Old 04-13-2008, 01:20 PM   #16
Default Re: Does the Accessport have to stay in car after flash?
Originally Posted by HASTIhatch View Post
And after car is flashed, you have to disconnect the green test connectors, yeah? That's what the cobb PDF said.
Correct!
Old 04-13-2008, 01:27 PM   #17
Originally Posted by Brand View Post
Is this just for datalogging certain variables or what? I didn't connect anything before I flashed mine, have had no problems.
For the upload of the new map to occur, the test connectors need to be connected. Unless there is a difference with the 08's that I am not considering. I don't have my manual in front of me, take a look in there, I *think* it covers connected v. disconnected.
Old 04-13-2008, 01:38 PM   #18
Trader Rating: (13)
green connectors needs to be connected to load a base map ONLY, real time maps do not involve them
So off the shelf Cobb maps are basemaps (I believe, never used hem), so you need the green conneteors to be together.
Once you have a pro-tune, your tuner most likely have your map as a real-time map loaded over a base map, so green connectors are not needed
blindfold is online now   Reply With Quote
Old 04-13-2008, 02:37 PM   #19
Car: AW 08 STi
Fav Mod: snow tires
HASTIHatch, look at the PDF that was linked here and look at the vehicles it lists that it supports. The 08 STi is not in that list. The Users Manual that came with my AP for my 08 does not require the connection of the green wires at all. I successfully flashed stage 1 without connecting these wires, per the instructions that came with my AP.
If you've purchased an AP open up the disk it came with and there is a users manual on that disk.
Spork is offline   Reply With Quote
Old 04-13-2008, 03:08 PM   #20
Car: DGM 08 STI
Fav Mod: cobb AP
I was gonna say, if my base map flash didn't work, my car sure warmed up after break in
I am pretty good at reading/following instructions and I never hooked up any wires prior to using mine.
Old 04-14-2008, 03:44 AM   #21
Good call, thanks, forgot about the base/real-time difference!
Old 04-14-2008, 05:12 AM   #22
Super Moderator
Car: 08 DGM STI
Fav Mod: My wife :)
The 2008 STI does not need the green test connectors to be connected to flash a base map.
Period.
Old 04-14-2008, 06:03 AM   #23
Car: 08 Aspen STi Hatch
Fav Mod: Stage 2 AP
Period.
Thanks for this very helpful information, Digital. Are you able to explain why this is the case? I just ask, since I see that in the PDF for Cobb's explanation of installing the AP, it calls for the green test connectors. Why might they have said that in that manual versus what we should be doing for our STI? Is it that that manual is for, say, just regular WRXs? I just like to understand these kinds of things. Thanks.
-HASTi
HASTIhatch is offline   Reply With Quote
Old 04-14-2008, 06:11 AM   #24
Car: AW 08 STi
Fav Mod: snow tires
Here you go.
-HASTi
Old 04-14-2008, 06:23 AM   #25
Fav Mod: Stage 2 AP
Here you go.
Thanks SPORK.
