Old 05-06-2008, 01:12 AM   #1
Car: White 08 WRX STI
Fav Mod: Magnaflow Catback
Default No Muffler
would it be bad to drive with no muffler. im thinking it would be alot louder. also pros/cons wit no muffler
Joey_08sti is offline   Reply With Quote
Old 05-06-2008, 03:45 AM   #2
Car: 08 OBP STi
Fav Mod: Boobies........oh, for a car Boost
Default Re: No Muffler
no pro other than a loud exaust. +1 on con for exaust db tickett.
Wales Garage is offline   Reply With Quote
Old 05-06-2008, 04:59 AM   #3
Car: Silver 05 WRX Sedan
Fav Mod: Stage 2 w/ Uppipe
it will be INSANELY loud... like louder than those harley davidson bikes... its gonna be a cop magnet.
JuggernautTCW is offline   Reply With Quote
Old 05-06-2008, 05:06 AM   #4
Car: Black 07 STI
Fav Mod: Cobb AP V2
Send a message via AIM to Knuckleball22
I have no muffler and it's not that loud. I welded up a temporary exhaust until I go stage 2. Theres a cat and a turbo and both quiet the exhaust significantly.
Knuckleball22 is offline   Reply With Quote
Old 05-06-2008, 06:11 AM   #5
Fav Mod: I do meth...
On the stock turbo you'll lose power.
I have dyno graphs to prove it
renns is offline   Reply With Quote
Old 05-06-2008, 06:22 AM   #6
Fav Mod: Autotrader.com
I would like to see those .
I'm running a small 2.25" pipe that replaced the big heavy muffler. Is the power loss significant?
Old 05-06-2008, 06:33 AM   #7
I have the dyno graphs at home and I'll upload them, but long story short the straight pipe made about 10 less peak whp and 30 less whp throughout the top end... spooled the turbo about 2-300 rpm later too. Keep in mind it was tuned for the straight pipe, not just a bolt on job. When I switched to my other exhaust (Cobb full 3" with mufflers) and re tuned it, I made the 10 peak and 20 top end whp.
Interesting stuff. My tuner and I have a theory that the noise from the straight pipe was setting off the knock sensor and causing it to pull timing though... so that could be part of the power loss. Search 'straight pipe STi' on youtube and you can hear it...
Old 05-06-2008, 06:37 AM   #8
Interesting.
After an evo school and an autocross event this weekend my car felt like it was running crappy, and it took an ECU reset for it to feel right again. I wonder if you're onto something here.
ps- search for homemade 08 sti exhaust to see mine.
Old 05-06-2008, 02:14 PM   #9
but with no muffler it wont mess up the car will it
Old 05-06-2008, 02:21 PM   #10
Car: 07 Lexus IS250
Fav Mod: Future 09 STI Owner :)
Wouldn't one consider this setup with no muffler? Perrin and Cobb both have the big muffler at the rear of the car just like the stock setup.
This is AMR's setup. I won't what gains and sounds this setup will provide?
chmura is offline   Reply With Quote
Old 05-06-2008, 02:26 PM   #11
Well I could stick my hand completely in my invidia n1 race exhaust. Which means NO restriction. So how would just not having the last axle back part be non benificial? Just trying to comprehend it...Not saying you would gain, but why would you lose?
Old 05-06-2008, 02:38 PM   #12
The only problem with that is the midpipe points the exhaust right into the back of the bumper. You need a turn down or something to direct that exhaust somewhere. Here's mine. YouTube - 08 STI Home made exhaust
Old 05-06-2008, 05:08 PM   #13
Well just tried out the no axle back thing. Holly cow! I couldnt stop smiling!!!! I herd my baby puur again. Reminds me of my n1 days(sighs in remorse)... As for boost I gained another psi like I should. With stock axle back I would be down 1 psi from my target 18.5 cobb map. Now im back where I should be. Im running a helix catted downpipe and stock midpipe, sounds a little quiter than my n1. But alot more mini back fires. WOT sounds like I have an external waste gate. Sounds to sick for words. All get a video up probly by tomorow. As of right now, I just found a cheap substitute for a catback.
Old 05-06-2008, 07:12 PM   #14
Car: AW/Gold 08 STI stg1
Fav Mod: AP
i'm did the same thing, took off the muffler, but the force from the opening was so hard it blew one of reflectors out!!! The welding of the flange should be done tomorrow, and ill try to post up pics and a vid asap. it sounds very very good.
OH8STI is offline   Reply With Quote
Old 05-06-2008, 07:19 PM   #15
Car: CGM 05
Fav Mod: cobb ap v2 w/ LC
Send a message via AIM to 1loudsti
im not running any muffler at all and the butt dyno says its quicker
bellmouth catless 3inch all the way back resonated tip
1loudsti is online now   Reply With Quote
