Old 05-01-2008, 01:48 PM   #1
Car: AW 08 STI
Fav Mod: Cup Holders
Default Driver's Side Rattle
I have a faint rattle coming from the driver's side of my car. It doesn't seem to do it if its been sitting outside all day, only when its under cover all night and its cooled down. Are there any pieces in the doors that are particularly prone to loosening?
WALoeIII is offline   Reply With Quote
Old 05-01-2008, 02:14 PM   #2
Car: 08 STi, SSM
Default Re: Driver's Side Rattle
2002 model year Imprezas were known to have their window actuators work their way loose after a while and tear up the sheet metal if left unchecked. I've personally had to work on 2 Imprezas that did this.
Old 05-01-2008, 02:20 PM   #3
Car: AW 08 STI
By actuator do you mean the motor that is responsible for moving the glass or the switch that turns said motor on and off.
Old 05-01-2008, 02:28 PM   #4
Car: 08 STi, SSM
yes...motor assembly=actuator
Old 05-01-2008, 05:16 PM   #5
Car: DGM 08 STi
Fav Mod: Stg 1 soon!
Every Subaru I've owned has had some mystery interior rattle. I was hoping with the bodystyle change that they would go away. Wishfull thinking I guess.
cookin is offline   Reply With Quote
Old 05-01-2008, 05:51 PM   #6
Mine has this wierd chime noise, like two light little metal pieces clanking against one another.
Kilya is offline   Reply With Quote
Old 05-01-2008, 09:08 PM   #7
Car: White 08 WRX STI
Ive got a rattle that seems to come from inside my steering column. Only happens on rough pavement, very annoying.
AWD4lyphe is offline   Reply With Quote
Old 05-01-2008, 09:23 PM   #8
Car: 08 STi, SSM
At least the vin number trim piece won't rattle on these cars.
Old 05-01-2008, 09:45 PM   #9
Car: AW 08 STI
I'm sure each of these can be traced down, the trouble is diagnosing them when they are intermittent (or only on rough pavement).
Old 05-02-2008, 02:35 PM   #10
Car: AW 08 STI
I am now very confident that the loose part is somewhere in my steering column and it only sounded like it was coming from the door. It sounds like a piece of plastic, something I probably broke loose banging my knees (I'm tall) into the column sliding into and out of the car.
Old 05-02-2008, 02:36 PM   #11
Car: AW 08 STI
I would be willing to bet we have the same issue.
Old 05-02-2008, 02:42 PM   #12
Enginerd
Car: The Spaze Mobile
Fav Mod: Tuning
Try holding on to the steering columns plastic cover. That sounds like a rattle I had.
Old 05-02-2008, 02:45 PM   #13
Car: AW 08 STI
I tried that, no luck.
Old 05-02-2008, 02:46 PM   #14
Enginerd
Fav Mod: Tuning
I hate rattles too.
Old 05-03-2008, 07:12 PM   #15
Car: Silver 08 WRX STI
I have the exact same problem...It's annoying as hell...but can't seem to pinpoint it
MIA~WRX~STI is offline   Reply With Quote
