Old 05-14-2008, 02:42 PM   #1
Car: 08white sti gold bbs
Fav Mod: emblem delete
Default front brake noise?
hey guys,just joined great forum.so much good info i love it,goin to walk the dogs with the lady so i need to be quick,08 sti,950 mi,strange noise coming from right front brake at slow speeds,2-5 mph first a clack then a screachish kinda squealany thoughts?this just started,noticed it 15 min ago pulling up and turning around in front of the house.i live in the mtns on a dirt road,dont know if this makes a diff,anywho broke it in nice,drive it like a adult,not raggin on the car i love it to no end thanks mike
sleepsindirt is offline   Reply With Quote
Old 05-14-2008, 02:49 PM   #2
Fav Mod: Motor Mounts
Default Re: front brake noise?
Its not uncommon at all to hear brake noises at low speeds on STi's. My brakes make all kinds of noises... The real question is...do they still stop you well?
Old 05-14-2008, 03:13 PM   #3
thanks for the input,after a slow quick test drive i realized its both fronts not just one,i also under stand its hard to make a racecar tame enough for daily driving.thanks mike
Old 05-14-2008, 03:16 PM   #4
oh,they are the baddest brakes ive had on a vehicle even if they are loud,they work great
Old 05-14-2008, 03:42 PM   #5
Car: '07 UGM STI Ltd #262
Fav Mod: APS TBE
Not intending on highjacking, but seeing as I have a related problem I thought I'd ask...
I get the clack and squeal when I'm driving slowly too. Then I'll stop, go to back up, then brake again, and it does the same clack and squeal. The funny thing is, is that it only happens on my drivers side front brake. Is it possible that my brake pads are lose in the front left rotor? Suggestions?
pearl boxer is offline   Reply With Quote
Old 05-14-2008, 04:58 PM   #6
pearl boxer,thats it to the t with the clack noise,the clack has me more concerned than the rough squeal.....
Old 05-14-2008, 05:06 PM   #7
Welcome to fixed caliper brakes . The pads float in the caliper and there is a small amount of play. The first time you brake in one direction (forward or back) after having braked in the other, you will probably hear a click/clack/snap/whatever. 'Tis normal for this style of brake.
Old 05-14-2008, 05:20 PM   #8
thanks rootus,i was hoping it was somthing like that
Old 05-14-2008, 08:09 PM   #9
10-4...welcome to big brakes...mine clack...cling...zap...pop...when changing direction from front to revers.
Old 05-14-2008, 08:10 PM   #10
Squeal...I had the same problem from 10-0mph on stock pads. When I switched to Hawk HPS I have no problem with squeel....
Old 05-15-2008, 07:10 AM   #11
Fav Mod: APS TBE
Thanks guys. I figured that this was somewhat normal for the Brembo's. I was just concerned because it never did this on my 06 WRX with the 4 pots, which I believe are a fixed caliper brake as well. Also, when I bought the STI from the first owner and drove it over 1800 miles to my home, it never once made any brake noise. It wasnt until a couple weeks later that it just started happening. I do have Porterfiled RS-4 brake pads on, which would explain a bit of squeel. But why the clacking noise is localized on my front left brake caliper is beyond me. I guess I'll have to take them apart this weekend. Any suggestions as to what I should look for when I'm in there?
Old 05-15-2008, 06:27 PM   #12
Car: 08 STI
mine started squealing and grinding at 100 miles. i was woried at first, but it kinda went away, only does it now when they are really hot. i had the dealer check it out just to be safe and they told me half a dozen 08 sti owners have come in complaining about it. but they cant find anything wrong. i read around i little more, and accept it as normal now
STI 08 is offline   Reply With Quote
Old 05-16-2008, 05:33 PM   #13
Get them looked at again, with the wheels off.
There have been a few complaints of cracked pads - I had weird grinding noises at 50-100 miles on the car, I'm at 1000 now, and both fronts are definitely cracked and on order. If they aren't cracked, they might be wearing unevenly on the outer edges.
Just an FYI.
-G
cyanb is offline   Reply With Quote
Old 05-16-2008, 08:12 PM   #14
Car: Blue 08 WRX STI
Fav Mod: rallyarmor mud flaps for now
Send a message via AIM to Subie 2.5 STI
yea i have noticed the same squel noise on the front brakes, i thought it was something but i noticed the same sound on my spec v when i change brake pads. i just think its normal on brembos.
It only squels on mine on low low speeds.
Subie 2.5 STI is offline   Reply With Quote
Old 05-17-2008, 08:47 AM   #15
Car: DGM 08 STi
Odd. I don't have any type of weird noises from mine (at about 2500 miles). My '05 never made any odd sounds either. Just assloads of dust.
-rain-
raindance is offline   Reply With Quote
