels out evenly.
Also i have a question, how long does it take before the exhaust is broken in where the packing inside changes the tone of the exhaust.. I hear a week but someone says it usually takes about a month..
Old 07-22-2008, 08:02 AM   #212
Car: 08 Gray STi
re: loudness differences between audio samples.
keep in mind this is a sample to show exhaust tone. relative volumes are offset by the recorders auto EQ function. to keep the Magnaflow from clipping would have ended up with the OEM so soft you'd have a hard time hearing the details. Bringing up the two equally to make the OEM loud enough to hear would have resulted in clipping the audio sample of the Magnaflow. (based on the gear i used).
this will all be detailed in the web page i do. there will be both dBA (human hearing range) and dBC (musical range) readings even though DOT/States specify dBA for their requirements (when they have them). dBC will typically provide a higher reading than dBA because it samples a wider range of frequencies (and this is reflected in the numbers I got). for now, suffice it to say that my readings confirmed Magnaflows assertion that they pass all state restrictions on loudness (95 dBA iirc).
Old 07-22-2008, 04:39 PM   #213
Technically the internal stuffings of the muffler (fiberglass packing, insulation, steel wool, etc) won't "break in". They are designed to help absorb / diffuse based on the characteristics of the muffler design. Over time they will break down with heat, vibration, moisture, pressure, etc. On really cheap mufflers this is quite problematic because the internals breakdown quickly and the design intention of the muffler is quickly compromised.
shiplemw is offline   Reply With Quote
Old 07-22-2008, 06:34 PM   #214
Car: 08 STi, 08 ZX10r
Fav Mod: COBB AP
Originally Posted by thekiffer View Post
Ok, so mine whistles under full boost. This is my first turbo and I do not have an air intake with this but the whistle is pretty significant. I am almost positive it isn't the exhaust because it is only under boost and everything is really tight. I went back and made sure. I know someone else mentioned this too. Is this common? I would hate to blow something up from my $450 exhaust.
I have the same whistle .. it seems to start around 4k under load...it almost screams.. it sounds like wind is getting in between somewhere?? I had the exhaust installed at a shop and everything is buttoned down... no idea what it could be..... I'll try to capture it with my video camera and post it..
Angry-cop is offline   Reply With Quote
Old 07-22-2008, 07:38 PM   #215
Car: DGM 2008 STI
I dunno what screams you guys are getting. but my car whitles cause i got the CAI
Old 07-22-2008, 08:38 PM   #216
Fav Mod: COBB AP
here is the vid.. every time I accelerate, if you listen closely you can here it.. its a a lot louder in person.. No CAI.. and i have a completely stock air box..
Old 07-22-2008, 08:54 PM   #217
Car: 2008 Sti
Sounds normal to me.. I'll drive mine tomorrow and see..
alex911s is offline   Reply With Quote
Old 07-22-2008, 09:02 PM   #218
Banned
Fav Mod: brown chicken brown cow
I hear it. it is probably the design of the tips... not a smooth split off. Just a hole in the pipe for the inner tips. what you're hearing is turbulent exhaust rushing out of the tips.
mattjk is offline   Reply With Quote
Old 07-22-2008, 09:21 PM   #219
Car: AW/Gold 08 STI stg2
Fav Mod: hands
mine does it...........kinda annoying. im slappin on the catless V3 on monday hopefully that will drown it out.
OH8STI is offline   Reply With Quote
Old 07-23-2008, 09:34 AM   #220
Car: DGM 2008 STI
I have no idea what you guys are talking about lol. But this exhaust with a catless dp makes MUSIC!!!!!!!!!!!!!!!!!!
Old 07-23-2008, 11:41 AM   #221
Car: White,2008,WRX STi
Yep that is it. You can barely hear it on there but I hear it and that is what mine sounds like too.
thekiffer is offline   Reply With Quote
Old 07-23-2008, 08:46 PM   #222
Car: 08 Gray STi
Some people pay extra and take pride in that sound.
YouTube - The whistles go.... whoo whoo!
Old 07-23-2008, 09:27 PM   #223
Car: 2008 Sti
Old 07-24-2008, 11:09 AM   #224
Car: Dark Grey 08 STI
Fav Mod: Arm rest extender
Anyone get one recently? Just curious if they made adjustments for fit issues. I was told I'll have a new one sent once it is hand picked. hadn't heard anything for a week though.
spongebobnopants is offline   Reply With Quote
Old 07-24-2008, 12:35 PM   #225
Car: 08 Gray STi
last week is recently but that would include first wave builds.
