Old 05-03-2008, 09:36 PM   #1
Fav Mod: Flat soled shoes
Default Really dumb question: How to reset stock ECU multiplier?
With my old wrx and the AP, all I had to do was change the map and the ECU would be reset, I could drive it like a madman (or do the 5th gear push on an empty highway) and I could max my multiplier.
My question is, how do you reset the ECU on the new '08 STi's? Any other strategy on maxing that multiplier?
Thanks.
linkbeat is offline   Reply With Quote
Old 05-05-2008, 07:22 AM   #2
Car: Aspen White 08 STI
Fav Mod: TOP SPEED TUNE!!!
Default Re: Really dumb question: How to reset stock ECU multiplier?
Doesn't the AP v2 allready do that for you when you flash the map over?
08aspenSTI is offline   Reply With Quote
Old 05-05-2008, 08:37 AM   #3
Trader Rating: (47)
WHy would you want to do this? If you have a problem and the multiplier is being pulled, resetting it and artificially upping it via the methods described will only cause greater issues down the road. If the multiplier is not at full, then something is wrong with your setup or tune.
Tony
Old 05-05-2008, 09:40 AM   #4
Fav Mod: Autotrader.com
And on the same note...how do you know it isn't already?
waktasz is online now   Reply With Quote
Old 05-05-2008, 01:11 PM   #5
Tony
The STi ECU is stock, and for now I don't plan on changing that. I just spent the first 1000 miles driving this car under 4000 rpm, and babying it. I imagine the ECU has set the multiplier at a very low level after observing my grandma-esque driving habits. So my purpose is to reset that multiplier, drive like I would normally now that it's over 1000 miles, and have the multiplier maxed so it performs better. Make more sense?
Old 05-05-2008, 01:29 PM   #6
That's not how it works at all.
Old 05-05-2008, 01:37 PM   #7
Ooookay then. Looking for some help here.
Old 05-05-2008, 01:50 PM   #8
Enginerd
Car: The Spaze Mobile
Fav Mod: Tuning
This is where you want to start reading
ECU Tuning & Performance Electronics - IWSTI.com: Subaru STI Forums
Old 05-05-2008, 02:46 PM   #9
Car: 08 STi, SSM
Just pull the negative lead off your battery and hit the brake pedal, then reconnect the negative. Or you can just reflash your realtime map to reset the ecu. Either way, you will be losing all of your learned fuel trims. If I were you, I'd just drive the car hard and datalog to see what the multiplier does. You really don't want to force it to 1 if there is something legitimately keeping it from rising. How do you know you aren't at 1 already?
Old 05-05-2008, 08:51 PM   #10
Thanks! I don't know for sure, but I had a hunch that it would be lower just based on the fact that its brand new, and I drove it very timidly for the first 1000 miles. It was my understanding that those fuel trims were created using driving habits as a basis.
Old 05-05-2008, 08:54 PM   #11
Car: 08 STi, SSM
I'm of the opinion, that if you drive the car timidly, it doesn't break in properly. Drive it like you intend to daily drive it. Don't sweat the little things, just drive the car.
