Old 05-08-2008, 05:46 AM   #61
Default Re: Harman Motive 2008 STI Catback and Downpipe - Info and Pics!!
Yeah, I am currently waiting for some better videos before I purchase it.
blackhawk444 is offline   Reply With Quote
Old 05-08-2008, 07:12 AM   #62
Car: 08 DGM STI
Fav Mod: right pedal
Me too. Really looking fwd to the high quality vids.
shiftonthefly is offline   Reply With Quote
Old 05-11-2008, 04:58 AM   #63
Car: AW 08 STi
Fav Mod: snow tires
Any dyno plots around that show the difference of this system with just the Harman downpipe vs. the entire TBE?
Spork is offline   Reply With Quote
Old 05-11-2008, 06:15 AM   #64
Car: 2008 DMG STi
FWIW, I talked to the guys at HM about this. I was told that their DP would not match up to the stock CB perfectly since it was 3". That there may be some leaks. Kinda sucks doing it by the piece-by-piece method, but at least they were honest.
1day is offline   Reply With Quote
Old 05-11-2008, 11:49 AM   #65
has anyone taken a video yet?
Old 05-11-2008, 03:11 PM   #66
Car: 07 MZ4,08 STI
How about HM CBE? Is it going to fit stock DP ?
freeman is offline   Reply With Quote
Old 05-11-2008, 03:43 PM   #67
Car: AW 08 STi
Fav Mod: snow tires
Thanks, that does help.
I am trying to justify the additional purchase of the cat-back over just a DP. If there is a real improvement on just a Stage 2 setup on the 08 by adding the catback then I'll probably look into purchsing the full setup. I am not interested in it for sound or noise or bling at all. I want to know if there is documented gains to be had on a stage 2 by adding the catback on the 08. If it's just 2-5 hp I can't justify the additional 1k. If it's 10, thats a different story.
Old 05-11-2008, 04:01 PM   #68
Fav Mod: Advan RS 18x9. TurboXS downpipe.
Spork, there has been quite a large amount gained, dyno proven by tuners..but to utilize it you need to get a protune or custom flash via ecutek software
paikman is online now   Reply With Quote
Old 05-12-2008, 05:21 AM   #69
HowTo Contributor
Car: '05 OBP w/ Gold
Fav Mod: Spec C Type-RA struts
I see that the bung for the stock rear O2 sensor is pre cat. Any CELs with this? I'm planning to get an 08 STi in the semi-near future and eventually if I mod it I will need it to comply w/ STU auto-x rules which now don't allow for any type of CEL defeat (mechanical, electrical, turning off the CEL in a tune, etc.)
Old 05-12-2008, 05:13 PM   #70
Car: 08 STi
Here is another video posted by a customer. Thanks to Marcus K for posting it!
YouTube - 2008 STi with Harman Motive Turbo-Back Exhaust
Harman Motive is offline   Reply With Quote
Old 05-12-2008, 05:16 PM   #71
Car: 08 STi
REGARDING FITMENT OF DOWNPIPE/CATBACK TO OEM:
Our downpipe and catback use a 3" flat flange. The OEM pieces use a 2.5" donut gasket.
In order to keep flow as high as possible, we elected to use the 3" flanges.
If you try and connect a Harman DP to a stock catback, they will bolt together, but the seal is less than optimal due to the thin donut style flange on the stock system. This can result in a small exhaust leak, but won't effect performance.
However, our catback seals nicely to an OEM (or OEM style like Cobb) downpipe. You can use a flat gasket or the donut (the donut fits inside our flange). We recommend using a 3" all the way through design where possible.
Old 05-12-2008, 05:17 PM   #72
Car: AW 08 STi
Fav Mod: snow tires
Are there any left currently in stock, or when is the eta on the next batch?
Thank you.
Old 05-12-2008, 05:18 PM   #73
Fav Mod: Britax Roundabout
Man, that sounds nice. Maybe a bit too loud for my needs (DD, family hauler) but very nice.
Old 05-13-2008, 04:54 AM   #74
Car: 08 Aspen STi Hatch
Fav Mod: Stage 2 AP
I ordered one a couple weeks ago and it is on its way to my house as we speak. Not sure if there are any more...
HASTIhatch is offline   Reply With Quote
Old 05-13-2008, 06:42 AM   #75
Fav Mod: Bride Brix II
I'd be surprised if you found this exhaust too loud for DD. If you listen to the radio at all, you will probably not even be able to tell a difference over stock. I'd consider it a very healthy, conservative sound
Marcus is offline   Reply With Quote
