Old 04-20-2008, 10:46 AM   #16
Car: 08 red S.T.I
Default Re: Intake Silencer removal for 2008
Guys, I could be wrong b/c I have not started mine yet(maybe tonight). Anyway, I believe there will be performance gains by removing and or modifying this. I did this at the race track in my 1990 Mustang Gt as did a friend of mine when received the tip from someone at the track. We both dropped exactly 3 tents from our times the very nxt run. I believe the result would be even more dramatic in a turbo... Again, I may be offbase here but I am assuming this feeds the airbox? Wouldn't it be beneficial to run a ram air so to speak to this via fabricating a stealth like inlet in the lower front balck louvered cladding? Again, I have not even look into this at all other than reading this post but if I am adding things up correctly then I may pursue this. Please share your thoughts. Thanks.
aquack is offline   Reply With Quote
Old 04-20-2008, 10:49 AM   #17
Car: OBP 07 STi
Fav Mod: Ring-Shaped Reinforcement Frame
Yeah, you're way off base. Go look at your intake system closely, then come back and post.
USNSTI is online now   Reply With Quote
Old 04-20-2008, 11:54 AM   #18
Car: Silver '08 STi w/BBS
Fav Mod: WC Lathe Werks Copolymer Sphere Shift Knob
Originally Posted by USNSTI View Post
Where would the air come in then?
I'm not saying block the airbox inlet.
There's a little round hole in the airbox that leads to the silencer, blocking it should prevent the air (sound waves, rather) from entering the silencer.
rj45 is online now   Reply With Quote
Old 04-20-2008, 11:58 AM   #19
Car: OBP 07 STi
Old 04-20-2008, 12:14 PM   #20
Fav Mod: Hatchback!
The 08 is a different airbox/silencer design from previous, its now like the legacy. No more silencer in the front wing that can be removed or replaced with an elbow. The silencer is now hanging under the airbox, could be removed or just capped off (duct tape?).
JPH did his, reported minimal sound change, so i'm not bothering with mine. Think the sound 'improvement' is much less than earlier models due the the different design & airflow path
S'poreSTI is offline   Reply With Quote
Old 04-20-2008, 01:19 PM   #21
Car: 08 red S.T.I
Thanks for the diagram--very sweet(where did you get it)? Anyway, it doesn't look like I was off base at all.
Old 04-20-2008, 01:32 PM   #22
Car: OBP 07 STi
Be sure to post up your time slips / dyno plots of your silencer removal gains.
Old 04-20-2008, 02:08 PM   #23
Car: 2008 DMG STi
FWIW, I had an 08 WRX before I got the STi. I found that the WRX has the same airbox as the STi, but without the sliencer. There was a round lip where the silencer would go, but it was not cut out. I could hear the BOV a lot more on the WRX than on the STi. I just figured it was because the turbo spools up much earlier on the WRX and the BOV was not being drowned out by engine noise due to high rpm's. If you guys really wanted to do away with the silencer and have the hole plugged, then an 08 WRX airbox would be the OEM solution.
1day is offline   Reply With Quote
Old 04-20-2008, 06:06 PM   #24
Fav Mod: APv2 Stg2 93
The 08 STI intake is more similar to the Legacy intake design like someone already mentioned, rather than the 06-07 STI's.
Check out this other thread:
08 STi intake silencer delete? How?
Pretty simple, took like 20 mins, didn't have to remove the bumper or anything like that. I don't notice any performance gains or loss. As far as sound goes, you can hear the bov and the turbo spooling a bit more.
NaoNao is offline   Reply With Quote
Old 04-20-2008, 06:40 PM   #25
Send a message via AIM to midnit
Awesome link sir!
midnit is offline   Reply With Quote
Old 04-20-2008, 07:18 PM   #26
Car: Silver 08 WRX STi
Fav Mod: Mud Flaps/AP Stage 1
Nao Nao,Great link, that's just what I started the thread for...Mission complete!!!!!
Thanks!
Giant is offline   Reply With Quote
Old 04-21-2008, 05:21 AM   #27
Car: 08 red S.T.I
does everyone agree that the wrx version would bolt up and provide the desired result??
Old 04-21-2008, 08:30 AM   #28
Car: Pure white MY08 STI
I did remove my silencer and you definetly get a little bit more sound.
More Performance... i dont know
It's possible maybe, because the air can go directly and smooth to the filter element and don't have to swirl in to the silencer
suby555 is offline   Reply With Quote
Old 04-21-2008, 03:13 PM   #29
Car: 08 OBP STi
Fav Mod: Boobies........oh, for a car Boost
after the test pics for the wheels, my hacked intake from my LGT goes in with the K&N. i payed alot of money for a turbo im gonna hear it.
Wales Garage is offline   Reply With Quote
Old 04-21-2008, 05:43 PM   #30
Trader Rating: (48)
I took the silencer off the other day when installing my Kartboy crank pulley. Drove the car afterwards and noticed very little difference in sound. Not expecting anything in terms of performance. I put it back in shortly after.
Tony
