Old 05-03-2008, 06:08 PM   #1
Car: Silver 08 STI
Default traction control button on 2008...? or something else?
is that what that little button is next to the side view mirror adjuster?
whats that little button do?
better to launch with it on or off?
vhalin is offline   Reply With Quote
Old 05-03-2008, 06:27 PM   #2
_
Fav Mod: 2008 STi
Send a message via AIM to Spaceman Send a message via Skype™ to Spaceman
Default Re: traction control button on 2008...? or something else?
Was it that hard to look in your driver's manual?
Or better yet search?
VDC, DCCD, and SI-DRIVE Explained! (Great Info)
Spaceman is offline   Reply With Quote
Old 05-03-2008, 06:33 PM   #3
Fav Mod: karma wheel hanging from rearview mirror~ 5th door~
Lightbulb Re: traction control button on 2008...? or something else?
search is your friend newb if not your best friend on this forum!
Old 05-03-2008, 08:55 PM   #4
Car: Silver 08 STI
this is still confusing as to which one would be best for launching... off or traction?
VDC – the default setting, optimized for daily driving situations. There are no warning lights associated with this mode, which enables all controls for ABS, the Traction Control System (TCS), and VDC.
Traction – set by holding in the VDC off switch, which turns the VDC warning light green. This setting is more performance-oriented, with less-aggressive stability control. Engine torque-reduction control is disengaged.
Off – set by pushing the off switch once. This setting turns off stability control and the traction control functions for emergency situations, such as getting out of mud or snow. It leaves ABS and incline start assist active.
Old 05-04-2008, 01:04 AM   #5
Car: 08 STi, SSM
Off. Try the different modes so you know exactly what they do.
Old 05-04-2008, 05:09 AM   #6
Car: WRB 08 WRX STI
Again search is your friend but quickly the best mode for launch is:
- S#
- Auto (-)
- Stability Control off
Please read your owner's manual as well as search the technical forum for 2008.
Thanks!
pisymbol is offline   Reply With Quote
Old 05-04-2008, 06:17 AM   #7
Car: Silver 08 WRX STi
Wow! Give a guy a break. The owners manual will explain this button but it certainly doesn't address this button's function for launching the car!
Punk
PunksSTi is offline   Reply With Quote
Old 05-04-2008, 10:33 AM   #8
^^^ we are giving him a break... no one is ripping on him and everyones being very courteous in advising him to use the search function... pisymbol even gave him a real quick answer.
even if he didn't read the manual, the link provided by spaceman should have sufficed in answering all the questions he had...
Old 05-04-2008, 11:05 AM   #9
Car: Silver 08 STI
- S#
- Auto (-)
Thanks!
green or yellow mode?
Old 05-04-2008, 11:51 AM   #10
Car: 08 WRB STi
Fav Mod: Stage 1
green
BuzSTid is offline   Reply With Quote
Old 05-04-2008, 11:55 AM   #11
_
Fav Mod: 2008 STi
Wow, do you not know how to read? Is it that hard to look in the manual and find out which is which?
The link I provided has the info on the second post, if you had a set of eyes you wouldn't miss it.
Old 05-04-2008, 11:56 AM   #12
_
Fav Mod: 2008 STi
Originally Posted by BuzSTid View Post
green
Green is for traction, and Yellow is Off...
Old 05-04-2008, 12:03 PM   #13
Car: 08 STi, SSM
Just goes to show, you can lead a horse to water...
Old 05-04-2008, 12:08 PM   #14
^^^ +1
rtfm... da mantra ~~
