Old 05-03-2008, 01:52 PM   #1
Car: STIzzle
Fav Mod: Tint
Default AP Stage 1 Cobb 93 - Overboost/Cyl4 misfire?
Okay. So I went stage 1 yesterday and I have had some issues. When I am not having issues the car is spectacular, however I want to know if anyone else has these issues?
If I am in neutral and rev then occasionally I will throw a P0304 code: cylinder 4 misfire detected.
Note: This is no longer repeatable. I am going to try some more right now.
Edit: Still can't get it to repeat...hopefully it is gone for good.
I was driving it -really- hard and I pulled a P0244 code with a bunch of lights.
Has anyone else had any similar problems?
Although I would be upset to lose the motor...it would make it much easier to convince my wife that I need an "improved" motor.
Old 05-03-2008, 03:04 PM   #2
Car: 08 STI WHITE ! ! !
Default Re: AP Stage 1 Cobb 93 - Overboost/Cyl4 misfire?
i've had the p0244 code as well as a bunch of other people.. i switched to the perrin map and had no problems
bklynpanman is offline   Reply With Quote
Old 05-03-2008, 04:07 PM   #3
Car: Dark Grey 08 WRX STi
Fav Mod: COBB AP - Stage 1 - 93 Octane
2nd that. Perrin slightly less boost and never hit 18 but always 17.something
The Cobb always hit 18 but the P0244 just does not make it worth the trouble. Honestly the difference between Cobb and Perrin 93 map is neglible.
So glad I bought my AP from Perrin and had a free alternative for 93 oct. map from Cobb 93 map
threader is offline   Reply With Quote
Old 05-03-2008, 05:49 PM   #4
Car: STIzzle
Fav Mod: Tint
I think I will switch to the Perrin map then.
Old 05-03-2008, 05:52 PM   #5
With the Perrin map I hit almost 19 but I never throw the codes.
Old 05-03-2008, 06:34 PM   #6
How do you read 19? Thought ECU max readout was 18.4 Got a gauge? My ap never hits 18. nada
Old 05-03-2008, 06:50 PM   #7
Fav Mod: Advan RS 18x9. TurboXS downpipe.
this is from my dyno result, boost hits 18.9 max on cobb
paikman is offline   Reply With Quote
Old 05-03-2008, 06:58 PM   #8
Super Moderator
Car: 08 DGM STI
Fav Mod: My wife :)
If you read the "manifold absolute pressure" value, I believe you can calculate above 18.4 by subtracting 14.7 (though this value can fluctuate slightly).
Digitalfiend is online now   Reply With Quote
